Radiator hose question on 4.6L - TCCoA Forums
post #1 of 3 (permalink) Old 07-19-2002, 10:32 PM Thread Starter
Does LOWER hose have a coil spring in it?
bbird is offline
post #2 of 3 (permalink) Old 07-20-2002, 01:51 AM
4 Cam Bird's Avatar
Pretty sure it doesn't.
2011 CTS-V Wagon
4 Cam Bird is offline
post #3 of 3 (permalink) Old 07-20-2002, 07:36 PM
If you can, squeeze the hose. You should feel if it has one.
W.Cup is offline
