Diagnostic port: No power??? - TCCoA Forums
post #1 of 10 (permalink) Old 06-02-2004, 11:39 PM Thread Starter
Jealous?'s Avatar
Send a message via MSN to Jealous?
Ok, I hooked up two seperate fully-functioning code scanners to my OBDII port and nothing happened. No power, no nothing. Does it have its own fuse or something that I don't know about????
Now I'm in Florida....
Jealous? is offline
post #2 of 10 (permalink) Old 06-03-2004, 09:57 AM
girdnerg's Avatar
Did you turn the ignition to on?
At the zone they hook up the scanner then have me turn the igntion on without starting the car.
Hope this helps
Rob
girdnerg is offline
post #3 of 10 (permalink) Old 06-03-2004, 09:14 PM Thread Starter
Jealous?'s Avatar
yeah, KOEO. No signal, no power, no nothing.
What do ya think? I could really use some help!
Jealous? is offline
post #4 of 10 (permalink) Old 06-03-2004, 10:43 PM
mine needs the engine to be running to scan codes.
97 Mark VIII LSC yeah
08 Ford Edge, white for now
modbird is offline
post #5 of 10 (permalink) Old 06-04-2004, 03:08 AM
Sweet T
SanDiegoLXBird's Avatar
Turn the key to the on position before plugging the scanner in.
I had a similar problem with one of the $5000 dollar scanners at my work. I pluged it in before I turned the key to "on". Turned the key off, unplugged the scanner, turned the key on, plugged the scanner in.. everything was fine.
SanDiegoLXBird is offline
post #6 of 10 (permalink) Old 06-04-2004, 05:47 PM Thread Starter
Jealous?'s Avatar
OK, cool. I'll try that in the morning!
Jealous? is offline
post #7 of 10 (permalink) Old 06-05-2004, 05:16 AM
W&S Motorsports
The OBDII port should have power on at all times 4 GND and 16 VPWR. It is fused by a 10A fuse in the fuse box near the steering column.
Winston is offline
post #8 of 10 (permalink) Old 06-05-2004, 07:25 AM
clean it
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #9 of 10 (permalink) Old 06-05-2004, 01:34 PM
ITT-BIRD's Avatar
Id check them all just to be sure ... probable will find that one burnt but every now and then you may find one other that is too.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #10 of 10 (permalink) Old 06-05-2004, 09:16 PM Thread Starter
Jealous?'s Avatar
I tried it with the key on first, then plugging it in. But...NO GO.
I guess I'll try to find that fuse, what's it labeled as?
Cleaning and testing will be after that...I'll get back to ya!!!
Jealous? is offline
