Fuel injectors - TCCoA Forums
post #1 of 3 (permalink) Old 06-08-2004, 10:36 PM Thread Starter
FoMoCoSVT's Avatar
Send a message via AIM to FoMoCoSVT
Fuel injectors
How many pounds? and what kind of fuel pump? 95 4.6 DOHC......will be SCing.
FoMoCoSVT is offline
post #2 of 3 (permalink) Old 06-09-2004, 01:58 AM
Slowride's Avatar
Send a message via Yahoo to Slowride
I'm thinking you could get by with 24's........but 30 or 36's would be better way to go.
The early bird may get the worm, but the second mouse gets the cheese!!!
Slowride is offline
post #3 of 3 (permalink) Old 06-09-2004, 06:13 AM
What are your HP goals? That will determine what you need. It won't hurt to have more pump than you need, but you want to use the smallest injectors you can get away with to keep them operating in the 80% duty cycle range.
19# injectors support around 300 hp at the crank, 42# injectors support around 560 crank hp.
Here are the calculators, plug in the numbers.
-mike
96 GoldBird
N/A:
96 GoldBird is offline
