Humming from front - TCCoA Forums
post #1 of 11 (permalink) Old 06-06-2004, 03:14 PM Thread Starter
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
Humming from front
Guys in the last 2 or 3 days i have noticed a humming comming from the front right part of my car. I know its not the wheel bearing because it does it when i'm stopped and it gets pretty loud then all of a sudden goes away. Any thoughts??
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #2 of 11 (permalink) Old 06-06-2004, 04:03 PM
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
i have the same problem. somebody explained to me what it was a while back, but i forgot. It gets pretty loud, but as far as i know, its not causing any damage
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
post #3 of 11 (permalink) Old 06-06-2004, 04:26 PM Thread Starter
MattsLE97's Avatar
Ya it got real loud this morning on my way home from work. I thought it might be the alternator or something but when i'm stopped it was doing it and my engine almost seemed like it was running rough
post #4 of 11 (permalink) Old 06-06-2004, 06:39 PM
BlownSix's Avatar
Send a message via MSN to BlownSix Send a message via Yahoo to BlownSix
Hey I have the same humming noise and I was told by people on here that it was the IAC valve (Idle Air Control I believe) was going bad. It would make my car stall out if I was stopped. I haven't changed it yet though.
Black '94 SC 5-Speed
BlownSix is offline
post #5 of 11 (permalink) Old 06-06-2004, 07:29 PM Thread Starter
MattsLE97's Avatar
Ya i remember reading about that a couple days ago. When yours humms is it pretty loud and does it stop after about 10-15 secs??
post #6 of 11 (permalink) Old 06-06-2004, 08:07 PM
BlownSix's Avatar
Sometimes it does. Like it's hummed for a few seconds and stopped, it's hummed for a few seconds until I've given it some gas, and it's hummed and I've waited to see what would happen and it would stall out.
BlownSix is offline
post #7 of 11 (permalink) Old 06-06-2004, 08:29 PM Thread Starter
MattsLE97's Avatar
Were exactly is this IAC valve i was looking and on the drivers side of the tb the one sensor that is on the tb is the TPS correct?? Were from the there is the IAC valve?
post #8 of 11 (permalink) Old 06-06-2004, 11:35 PM
TSB# Date Diagnosis
94224 OCT 94 Idle Air Bypass Valve - Noise Or Moan
There is an updated piece you can grab from Ford to replace your current one on your 4.6.
Derek is offline
post #9 of 11 (permalink) Old 06-07-2004, 05:17 AM Thread Starter
MattsLE97's Avatar
ok cool thanks derek but does someone know exactly were it is?
post #10 of 11 (permalink) Old 06-07-2004, 06:35 AM
Josh's Avatar
Send a message via AIM to Josh
mine has done it like twice in the last year..I just gave it some gas and it went away...but it is pretty loud.
  • My birdy pics: 1.2.3.4
  • AIM: SouthernSportmen
  • 4.6L 94LX T-Bird
  • MODS: New Motor, Rebuilt Modified tranny, Modified MAF,
    Removed air resonator, Autolite wires,
    Cobra R Hood,97 Headlight conversion,
    Hella driving lights
Josh is offline
post #11 of 11 (permalink) Old 06-08-2004, 07:13 PM Thread Starter
MattsLE97's Avatar
guys i was looking under the hood of my car and that noise kicked in dang is that loud. It is loudest by my filter. Its comming from the tb probably were that valve is but i still cannot find it can anyone point me in the right direction of were it is i looked in the haynes manual and it doesnt show it well
