FRPP Oil Pump question - TCCoA Forums
post #1 of 3 (permalink) Old 05-30-2004, 08:38 PM Thread Starter
fsh167's Avatar
Question FRPP Oil Pump question
I just finished a lengthy search, but came up empty-handed...
I'm in the process of getting my 02 Explorer engine ready to drop in soon. I just installed the FRPP oil pump on the engine which is on an engine stand (old motor still in car).
My question is: Will the pick up tube for the high volume pump clear my Tbird's stock oil pan? Or do I need to get a Mark VIII pan/tube?? It doesn't clear the Explorer pan, that's why I'm asking.
Thanks in advance for advice from someone who has done this.
Frank
Moonlight Blue 97 4.6L TBird
02 Explorer 4.6L w/ VT Stage II cams
C&L Plenum w/ Accufab 75MM TB
02 Mustang Mass Air, SCT Tune
Custom Duals w/Magnaflow mid-mounted
Marauder TC - "J-Modded" 00 Mustang GT trans
4.10 gears; Eibach springs; PBR Calipers; 03 Cobra wheels
Best time: 14.03 @ 99.40 MPH
fsh167 is offline
post #2 of 3 (permalink) Old 05-31-2004, 09:11 AM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
Frank
The pickup tube that is used on the Mustang will not clear your pan-you'll have to use the '97-'98 Mark 8 tube for that pump,and it will clear your TBird pan.
Beware of the powdered metal pump gears....they commonly fail,and when they do-there's a chance you'll destroy the engine.
Worth the $275 for insurance against breaking the Explorer engine.
JL
Fuelly
Johnny Langton is offline
post #3 of 3 (permalink) Old 05-31-2004, 04:57 PM Thread Starter
fsh167's Avatar
Thanks a lot for the info/advice Johnny!!
fsh167 is offline
