Subtle Problems... - TCCoA Forums
post #1 of 20 (permalink) Old 06-09-2004, 08:54 AM Thread Starter
Boom.
Palmguy's Avatar
Subtle Problems...
Well I am not quite sure if something is wrong or if it is all in my mind...
My exhaust has a fairly rich smell, it smells like I've got unburnt fuel coming out. The passenger side also has a different sound to it, since I have true duals now I know that that sound is thus coming from the passenger side bank. There is an audible pulse that is coming from that side that sounds like it shouldn't be there.
For starters, the hose coming from the top exit on the PCV is cracked all to hell, needs to be replaced. The second port on the PCV has nothing attached to it, and I'm not sure why. Plugs are 22Cs that were just installed two weeks ago, gapped to .060. New Motorcraft plug wires as well, also two weeks old. I don't believe the symptoms are a new condition necessarily, i.e. since the new plugs/wires.
My first thought was a bad injector or EEC, but I'm not pouring fuel out of the tailpipes. Regardless, I'm going to test with a noid light today and see where that gets me.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #2 of 20 (permalink) Old 06-09-2004, 09:08 AM
Palm,
Greetings. I too am having the same same symptoms. I am catless so I think this might be a cause. Are you running cats?
House
Fly Low, Fly Fast, Fly Ford Forever!!!
Stock 94 block, Richard M intake tube, C&L 73mm MAF, BBK 75mm TB, Port matched elbow, 9 in K&N in the fender well, Diablo chip, M8 flywheel and TQ, FOrd racing underdrive pullies, NGK plugs, FRPP 3:73, auburn limited slip diff, 2.5in exhaust from manifolds back into Dynamax SS mufflers.
MN12-Blackbird is offline
post #3 of 20 (permalink) Old 06-09-2004, 09:17 AM
B,
I was also looking at your signature, is that time and speed correct? You ran a 15.6 @ 90. What happened? Bad track or was that before the engine swap?
House
post #4 of 20 (permalink) Old 06-09-2004, 09:29 AM Thread Starter
Boom.
Palmguy's Avatar
I have the two cats coming off the manifolds but no third cat.
That time is correct, and was post-engine swap, but was made on stock exhaust and 3.08 open rear. I'm going back to the track when I can get this situation figured out. The track wasn't horrible, Aaron K. ran a 14.3 I believe, The Great Obucina was running 15.1s all night. I think I'll see a nice improvement with practice and proper tires.
Can someone confirm for me where the bottom of the two ports on the PCV valve is supposed to lead? I'm guessing it should go to the upper intake, I have a port blocked off by the IAC intake that I'm thinking it should lead to...
TCCoA Gun Club
Palmguy is offline
post #5 of 20 (permalink) Old 06-09-2004, 09:34 AM
15.6 with 3.08's. That ain't shabby. Drop in some 3.73's and you will fly. Keep it up and lets us know when you hit them 14's. I am looking for them as soon as a can a find a near by track here in DC.
post #6 of 20 (permalink) Old 06-09-2004, 11:18 AM
ThunderB's Avatar
Only the large port of the PCV is used on my '97. The origional valve only had one large port, but the replacement had one large and a small port that was plugged. Are your unused PCV ports plugged? Check your vacuum lines as well, I just replace two rotted ones last weekend, still have to replace a few more. Also replace the PCV hose, if it's cracked, its leaking. Any whistling noises coming form your motor that could be an open vacuum line?
B
97 T-Bird Sport: Dynomax catback, Removed silencer w/ K&N panel, DReinhart chip, Lightning AGSF12-FM1 plugs/180 stat, Tokico 1.25" dropped stance, bye bye fender gap
'79 F100 SB : 300 ci six, Hurst Mastershift 3spd floor shifter, Offenhauser intake, Holley 4 brrl, EFI manifolds, Chebbie Rockers, Summit Racing 3.50 gearset, DISO 2.5" diesel muffler and 2.5" exhaust, Its'a six?!
ThunderB is offline
post #7 of 20 (permalink) Old 06-09-2004, 12:35 PM Thread Starter
Boom.
Palmguy's Avatar
I just checked our '96 and the larger hole does indeed go to the intake plenum. I have the tube for that lying around somewhere I just need to find it. New PCV valve as well, only $4, going in in a few minutes. Just need to get the flexible rubber hose that connects the PCV to the line going to the canister now, and we'll see where I end up at.
TCCoA Gun Club
Palmguy is offline
post #8 of 20 (permalink) Old 06-09-2004, 02:00 PM
Chapter Director Coordinator
jamesD's Avatar
hey
btw.. ever since this new SCT tune.. the exhaust smells different on my bird as well.. and she has true duals (ok ok ok w/ an h-pipe but still)
J
jamesD is offline
post #9 of 20 (permalink) Old 06-09-2004, 02:12 PM Thread Starter
Boom.
Palmguy's Avatar
Yeah if I could place a time frame on the problem I first noticed it around the time I became SCT Tuned...
Something doesn't seem quite right in my MD tune, so L is going to take care of me.
TCCoA Gun Club
Palmguy is offline
post #10 of 20 (permalink) Old 06-10-2004, 01:57 PM
Send a message via AIM to 96TBird
did they bump the timing at all? the one thing that comes to mind would be the valves having too long of an open duration. make sure that all the valves are opening and closing all the way. if they are than the only other thing i can think of is that on the exhaust stroke our intake valve somewhere is opening too early and it is venting unburn fuel through you exhaust valve (if that was the problem than you might have noticed a small loss in power) hope this helps you out.
1996 4.6L T-Bird - Totaled 1-26-2004
1981 Jeep CJ7 - 8 inch of lift (2 1/2" shackle, 2 1/2" leaf springs, 3 inch body) on 32x11.50. Soon to be equipted with Dana 44" axles and 35x14.50 MT OH YEAAAAAAA
R.I.P.
10-9-03 ~ Mallory Brook Neeley ~ Susan Jane Boyes
10-14-03 ~ Lindsey Nicole Groff
Please Visit the Thunder Chicken Fan Page and the Memorial Link for my 3 friends who died an an automobile accident.
96TBird is offline
post #11 of 20 (permalink) Old 06-10-2004, 02:34 PM Thread Starter
Boom.
Palmguy's Avatar
Yes, the chip advances the ignition timing.
The only way that I have improper valve operation would be if there was in fact damage done at the track on April 30th. The engine saw 6500 RPMs once, not intentionally, but I suppose it is still possible that there was valvetrain damage done at that point. I do not believe this is the case though.
We'll see how things turn out after the car gets retuned by someone I trust and he gets behind the wheel and checks things out himself.
TCCoA Gun Club
Palmguy is offline
post #12 of 20 (permalink) Old 06-10-2004, 04:40 PM
jamesD's Avatar
when are you going?? just let me know.. i'll "fly" with you
jamesD is offline
post #13 of 20 (permalink) Old 06-10-2004, 06:19 PM Thread Starter
Boom.
Palmguy's Avatar
I hope to get the separator plate that Tim gave me installed first thing next week, so as of this point I will be planning on going up the following Monday.
I'll keep you posted after I get my schedule sorted out and talk to the man to see what his looks like.
TCCoA Gun Club
Palmguy is offline
post #14 of 20 (permalink) Old 06-10-2004, 08:30 PM
jamesD's Avatar
shyt.. can't go that monday hehe not free till that wednesday that week u back up in O-town yet??
jamesD is offline
post #15 of 20 (permalink) Old 06-10-2004, 09:19 PM Thread Starter
Boom.
Palmguy's Avatar
Nope I'm back home for the summer in PC...otherwise you would have been getting phone calls to hang out/have a BBQ or something lol
I could probably back it up a couple of days or hold off until the next week or so, of course depending on the other party. I've got a Ford meeting in Orlando on the 26th-27th but won't be able to shoot up to OP then.
TCCoA Gun Club
Palmguy is offline
post #16 of 20 (permalink) Old 06-10-2004, 09:51 PM
JoeyICU's Avatar
6500 should be fine on a pi motor, id get worried at 6900 and above, id work out your PCV issue and then see if the exhaust smells funky on one side still, you seem like you have very well planed out healthy mods, what made you opt for 3.27s vs something else?
JoeyICU is offline
post #17 of 20 (permalink) Old 06-11-2004, 05:46 AM Thread Starter
Boom.
Palmguy's Avatar
I know that some people say that they get decent highway mileage with 3.73s, but I spend quite a bit of time on the highway and I'm really not planning to go all out with this car. Right now I'm working on some appearance issues (new headlights, painted grill, etc), and my SVO fund is getting larger by the paycheck. After the SVO blower I plan to build up the suspension but that is it, or so I say now
TCCoA Gun Club
Palmguy is offline
post #18 of 20 (permalink) Old 06-11-2004, 11:15 AM
JoeyICU's Avatar
how much is the SVO kit? ive been looking for any info on it and cant seem to find any, i work for a ford dealer that is a FRPP dealer, can you get it threw FRPP?
JoeyICU is offline
post #19 of 20 (permalink) Old 06-11-2004, 11:46 AM Thread Starter
Boom.
Palmguy's Avatar
Yes, check your 2004 Ford Racing catalog for the 4.6L SOHC supercharger kit, two available, one with PI runners one with NPI.
TCCoA Gun Club
Palmguy is offline
post #20 of 20 (permalink) Old 06-11-2004, 07:13 PM
JoeyICU's Avatar
much help, now back to the thread, checked your maf or any sensors at all?
JoeyICU is offline
