12C plug life expectancy - TCCoA Forums
post #1 of 5 (permalink) Old 06-08-2004, 02:32 PM Thread Starter
4 Cam Bird's Avatar
My highway milage seems lower than normal. It has since last fall, since right around the time my car also ran its slowest 1/4 times since I put in my gears. So, I just finally put 2 and 2 together and decided taht maybe its the plugs although I haven't checked them yet. They've only been in there for about 20k miles though. What is anyone else experience with the 12C plugs? Are they normally pretty short lived?
2011 CTS-V Wagon
4 Cam Bird is offline
post #2 of 5 (permalink) Old 06-08-2004, 07:19 PM
Refrigerator Raider Hater
GreenBird's Avatar
Only way to tell is to take them out. Once you read the plug, it will tell you the complete story.
I would be ready to replace them. For some reason 10K comes to mind for coppers.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 5 (permalink) Old 06-08-2004, 09:50 PM Thread Starter
4 Cam Bird's Avatar
10k miles was mentioned on md also. I am in the process of getting new plugs. I am kind of relieved that I think I have figured out the performance problem and milage drop, I just don't know why it took me as long as it did to think of it.
2011 CTS-V Wagon
post #4 of 5 (permalink) Old 06-08-2004, 10:18 PM
JoeyICU's Avatar
i checked the ford serivce manual, couldnt find anything, id replace my plugs in the range of 10-20k, if you wanna be extra good to your engine, every 10k
JoeyICU is offline
post #5 of 5 (permalink) Old 06-08-2004, 11:40 PM Thread Starter
4 Cam Bird's Avatar
Yeah, I'll probably replace them a little more often in the future. Didn't realize that the life span was that short or the performance/mileage drop off as high as it is.
2011 CTS-V Wagon
