may have found a cheap way for people to get a drop in 2 core radiator cheap - TCCoA Forums
post #1 of 32 (permalink) Old 05-20-2004, 10:39 PM Thread Starter
On Probation
blown96bird's Avatar
I have herd that autozone caries a 2 core radiator for our cars so I had to check it out. I had them pull up the listings on a 95 v8 bird. They did not have a picture of it but they list 2 radiators for the v8. The first one it says single core for 148.99 and the second one it list for 259.99 but dose not list weather it is a double core. I would assume that it is since it has a seperate part number. The part number for the one that might be thicker at autozone is 432613
blown96bird is offline
post #2 of 32 (permalink) Old 05-21-2004, 01:41 AM
Moderator & Teksid Whore
guitar maestro's Avatar
wouldnt it still have the plastic side tanks though?
guitar maestro is offline
post #3 of 32 (permalink) Old 05-21-2004, 05:47 AM Thread Starter
On Probation
it would still have the plastic side tanks. 259 is lot cheaper than 530.00 for a griffin.
post #4 of 32 (permalink) Old 05-21-2004, 08:39 AM
The all aluminum Cobra radiator and shroud is a lot cheaper than $530, and is a sweet unit. It's thicker and has a much larger cooling area:
It has a six blade fan:
And when it's installed, it looks factory:
The only down side is that there is no trans cooler in the radiator, but the radiator trans coolers are weak and we normally suggest to everyone to get an outside cooler anyway... this would force you to do something that is an improvement anyway...
I am, and all the other guys I know that swapped them in are, very happy with the Cobra unit. They are thicker, but still thin enough to leave clearance for blowers and plumbing, if you have that on your mind.
What are the dimensions of the two different autozone choices. I ask that because Rockauto has replacement radiators ranging in price from $128 to $216 and none are "dual core"... they are all essentially OEM, one is just more expensive than the next...
Check to be sure the cheaper autozone rad has the trans cooler.. it appears that the cheaper Rockauto's may not.. it's hard to tell though...
But if that $259 rad is in fact a dual core... except for the plastic side tanks, it sounds like a winner..
-mike
96 GoldBird
N/A:
96 GoldBird is offline
post #5 of 32 (permalink) Old 05-21-2004, 09:50 AM
Jedi Master
mn12xr7's Avatar
does the 03 cobra radiator fit on the 5.0s and 3.8s??? How many CFMs does that e-fan blow? is it more than the mark viii fan??
-Orlando
mn12xr7 is offline
post #6 of 32 (permalink) Old 05-21-2004, 10:13 AM
Sorry, I can't answer those questions.. the only guy I know that swapped em on did on 4.6's..
You might try posting the 3.8 and 5.0 questions in the 5.0 and 3.8 Forums.. maybe someone has tried it there.
The Cobra has a 4.6 engine with 32 valves... so it's essentially the same as the 4.6 in our cars... Do the OEM 4.6 LX radiators swap into the 5.0 and 3.8??? if so, the Cobra should, I would think....
Can't answer that either, but Dan Newman might be able to give you the numbers. If they exist somewhere, he can probably find them..
Since they put that fan on the Cobra, and not the MK VIII fan, my instincts tell me that it probably blows at least as much... If it didn't why would they redesign and tool up for a part that wouldn't work as well.. especially in a high performance application... I also suppose it's a fitment issue.. the MK fan will probably not fit the Cobra radiator.. I know the LX fans won't without major fabrication and modification and then does not cover as much of the fin area because the LX cooling area is significantly smaller...
-mike
96 GoldBird
N/A:
post #7 of 32 (permalink) Old 05-21-2004, 12:43 PM
King Of Beers
Green95LX's Avatar
Send a message via AIM to Green95LX
Personally i don't see why the Cobra Rad wouldn't swap into a 94 up 3.8. Since it's not the motor that holds the radiator, it's the actual radiator mounts on the car. I doubt the mounts changed any between the 3.8/4.6
It's time to get the hell out of Dodge
A day late and a dollar short
"I never seen a T-Bird get rubber like that unless it was an SHO"
Green95LX is offline
post #8 of 32 (permalink) Old 05-21-2004, 12:53 PM
The Great Obucina's Avatar
im not sure what FoMoCo jacked up the price to on the 03 Cobra radiator, but I checked with radiator.com and they quoted me about 150$ for the radiator.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #9 of 32 (permalink) Old 05-21-2004, 01:08 PM
joseph
I think Scott, Chadg and I all lucked out, after that I don't know, either. I'll check to see if they are in the FRPP catalogue when I get home and see what the list is..
I rember I got the shroud for about $100 "back in the day" (like a last July)... you gotta get the shroud, too 'cause the stock won't work.. if they jacked the rad, they probably jacked the shroud too...
You need to get the plug for the harness too, but that's probably still not too bad.. Dan knows the PN, and I think I may have posted the wiring color codes, but if not I can get em... I think I have some pix of the wiring too...
-mike
96 GoldBird
N/A:
post #10 of 32 (permalink) Old 05-21-2004, 02:03 PM
I have done this swap as well, and it was a few months ago. This is the price for the rad., fan, and pigtail that I got from Dan-- $351.73 + shipping. I live in MO, so ground shipping wasn't much. Think I ended up at about $400~ish at the end. All in all, I have yet to see the temp needle go past the "O" in normal, and it usually sits between the N and O. It's been pretty hot and humid here the last few days, and I went out and ran it hard for a few miles (anywhere from 80-85mph), and all the time had the A/C on. I came into some standstill traffic, and sat for about 10 min. during that run. Needle never moved, and all I heard when I rolled down the window to check out the reason for being stopped, was the fan kicking on cooling her down. That fan seems to put out more air flow than the stock version. No proof tho, just looks lke steeper pitch on the blades. I'm happy w/ my upgrade, that and it looks pimp.
FordMan77 is offline
post #11 of 32 (permalink) Old 05-21-2004, 02:45 PM
Jedi Master
mn12xr7's Avatar
does any one know if it works on a 5.0 though???
-Orlando
mn12xr7 is offline
post #12 of 32 (permalink) Old 05-21-2004, 05:02 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
Almost 250K miles in the horrid heat down here,and I've never had the first problem with the plastic side tanks.I like the OE fitament of the replacement radiators personally,and do not like the idea of limiting myself to an external only trans cooler.
JL
Fuelly
Johnny Langton is offline
post #13 of 32 (permalink) Old 05-21-2004, 09:32 PM
JL
I had just replaced mine with an OE about 3 weeks before I put the Cobra rad in because my original cracked...
I actually pulled the new OE out and put the Cobra in 'cause my engine was running on the hot side and I thought the larger capacity and thicker and larger cooling area would help keep it cooler.. and it did.
And besides, I thought it looked really cool, and I needed validation to put Cobra badges on the side of my car, and I figured between the oil pump and the radiator, I qualified...
I absolutely agree that two trans coolers are better than one. After I found out about my thrust bearing getting destroyed, I read up a bit on the causes and conditions and the prevention of it happening again, and one of the things that was suggested was to run two coolers so that if one ever clogs, you can bypass it through the other cooler and prevent excess pressure and TC ballooning, which is one cause of thrust bearing failure... Obviously you have to check your in/out trans line pressure occasionally to determine if there is blockage....
-mike
96 GoldBird
N/A:
post #14 of 32 (permalink) Old 05-21-2004, 10:08 PM Thread Starter
On Probation
the best thing about this radiator if it has 2 cores is that you should be able to use your factory fan with out having to buy a cobra fan. I think that a stock tbird fan has 7 blades.
post #15 of 32 (permalink) Old 05-21-2004, 10:10 PM
AEDM8's Avatar
If you guys are really interested I have a cobra radiator and fan and a 3.8 radiator and fan in my garage. I can take pics and get measurments tomorrow for comparison.
AEDM8 is offline
post #16 of 32 (permalink) Old 05-21-2004, 11:54 PM
Banned/Duplicate Acct
JL
Then you're a lucky one
The avg life of a radiator with plastic tanks by any manufacturer is 95-110K before the tanks start leaking
I know ALL of my parents cars ranging from mercedes to toyota have proved this industry avg many times.
chadr is offline
post #17 of 32 (permalink) Old 05-23-2004, 06:35 PM
man i've got to stop replying to these threads....my OE radiator just took a crap this morning on my way to work.....so i had to buy the autozone one, because i can't afford any downtime at all......but needless to say, the cobra radiator is going in very soon, and the autozone junk is coming out
anyone need an autozone OE replacement radiator w/ less than 100 mi on it??
post #18 of 32 (permalink) Old 05-23-2004, 07:18 PM
Wife's '98 F-150=143K miles..no leaks
Friend's '94 Tbird=just over 100K miles...no leaks
Daughter's '95 Tbird=128K miles...no leaks
Maybe it's just proper maintenance that keeps them alive-but I doubt it.
JL
Fuelly
post #19 of 32 (permalink) Old 05-23-2004, 07:39 PM
JL
Ford Quality
chadr is offline
post #20 of 32 (permalink) Old 05-23-2004, 07:40 PM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
Put me down for a leaker, started in the winter...
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #21 of 32 (permalink) Old 05-23-2004, 08:09 PM
mercoug302's Avatar
JL
I've been through 2 in 145K miles. The first one lasted 89,000 miles, the second one lasted 50,000. Both were ford originals. Replaced it with the cobra rad and have been very happy so far. Maybe it's because you don't get super hot weather followed by super cold weather down 'thar in Texas.
The Cobra rad retails for 323.xx from the dealer, 325 in FRPP. But if the guys at the parts counter of your local dealer regularly greet you with "what are you forcing onto that car now?", you can probably get it for less than 250.00 (I paid 220.00 for mine).
1988 XR7
5.8L EFI, tremec 3550,spec stage III clutch,90mm L-MAF, TFS heads, GT40 intake, lunati cam,Fordchip.com,diablo chip 311rwhp 375 rwft/lbs.13.2 @107.2. with 3.08's
2004 Pontiac GTO LS1 6 speed black/red RIP
mercoug302 is offline
post #22 of 32 (permalink) Old 05-23-2004, 11:19 PM
TCCoA Founder
Sir William's Avatar
I had my radiator hot tanked and rodded at about 75,000. They put a very light bead of silicone around the plastic tanks when they put them back on. Since then my temps have been rock solid, and I've had no leaks whatsoever.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #23 of 32 (permalink) Old 05-23-2004, 11:19 PM
Overkill Fetish Freak
My tank leaked on my '87 Turbo coupe and the Cougar would do it if it was cold out. I'm very happy with the Cobra rad and I like the external cooler deal, in GA there is no need to warm up the blood and I'd rather not add any extra heat to the mix. With Cobra rad my ECT temps have never been an issue even when the roots was on the loose.
Dr. FrankenCougie is offline
post #24 of 32 (permalink) Old 10-02-2004, 02:12 PM
Well,I did a bit of checking on the 432613,and it's not what we want-It appears to be an SC radiator.
JL
Fuelly
post #25 of 32 (permalink) Old 10-03-2004, 09:16 PM
I agree with JL. I live in the hot and humid south. I have a 94 t-bird 4.6l with over 250,000 miles on it, never had a radiator problem or leak. My 97 bird w/4.6l has 110,00 mile, no problems either. I never really done much maint., just changed the coolant two or three times. So I can't even agree that it has to do with maintenance, since I did very little.
nitrotn97 is offline
post #26 of 32 (permalink) Old 10-03-2004, 09:36 PM
RIP Jake
Leland Jacobson's Avatar
at 193 K I flushed it for the second time in its life..... Its still goin strong...
Leland Jacobson is offline
post #27 of 32 (permalink) Old 10-08-2004, 09:38 AM
I've 305,000 miles.. original radiator..
no runs drips or errors.
average lifespan is usually "short" because "average" car owners dont perform proper routine maint.
Of course they all "say they do"... but in reality..
{shruggs)
FWIW: original engine, and tranny.
No Jmod, no 1-2 upgrade, no cooler
Ed note- I didn't want to put money into a tranny that I thought was going to die soon.. as luck would have it.. it's been running like a champ
{abliet a very SLOW champ}
1995 Lincoln Mark VIII "Grandmas Car"
400,480 miles *STOLEN 04-13-08*
98 Mark VIII LSC
STONE
STOCK
SLOW
NO
MODS
HERE
XLRVIII is offline
post #28 of 32 (permalink) Old 10-08-2004, 12:09 PM
RIP Jake
One must also consider thermal stress cycles the thing is exposed to.... In the south never , ok hardly ever... really cold , so your runn on a range of, say 35degrees to 190 degrees (Stock T-stat)not too many times a year, Alaska gets down to minus 50 more times a year, giving alaska a 240 degree range to the piddly range of 155 degrees experienced less often in Florida....gotta mean something???
post #29 of 32 (permalink) Old 10-08-2004, 02:15 PM
Draggin the Subframe
with Jesus now
RIP Buddy!
JoelBender's Avatar
My radiator only lasted 160k miles, and cracked inside in between the radiator, and tranny cooler, allowing water to get into my tranny, bye bye tranny..... didn't even realize it till the tranny started making whining noises, and by then it was too late.
Nothing like having a $120 part ruin a $500 + part....
The one, the only.........Bagged!.....Bottle Fed!......Thunderchicken!!
13.605 @ 99.46 & 13.608 @ 99.78 & 13.610 @ 101.72 on the bottle.
14.782 @ 94.46 at Cecil
14.792 @ 93.38 at Rockingham with new torque converter (2800 stall) 95% humidity, 82 degrees....
284.3 hp @ 4100 rpm, 370.4 ftlb @ 3600 rpm
Your friendly, run of the mill, Psychopathic moderator
NC Chapter Forum Carolina Thunder
TCCoA A-hole crew 2005 "DIASS"
JoelBender is offline
post #30 of 32 (permalink) Old 10-08-2004, 02:38 PM
mamberg's Avatar
JL
so what's the difference between a 2 row radiator and a 2 core radiator?
The statements in this post are my opinions only.
If you have a problem with them, please PM me
and keep the boards clear of flame wars.
_____________________________________________
mamberg is offline
