Replacing ignition cables - TCCoA Forums
post #1 of 4 (permalink) Old 05-26-2004, 07:01 PM Thread Starter
I am going to be installing new OEM ignition cables soon on my 1997 4.6. Two questions:
Can the cables be routed under the alternator without removing it?
Is it possible and/or advisable to run the cables over the alternator?
Thank you.
Last of Breed is offline
post #2 of 4 (permalink) Old 05-26-2004, 07:18 PM
Matt C's Avatar
You can route them under the alternator without removing it. I did it that way once, but it was a real pain. I had to use long pliers to pull the wires out the other side. It would have been faster to remove the alternator.
You can also route them above the alternator. After my intake cracked that is how Ford set it up. They had a bracket that bolted to the intake to route the wires. I'm not sure if that bracket will bolt up to the original intake though.
1997 LX Sport..Eibachs & KYBs...245/50s on Eagle Alloy 16x7s...SC rear sway bar...94 SC seats...Mark VIII ds...SCT tuned by Lasotta Racing ...Dirty Dog Marauder converter... Trans by Supergordo
Matt C is offline
post #3 of 4 (permalink) Old 05-26-2004, 09:16 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
over the alt is fine. thats how i did mine cuz i was to lazy to remove the belt and alt just to run wires.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #4 of 4 (permalink) Old 05-26-2004, 09:22 PM
Back in Black
ShadowDragon's Avatar
Only the updated intake has the holes to mount it. I got creative and zip tied it to a 94 aluminum intake though. I got tired of squeezing my hands through to feed the boots (had no problems doing it without pliers though)
ShadowDragon is offline
