new t-bird engine - TCCoA Forums
post #1 of 33 (permalink) Old 05-20-2004, 11:01 PM Thread Starter
new t-bird engine
man, why couldn't Ford have given us T-Bird owners this kinda love back in the 90's?:
"An already efficient powertrain gets a boost in acceleration performance, with a 280-HP, 32-Valve DOHC engine. The optional Select Shift transmission allows for gear changes like a manual transmission without a clutch. The 32-valve 3.9L V8 has the free-breathing, high-output characteristics of four valves per cylinder, plus dual overhead camshaft design. Variable Cam Timing improves engine performance, fuel economy and power."
that is taken from the Ford site, this is the engine that's in the new T-Birds....an engine that creates WAY more power with less fuel....
maybe the next engine swap to be done? unfortunately, not by me don't have the $$$ or time to attempt something like that
95ThundaChik'n is offline
post #2 of 33 (permalink) Old 05-20-2004, 11:04 PM Thread Starter
and that "Select Shift" tranny is a 5-speed auto, too
post #3 of 33 (permalink) Old 05-21-2004, 08:50 AM
bah, that smaller than my V6 I'm building someone just built a naturally asperated 4.2L that made 265rwhp/280rwtq, had over 240rwtq from 2000-5500rpm and it was faily cheap to build, I would think that that 3.9L DOHC would be hard to squeese any more power out off also.
1996 Thunderbird LX 3.8L
-255rwhp 273rwtq-
-Vortech V1 S-trim [email protected], aftercooled-
-Built 4R70W W/3200rpm PI
1997 Lincoln Mark VIII LSC
-stock, stock, big dent, and more stock-
rancherlee is offline
post #4 of 33 (permalink) Old 05-21-2004, 09:34 AM
They did, but they named it: "Lincoln Mark VIII"
69 F100 LWB w/460 Engine
post #5 of 33 (permalink) Old 05-21-2004, 09:47 AM
Trumpeter Extraordinaire
IronChopz's Avatar
Originally posted by rancherlee
..... I would think that that 3.9L DOHC would be hard to squeese any more power out off also.
I'd agree, since the HP rating is at 6000 RPM.....I don't know anything about HP curves and whatnot, but max HP at that high an RMP seems unusable for the most part (how often is one driving with the engine revving that high?).
IronChopz is offline
post #6 of 33 (permalink) Old 05-21-2004, 10:14 AM
Boom.
Palmguy's Avatar
Max Torque: 286 ft-lbs @ 4000 RPM.
I would venture to guess it can handle itself just fine daily driving. Even if peak power is at 6k, it probably still can move alright in the middle RPM range.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #7 of 33 (permalink) Old 05-21-2004, 11:41 AM
FordFanatic's Avatar
i would have to say there is no replacement for displacement, ford should have given us a 5.8.
FordFanatic is offline
post #8 of 33 (permalink) Old 05-22-2004, 12:12 PM
copenkagan's Avatar
Send a message via AIM to copenkagan Send a message via Yahoo to copenkagan
I don't think we would have ever gotten a 5.8, myself. Chances are higher of maybe a 5.4.
2000 Mustang GT - 4R70W
214rwhp
263rwtq
More powerful now, but haven't gotten it on the dyno.
copenkagan is offline
post #9 of 33 (permalink) Old 05-22-2004, 01:41 PM
On Probation
blown96bird's Avatar
ford should have raised the belt and winow line of the car to accomoadate a 351. The bird should have never been offered with a 3.8. It should have come with a 302 with dual exhaust and 230 hp standard. It should have come with a sport insturment cluster and 4 wheel disk brakes, 16x7.5 wheels 235 60 16 H speed rated tires, 11.5 inch dual piston brakes, and a track lock rear end with 3.55s as standard equipment.
The supercoupe should have come with a built up 351 windsor with 300 hp, sport springs, high performance convetional shox, abs, heavy duity cooling , jbl audio system, sc body clading, and 17x8 wheels with 245 50 17 tires. The bird should have come with a 5 speed regardless if it was a lx or sc and a automatic should have been a 400.00 dollar option.
blown96bird is offline
post #10 of 33 (permalink) Old 05-22-2004, 09:18 PM
BB,
Call Ford and tell them what you just said. Tell then to scrap that new POS body for the Bird bring back the 94-95 body witha sleek NASCAR wing in the back and hail a new era and rebirth of the american Ford muscle car.
House
Fly Low, Fly Fast, Fly Ford Forever!!!
Stock 94 block, Richard M intake tube, C&L 73mm MAF, BBK 75mm TB, Port matched elbow, 9 in K&N in the fender well, Diablo chip, M8 flywheel and TQ, FOrd racing underdrive pullies, NGK plugs, FRPP 3:73, auburn limited slip diff, 2.5in exhaust from manifolds back into Dynamax SS mufflers.
MN12-Blackbird is offline
post #11 of 33 (permalink) Old 05-23-2004, 01:57 AM
Back in Black
ShadowDragon's Avatar
Yeah the one at work didn't lose to me too badly.
ShadowDragon is offline
post #12 of 33 (permalink) Old 05-23-2004, 07:08 AM
With the way gas prices are tending, I wouldn't mind at all if that hybrid engine that's goin into the Escape would swap into the t-bird. I hear it makes pretty good torque because of the electric motor... probably not a really fast engine, but hey 35 mpg wouldn't hurt
SloMo228 is offline
post #13 of 33 (permalink) Old 05-23-2004, 11:08 AM
JoeyICU's Avatar
yeah eltric motors make instant tq, its great, the civic hybrids are pretty cool in a 5spd, id own one, so if the escape gets one, id might look into that, b/c i like the escapes alot, sport, useful, and atractive, its been one of the most on ford made in a while
JoeyICU is offline
post #14 of 33 (permalink) Old 05-23-2004, 12:13 PM
Boom.
Palmguy's Avatar
It's not an if, it is happening, there is a Hybrid Escape that will hit showroom floors in about six or seven months.
TCCoA Gun Club
Palmguy is offline
post #15 of 33 (permalink) Old 05-23-2004, 08:20 PM
My sister has a 2003 T-Bird and has noticed that there is nothing more that can be done to the engine other than a supercharger to squeeze out any more HP. The car is very heavy because it is a convertible. Yes, the transmission is better than a stock 4R70W, but not worth the difference if you have a transmission shop custom build you a racing 4R70W with a trans-go kit and kevlar clutches and kolene reaction plates. I have blown my sister off the line quite a few times and she cannot even come close to beating me. Thus, Ford had a nice idea, but left no room for upgrades and modifications.
AED 9 PSI Supercharger, .30 over Forged Block with Manley H-Beam Rods & Pistons, Innovative West 10% Overdrive Crank Pulley, Thump RRR Tensioner Pulley, Cobra Crankshaft, BPE Racing Stage 2 Ported & Polished Heads, Crower Direct Replacement Cams, 70MM Throttle Body, MAC Cold Air Intake, 80 MM L-MAF, 38Lbs Injectors, JBA Ceramic Coated Headers, Metal Matrix Drive Shaft, Kevlar Clutch & Kolene Reaction Plate Transmission, True 2.5" Dual Magnaflow Exhaust (Cats & Mufflers), Griffin 1 1/4" Radiator, B&M Racing Trans Cooler, Hughes 2750 Stall Torque Converter, 3.73:1 Gears with Traction Lock Differential, Trans-Go Kit, Superchips Custom Tune for Supercharger, 17" SVT Wheels, Kenny Brown Suspension Enhancers & Eibrach Lowering Kit.
Wolverine27 is offline
post #16 of 33 (permalink) Old 05-23-2004, 08:31 PM
Boom.
Palmguy's Avatar
Their primary target audience, or at least the majority of people who buy those things, have no interest in modding them at all.
TCCoA Gun Club
Palmguy is offline
post #17 of 33 (permalink) Old 05-24-2004, 01:41 AM
Tinfoil hat wearer
azreael344's Avatar
Send a message via AIM to azreael344 Send a message via Yahoo to azreael344
I personally think the current design of thunderbird is ugly and overrated
1996 Laser red 4.6 V8.
Flowmaster catback, PI Intake, PI cams K&N 9 inch cone filter 80mm LMAF, Trickflow plenum, 75mm BBk throttle body,SCT Chip, Red FRPP wires, 22c plugs & 180* t-stat, PBR calipers, ASP underdrives. Marauder torque converter, FRPP 3.73 gears, Custom Drive shaft, Eibach Springs, Tokico shocks, JMOD, B&M 24k Tranny Cooler, Clear corners, 145mph Speedo,17X9 Cobra R's, Complete SC interior including SC Handbrake conversion
Best time [email protected] 93.18 MPH 4/16/2004
My other ride: 2001 F150 4x4
Aol screen name: Azreael344
azreael344 is offline
post #18 of 33 (permalink) Old 05-24-2004, 07:14 AM
JoeyICU's Avatar
yes sir, and a pitty to the name, im ok with the licoln LS's becuase there 4 doors and i think they look really good, but i dont know if im a big fan of the 3.9L. im sure you could get some more power out of the engines, its only puting 250hp to the crank, nissan puts 280 hp to the crank of there 3.5L v6, i doubt its like a honda s2000, where if you put any mods on it, it will not gain any power
JoeyICU is offline
post #19 of 33 (permalink) Old 05-24-2004, 07:17 AM
The design should have never changed from the 94. IMO.
post #20 of 33 (permalink) Old 05-24-2004, 10:32 AM
Boom.
Palmguy's Avatar
2003+ 3.9L engines are up to 280 bhp.
TCCoA Gun Club
Palmguy is offline
post #21 of 33 (permalink) Old 05-24-2004, 10:22 PM
JoeyICU's Avatar
hmm, think more power could be made out of them, 280hp, why is everyone raging on the 3.9s thats alot, i thought they were still on 252hp, i wonder how much hp can be mad with that cammer small small v8
JoeyICU is offline
post #22 of 33 (permalink) Old 05-25-2004, 12:07 AM Thread Starter
mainly what i was trying to get across when i posted this is the fact that the engines make a lot more power, while using less fuel. i'm sure the engine and tranny would probably perform better if it was not in the newer body style, and were in our older and (somewhat) lighter body styles (hence my original post about them giving us this kinda stuff back in the 90's).
for a lot of people that drive our cars, they don't really care about turning their car into a 'vette killer or anything, they just want a nice looking car that rides good and has decent power. i'd take a 280HP engine that uses less gas over our current 4.6L engine, and maybe just slap on an SC, good exhaust, and other minor mods, and be totally happy with it, as would a lot of others. 286 Torque at 4k RPM stock is not too shabby....and throw in some better gears and a chip on top of the other things listed above, and it's not looking too bad at all.
true, you can probably get more power out of a 4.6L right now.....but give it some time, and i'm sure someone will figure out a way to get more power out of a 3.9L as well. also, think of it this way: smaller engine = less room being taken up in the engine compartment = easier to do a single, or even double turbo setup.
post #23 of 33 (permalink) Old 05-25-2004, 12:19 AM
at least Ford kept it a v8 and rwd look what chevy did to the impala, monte carlo, malibu etc.... but its a little to small for me
'95 4.6
'89 3.8
89BRD is offline
post #24 of 33 (permalink) Old 05-26-2004, 10:19 AM
Some where I read about a concept bird with a blown 3.9. If forgot the exact numbers, but I am thinking it was in the mid to high 300's. I am pretty sure that this concept is going to stay a concept and nothing more.
-Brian
TbirdJLcustom is offline
post #25 of 33 (permalink) Old 05-26-2004, 10:22 AM
Back in Black
Saleen had one.
I'm not sure if Chip Foose's was SC'd or not, it was at WFC6 in the Ford Racing tent.
http://www.mn12tbird.com/meets/wfc6/wfc091.jpg
http://www.mn12tbird.com/meets/wfc6/wfc092.jpg
post #26 of 33 (permalink) Old 05-26-2004, 11:09 AM
she's perdy.
post #27 of 33 (permalink) Old 05-26-2004, 11:14 AM
yeah but that is a FOOSEone of a kind.
post #28 of 33 (permalink) Old 05-26-2004, 11:28 AM
mamberg's Avatar
what is the supercharged motor (3.9 or 4.0L) in the new shelby cobra? Fastest current production sportscar. Something like 3.2 seconds 0-60.
mamberg is offline
post #29 of 33 (permalink) Old 05-26-2004, 11:30 AM
Try 5.0L.
post #30 of 33 (permalink) Old 05-26-2004, 11:46 AM
mamberg's Avatar
I meant this one , but trying to read between the lines, I think it is the Olds/Northstar 4.0L engine with a supercharger, but I am not sure.
Fast car in either case..................
mamberg is offline
