02 gt tube on 94-95 - TCCoA Forums
post #1 of 60 (permalink) Old 06-06-2004, 04:12 PM Thread Starter
Iowa Chapter Director
Uber Luber
Thomas's Avatar
02 gt tube on 94-95
Just thought I'd let everyone in on how to do this if anyone is interested in doing it. I bought an 02 Mustang GT intake tube from Dan for 20 something dollars shipped. With the help of Brian I was able to do this and thought it might be helpful to just post it so everyone can see how it's done.
-First, you cut the tube in half right between the two vacuum hose connections. It's easy to do, you just go along the side of the raised ridge all the way around. Flip on end of the tube over.
-Cut off the vacuum connection on the tb side of the tube (the one without the plastic insert). cut it flush with the surface of the tube.
-Cut a 3" aluminum pipe about 7-8" long and cut one end at an angle. Stick the end with the angle in the tb side of the tube and put the angle in such a way that it blocks off that hole from the connection that used to be there. put the other end of the pipe in the other piece of tube and clamp both sides down tight. You can see from my pics that the hole is not clamped off, but it's tightly pressed against that aluminum pipe and it won't leak at all.
-cut a piece of 3" aluminum pipe about 2" long and stick it in the hole where the throttle body would normally go, then take the piece off the stock violin case that has the hose connection and clamp it on top of the end of the tube. The aluminum pipe will provide a hard material for clamping force.
-Now you've got a tube that will route correctly for the 94-95 and will fit upto a 90mm LMAF on the end. Believe me the 90 fits. It took about half an hour to squeeze that dang thing on there but it fits nicely. Here are the pics.
**the piece from the violin case isn't pictured because it's still on my violin case on the motor. I'm waiting for my apten chip to run the 90 LMAF.**
-Thomas
Thomas is offline
post #2 of 60 (permalink) Old 06-06-2004, 07:12 PM
Rich95XR7's Avatar
Send a message via Yahoo to Rich95XR7
You just need to paint or powdercoat the exhaust tubing black to make it look good in there. I might give that a try next time I see my car.
Rich95XR7 is offline
post #3 of 60 (permalink) Old 06-06-2004, 08:11 PM
Back in Black
ShadowDragon's Avatar
ShadowDragon is offline
post #4 of 60 (permalink) Old 06-06-2004, 09:37 PM Thread Starter
Uber Luber
Thomas's Avatar
Yeah I've got some matte black bumper paint that's real durable and I'm going to paint the tube with that when I get the chance.
-Thomas
Thomas is offline
post #5 of 60 (permalink) Old 06-07-2004, 06:28 AM
Send a message via AIM to jjjustin17 Send a message via Yahoo to jjjustin17
i used a 96 t bird tube turned backwards and it almost fit perfect had to add like 2 inches is all.
green 95 thunderbird lx 4.6
mods-- clear corners, k & n filter, lebra, 97 intake tube. flowmasters.
mods to install-- saleen wing, sc side skirts. hopefulls-- new heads, intake, sc rear bumper, cowl hood, cobra r's, lower the car,
jjjustin17 is offline
post #6 of 60 (permalink) Old 09-24-2004, 09:27 AM
Back in Black
For the breather tube,
1/2" ID Elbow
5/8" ID Heater hose
The 96-97 bird and the 99+stang are identical except for the size of the MAF outlet. 96-97 bird works fine for stock MAF, but those of us who went to larger have to use the 99+ stang one. Even the 96-97 boys do a direct swap to the 99+ tube when upgrading their MAF.
post #7 of 60 (permalink) Old 09-26-2004, 11:16 PM Thread Starter
Uber Luber
Thomas's Avatar
my pcv hose went straight into the connection on the GT tube. No modification required.
-Thomas
Thomas is offline
post #8 of 60 (permalink) Old 09-27-2004, 07:40 AM
Back in Black
Mine did too until I broke it but some people are having problems with it so I thought I would help them out.
post #9 of 60 (permalink) Old 10-05-2004, 02:26 PM
CEO Red Sox Nation
DMcBrideBoston's Avatar
Originally posted by Thomas
[Bcut a piece of 3" aluminum pipe about 2" long and stick it in the hole where the throttle body would normally go, then take the piece off the stock violin case that has the hose connection and clamp it on top of the end of the tube. The aluminum pipe will provide a hard material for clamping force. [/B]
I am doing this part now, and holy ballz this isn't easy. fitting a 3" pipe into a 3" tube isn't that easy! but I got it after shaving a bnit of the inside of the tube with an exacto knife.
Also, this is alot more tough if you are using a STB, I have no idea how I am gonna manuever around that JL brace, it's huge!
PS this sucks...
Dave
2003 Infiniti G35 Sport Package with Navigation
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
DMcBrideBoston is offline
post #10 of 60 (permalink) Old 10-05-2004, 02:33 PM
Back in Black
It's just like a virgin, it's tight but it does stretch.
post #11 of 60 (permalink) Old 10-05-2004, 02:50 PM
CEO Red Sox Nation
Hey Shadow, I ran into another kink.....Can you help? I have my zex box mounted into the side of the engine bay where the airbox goes. With my Tbird K&N I have no fitment issues. NOw while trying to use the mustang GT airbox, I have run into a snag. It doesn't fit. Can I cut off the two mounting bolt hole things on the side? And would I have problems if the hole in the airbox is kinda facing the zexbox? Would I have many airflow issues?
problem is I need a kind of quick fix, I have to work tomorrow night, and I have no extra money until Friday to buy a Mustang K&N, if I need to, I don't wanna if I dont have to.
Dave
post #12 of 60 (permalink) Old 10-05-2004, 02:56 PM
Back in Black
I just used my stock airbox and flipped the rubber connector around backwards. (usually goes from big to small, I made it go from small to big.. Very tight fit, but works.) Of course I used an accufab adapter too. I know the GT Box needs to be slightly modified to fit well but I don't know what "bolt hole things on the side" you are talking about, pics would help. If I remember right the method I've heard was to cut off some of the snout of the box to get it to fit into the hole into the fender.
post #13 of 60 (permalink) Old 10-05-2004, 04:06 PM
CEO Red Sox Nation
I just stopped dealing with the airbox for now and I am trying to finish the 02 GT Mass Air wiring. This intake tube is jerry rigged like a mutha......
I need to get this PI intake on badly or buy a 96.......I'm sick of fabbing #hit up!
Thanks SD
Dave
post #14 of 60 (permalink) Old 10-05-2004, 04:08 PM
Back in Black
You and me both buddy.
post #15 of 60 (permalink) Old 10-05-2004, 10:37 PM Thread Starter
Uber Luber
Thomas's Avatar
whitecoug has an 02 gt box and his zex solenoid sits right underneath it on the side cosest to the shock tower. You can't even see it as it sits right underneath the box. Very sleeper-like.
-Thomas
Thomas is offline
post #16 of 60 (permalink) Old 10-05-2004, 11:37 PM
whitecoug's Avatar
Send a message via AIM to whitecoug
whtiecoug has an 02 gt box and his zex solenoid sits right underneath it on the side cosest to the shock tower. You can't even see it as it sits right underneath the box. Very sleeper-like.
-Thomas
Just going to say that...but somebody beat me to it...If you point the rubber hosse side angled towards the motor and the feed line from the front pass. corner it should fit ok. i could only use 3 screws though, but it ain't going anywhere. and yes, you can only see the purple from about one angle...i need to paint it white and cover it with dirt to match the rest of my car
1994 Mercury Cougar XR7 4.6L Special Edition
PnP'd NPIs, PI Cams, PI intake, 80mm GT MAF, 24# Injectors, Shorty Headers, SCT Tuned, Jmod, Trans Cooler, 3.73's, Underdrives, Zex Dry kit 75 shot, Dirtydog TC, Trans built by Darrin, 97 Cupholders
219 RWHP/256 RWTQ NA
280 RWHP/343 RWTQ Bottle Fed (75 shot)
[email protected] mph 5/20/06
I feel sorry for the people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day.
whitecoug is offline
post #17 of 60 (permalink) Old 10-06-2004, 11:29 AM
CEO Red Sox Nation
Well, I just got up and I am going to finish this jerry rigged project today. This PI intake needs to go on with the quickness. I'm gonna get some funny looks at my dyno tune on Saturday
94-95's officially suck in my book!(stock)
Thanks whitecoug and Thomas.....I'll give it a whirl.
Dave
post #18 of 60 (permalink) Old 10-06-2004, 12:04 PM
CEO Red Sox Nation
OH yeah.....
SD, how did you make the 1/2" ID elbow or did you buy it that way, I need to find something for the DS breather....
Dave
post #19 of 60 (permalink) Old 10-06-2004, 12:10 PM
Back in Black
I bought it that way. I got it in the PCV section of Pep Boys. It's practically identical to what's in the drivers side head, btw just without the "pin" to keep it from moving, so that's probably what it was intended for.
post #20 of 60 (permalink) Old 10-06-2004, 12:53 PM
CEO Red Sox Nation
Thanks SHadow....Is it for any particular vehicle or just something that looks like it?
I just finished up the wiring for the mass air, now to put stuff together to look good....
BTW: can I drive without the breather for 10 or 15 minutes to the parts store, or is that bad....
Dave
post #21 of 60 (permalink) Old 10-06-2004, 12:57 PM
Back in Black
It's a generic part. Just find something 1/2" ID that makes a 90* bend. lol The heater hose is just slightly bigger (5/8" ID) so that makes it easy to get the tube on, it is still quite a tight fit. I wasn't able to pull it off to take a picture so just included the hose.
It'll be okay for a little while but I would put some tape over the hole in the airtube itself for the trip. And don't forget the small hose clamps!
post #22 of 60 (permalink) Old 10-06-2004, 01:01 PM
CEO Red Sox Nation
Gotcha thanks...
Dave
post #23 of 60 (permalink) Old 10-06-2004, 06:57 PM
CEO Red Sox Nation
SD...I found that stuff with no problemsa and I connected it, but how did you keep the elbow inside the GT tube, I cant see where a hose clamp would work. For tonite, I used electrical tape to secure it to the tube.
How'd you do it?
BTW: throttle response with the 02 MAF and a 3" intake tube is sikkk....Car is alot more reponsive.
Dave
post #24 of 60 (permalink) Old 10-06-2004, 07:01 PM
Back in Black
I used a hose clamp, you can see it in my top pic.
post #25 of 60 (permalink) Old 10-07-2004, 04:00 AM
CEO Red Sox Nation
Thanks SD you've been a major help. Preciate it!
Dave
THis should be in the new tech articles, alot more clean cut, but should definetly be in there.
post #26 of 60 (permalink) Old 10-07-2004, 11:04 AM Thread Starter
Uber Luber
Thomas's Avatar
I put it in the Work In Progess forum, but I will try and find time to add SD's info to it sometime here.
-Thomas
Thomas is offline
post #27 of 60 (permalink) Old 10-07-2004, 11:17 AM
jk69cat's Avatar
i am going to try to do this on my parents 95 vicky too . i have always hated the violin case . its always in the da** way ! it needs a little help too . so im going try.
mn12 less!
jk69cat is offline
post #28 of 60 (permalink) Old 10-07-2004, 01:49 PM
Back in Black
Keep in mind that while the intake tube is reversed on the CV, the PCV system is still set up the same way ours is.
post #29 of 60 (permalink) Old 10-07-2004, 02:11 PM
jk69cat's Avatar
sd, i figured as much. i already got the tube . got it in this morning. just neeed the metal tube
mn12 less!
jk69cat is offline
post #30 of 60 (permalink) Old 10-07-2004, 02:14 PM
Back in Black
The thing is, you still need to have the pcv feeder tube come off the right side (looking from the front) unless you want to loop it all the way around the engine (don't want to kink it). Or maybe two elbows and two lengths of tubing. Just make sure you take that into account, the directions won't be exactly the same.
If you can get it to fit to the airbox fine just don't flip either piece of rubber over, just cut and place the metal tube between them so it keeps the bend going to the right and the hose connection there too.
