Somthing is up with my bird - TCCoA Forums
post #1 of 9 (permalink) Old 05-30-2004, 02:34 PM Thread Starter
Well the swap is done... still dont know what the problem is... The one head heats up a ton and the other doesnt...
http://www.eriespeed.com/tommymotor.wmv
Any idea's anyone?
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #2 of 9 (permalink) Old 05-30-2004, 02:47 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
Does the car feel like it has power if you rev it or does it feel like your at a loss for power?
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #3 of 9 (permalink) Old 05-30-2004, 03:09 PM Thread Starter
car has zero power
2004 F150
KrAzyT is offline
post #4 of 9 (permalink) Old 05-30-2004, 04:25 PM
Tx_Cat's Avatar
I think you have a busted head man. You made sure that the timming was OK, all gaskets and everything and you still have problems??? Must be the head
Tx_Cat is offline
post #5 of 9 (permalink) Old 05-30-2004, 04:29 PM
MattsLE97's Avatar
yup thats what i thought it might be. There is something screwed up in the head and probably by the way it sounds there is something not sealed correctly and my guess its the head.
post #6 of 9 (permalink) Old 05-30-2004, 04:30 PM
MattsLE97's Avatar
Or the exhaust header (sorry just thought of this )
post #7 of 9 (permalink) Old 05-30-2004, 07:25 PM
Tx_Cat's Avatar
No, it's not the header. Even if the header was on the engine, it would make a loud sound, even higher than the one he has right now. Krazy, if I were you, I would take off the busted head and take it to a machine shop, they can tell you if it's busted or not. For me, that has to be the problem. Even if the timing waa off, you would still have SOME power.
Tx_Cat is offline
post #8 of 9 (permalink) Old 05-30-2004, 07:33 PM
chunk's Avatar
Agreed, I'd have them clean and magnaflux the head to see if a crack has formed.
While your at it check the the coolant passages something might be blocking them.
Do you have good compression on that side on all cylinders, that would also give you an idea of weather the timing is off.
Just some thoughts
95 T-BIRD
74 F250 HIGHBOY
66-68 FALCON
87 AUDI 4000S
89 SUZUKI LT500R (QUADZILLA)
chunk is offline
post #9 of 9 (permalink) Old 05-30-2004, 10:28 PM
MattsLE97's Avatar
the reason i thought it could possibly be a leak in the header is because you can hear the pistons which in turn could be a crack somewere in the head and loss of compression. Have you done a compression test on each cylinder on that head?? I didnt mean there could be a bad header i meant there might be a leak in that general vasinity I hope you find out what it is man.
