99+ Airbox connected to the stock MAF? - TCCoA Forums
post #1 of 4 (permalink) Old 05-25-2004, 12:19 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
Is it even possible? If so how did you do it?
I got the airbox laying around my room for when I go to get my 02 GT Maf, but I want to put it to use now if possible. I broke my plexiglass heat sheild and don't feel like making a new one.
Thanks!
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #2 of 4 (permalink) Old 05-25-2004, 08:51 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
The stock MAF doesn't use the 4 bolt flange that the airbox does. Good luck...
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #3 of 4 (permalink) Old 07-31-2004, 08:43 PM
BirdofPrey97's Avatar
I just took the back housing of the air box and removed it. Took a piece of card board and cut it to the correct size to replace the original housing. Reason I couldnt use the factory housing was because it wasn't deep enough to allow me to use my K&N cone filter. That's what allowed me to use this box without a more current MAF.
Won't be doing the tune until next Spring, so figured this would last me the 2 months left that I can drive it. Also cut a whole in cardboard to fit the air temp sensor into it. No, it's not air tight and it's not perfect, but it will work. Good old duct tape to the rescue.
Maybe I have been watching to many Red Green shows living up north now?!?!?!?!?
The key is to get a cone filter and use it in place of your factory one. Do I think the cone filter is better or not? Doesn't matter what I think, its what will work with the setup for now where a stock one will not. The cone slides right onto the MAF.
Give it a shot or just say I am nuts doesn't matter just what I am trying. Hope this helps.
Honor, Grace, and Dignity.....Do you remember these?
BirdofPrey97 is offline
post #4 of 4 (permalink) Old 08-02-2004, 04:54 PM
Steve 4.6L's Avatar
Cardboard and duct-tape.........
You should sell this as a mod on the for sale forum.
Just kidding, I couldn't resist!!!!!
I have done some strange modifications to get by as well..
Just dont get it wet
Steve 4.6L
1996 Thunderbird 4.6L
Vortech S/C at 9psi boost
Steve 4.6L is offline
