Mid Mufflers??fit?? - TCCoA Forums
post #1 of 32 (permalink) Old 06-11-2004, 11:17 PM Thread Starter
Mid Mufflers??fit??
I have true duel 2 1/4 exhaust with no cats and 40 series flows in the rear. Has anyone ever mounted them in the front or the middle because I think it sounds better when there is piping after the mufflers.
JACOB is offline
post #2 of 32 (permalink) Old 06-11-2004, 11:46 PM
Flying Thunder
weswing04's Avatar
Send a message via AIM to weswing04 Send a message via Yahoo to weswing04
it would sound beautiful, but ground clearance may be an issue...
weswing04 is offline
post #3 of 32 (permalink) Old 06-12-2004, 12:11 AM Thread Starter
Yeah? Well my car is lowered about 2 inches or so and it might be a problem. I know it would sound beautiful. I have heard it before, I think StephenC has a clip. I have heard alot of setup, but I must admit, it was the best sounding exhaust I have ever heard on an MN12.
JACOB is offline
post #4 of 32 (permalink) Old 06-12-2004, 12:50 AM
JoeyICU's Avatar
you can get them up closer to the engine, just it will rub all the time on STOCK height, so id consider that option out of the question for you
it does sound better though, when there closer and have piping after the muffs
JoeyICU is offline
post #5 of 32 (permalink) Old 06-12-2004, 01:10 AM
Tx_Cat's Avatar
don't forget about the droning, because they will drone
Tx_Cat is offline
post #6 of 32 (permalink) Old 06-12-2004, 09:58 AM
JoeyICU's Avatar
yeah they will, but if your puting an exhaust on your car why worry about it, half the time with a droning exhaust my music just gets turned up more i dont know if mine drones b/c i dont even notice drone anymore, i think it does a little at 2k, but only b/c the piping isnt all the way out the back
JoeyICU is offline
post #7 of 32 (permalink) Old 06-12-2004, 12:47 PM
MRCYCOUG's Avatar
[QUOTE]Originally posted by JACOB
Yeah? Well my car is lowered about 2 inches or so and it might be a problem. I know it would sound beautiful. I have heard it before, I think StephenC has a clip. I have heard alot of setup, but I must admit, it was the best sounding exhaust I have ever heard on an MN12. [/QUOTE
you got it, i think stephenc is the only one that has real true dual setup, search for stehpenc's he has pics on here somewhere, i have not seen him here in a while thou, i have been planning this for my mark8 for the past 2 yrs, i have the muffler , ( i dont have hte tip or the x's soon to come thou, still thinking if i should get header shorties or l.t.
________
Honda FCX specifications
MRCYCOUG is offline
post #8 of 32 (permalink) Old 06-12-2004, 02:16 PM
Send a message via AIM to jjjustin17 Send a message via Yahoo to jjjustin17
i put my mufflers in the middle and they barley have enough room to fit side by side but u loose probly 2 1/2 inches ground clearance. my cars not lowered and iver never herd them scrape anything.
green 95 thunderbird lx 4.6
mods-- clear corners, k & n filter, lebra, 97 intake tube. flowmasters.
mods to install-- saleen wing, sc side skirts. hopefulls-- new heads, intake, sc rear bumper, cowl hood, cobra r's, lower the car,
jjjustin17 is offline
post #9 of 32 (permalink) Old 06-12-2004, 04:19 PM
Still needs a clue
Now what if you get a dual-in dual-out muff and run an xpipe AFTER it?
or maybe go with a pair of these Muffs
mylittleblackbird is offline
post #10 of 32 (permalink) Old 06-12-2004, 07:44 PM
Rich95XR7's Avatar
Send a message via Yahoo to Rich95XR7
I had mid-mounted mufflers for a VERY short time, and my car isn't lowered. I tore a hole in a muffler the week after I had them done, and took it in and had the whole exhaust redone. I lost at least 2" of ground clearance, and I would scrape them on big dips in the highway, and had to be careful of inclined driveways. It wasn't worth the hassle, so they went bye bye. It did sound good though.
Rich95XR7 is offline
post #11 of 32 (permalink) Old 06-12-2004, 08:03 PM
Will3799's Avatar
Send a message via AIM to Will3799
Are there clearence issues with a single muffler in place of the third cat?
Fear the insanely fast Thunderbird with SECRET mods!
Secret not meaning Fram filter and removed air silencer.
Yeah…definitely not
Future mods
5-Speed
Will3799 is offline
post #12 of 32 (permalink) Old 06-12-2004, 08:20 PM
Overkill Fetish Freak
Nope.
Dr. FrankenCougie is offline
post #13 of 32 (permalink) Old 06-12-2004, 08:43 PM
Send a message via AIM to 1997T-Bird Send a message via Yahoo to 1997T-Bird
Ya know, I just LOVE the responses some people have here.. Realll simple!!
Currently: 2004 Honda Civic Ex 5 Speed
17X7 BSA Wheels - 215/45/17 Falkens; Complete JL System; Magnaflow Catback; Lowered 1.4"
Last Car:
Custom Magnaflow Dual Exhaust; 2003 Cobra Rims with Kelley 255/45/17s;Steeda U/Ds; B&M Transmissoin Cooler; Dirtyd0g's custom 2800 Stall Torque Converter; J-Mod Kit installed by Dirtyd0g; SCT Tuned by Darrin; Lowered with Spring Tech Springs
Want great work done on your tranny? Have dirtyd0g do it! He made a believer out of me!
1997T-Bird is offline
post #14 of 32 (permalink) Old 06-12-2004, 11:19 PM
Rich95XR7's Avatar
See where the dips in the floorpan are on both sides of Scott's exhaust? That's the only place to put the mufflers, and you can see how much clearance you'd lose with 2 mufflers there.
post #15 of 32 (permalink) Old 06-13-2004, 01:41 AM
JoeyICU's Avatar
its kinda hard to put them there tho, b/c theyd hit the floorboards and rattle, or theyd rub everything, witch isnt cool either, i have my muffler mounted in place of the 3rd cat, it sounds good for what it is
JoeyICU is offline
post #16 of 32 (permalink) Old 06-13-2004, 02:35 AM
Full Metal
RedThunder94's Avatar
yup.
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #17 of 32 (permalink) Old 06-13-2004, 10:06 AM
JoeyICU's Avatar
id take a pic of mine but i basically have the same getup minus high flow kitties and the pretty undercar paintage, i think it sounds pretty good, i want a little bit diffrent sound though
JoeyICU is offline
post #18 of 32 (permalink) Old 06-14-2004, 03:21 AM
Send a message via AIM to powerhouze
wow its been too long since i've been under my car. However. It seems as if you would have enough room to install them where the cats where.
99 trans w/2800 stall (thanks to Darrin and Dirtydog) Mac Underdrive, CAI, SSAutoChrome headers sitting in my closet (For Sale), ford factory 4.10 ring/pinion in the closet also(for sale) 2 mtx 6x9s in the back .
powerhouze is offline
post #19 of 32 (permalink) Old 06-14-2004, 01:35 PM
281_TBird's Avatar
I was thinking of getting midmounted mufflers, but I am lowered. So I was thinking of putting two 6in round Dynomax Race Bullets on. Do you think i'd still scrape with those? Also, Im gonna out them on with shorty headers and no crossover, do ou guys think that would sound good?
1997 Ford Thunderbird, Built NA 2V/ T-45
1997 Ford Explorer AWD 5.0L
2003 Lincoln LS V8 Bolt Ons
2009 Yamaha VMax
2011 F-150 Lariat Limited 6.2L 4WD
2015 Ford Mustang GT Premium, Performance Pack, Recaros
281_TBird is offline
post #20 of 32 (permalink) Old 06-14-2004, 11:49 PM
I'm Mid-mounting my muffs. I'm gonna use The midget car borla muffelers.
I'll update my post with the link. be right back
They're bullet muffelers here
post #21 of 32 (permalink) Old 06-15-2004, 10:51 AM
Rich95XR7's Avatar
6 inch bullets would be too big I would think. My mufflers were only 4" deep. I would go with a 4" bullet, and try to tuck them up as far as you can, and hope they don't rattle.
post #22 of 32 (permalink) Old 06-15-2004, 01:14 PM
281_TBird's Avatar
but if I had 2.5in duals, with 4 in mufflers , wouldn't that mean that'd I'd lose[IMG]http://www.speedfreak.cc/products/texhaust/tex-under2.jpg[/IMG
Couldn't I put them, on this long stiagth section after where the cats would be?
2009 Yamaha VMax
post #23 of 32 (permalink) Old 06-15-2004, 01:15 PM
281_TBird's Avatar
Well, that image didn't work, but u can enter that for your url and see what I am talkin about.
2009 Yamaha VMax
post #24 of 32 (permalink) Old 06-15-2004, 01:39 PM
You just needed a "]" on the end.
post #25 of 32 (permalink) Old 06-15-2004, 09:27 PM
281_TBird's Avatar
Thanks Dr. FrankenCougie. Im talking about putting them where that long straight part is, the part along side the trannsmission. Do you guys think that would sound good with the bullet mufflers and shorty headers? Also does no crossover, x-pipe, h-pipe sound different? I think that no crossover has the least low-end torque right? But what would sound the best? I know a lot of that "mean sound" comes form better cams and heads, but what would sound teh best on my stock engine (for now )
2009 Yamaha VMax
post #26 of 32 (permalink) Old 06-16-2004, 11:45 AM
Rich95XR7's Avatar
One question: If they would fit, have you thought about maintenance??? I've worked on a couple cars with custom exhaust that you couldn't take the tranny pan down to change the filter because the exhaust was in the way, I'm willing to say that you would probably have the same problem, and trust me, it gets old having to take the exhaust off every time you need to change the tranny fluid.
post #27 of 32 (permalink) Old 06-16-2004, 01:42 PM
I hear you better off not changing the trans fluid after 100,000 miles
post #28 of 32 (permalink) Old 06-16-2004, 01:48 PM
I think You need a hearing aid.
post #29 of 32 (permalink) Old 06-16-2004, 05:27 PM
JoeyICU's Avatar
ditto, my rule of thumb id either put a sinlge muffler in the middle (what i have now) or two mufflers out back, i just dont feel like messing with the hassle, and im not that worried about sounds vs, actaully flowing and gaining power
JoeyICU is offline
post #30 of 32 (permalink) Old 06-16-2004, 07:13 PM
281_TBird's Avatar
Yeah, I think im just going to put a dual in dual out Magnaflow muffler where the third cat would be.
2009 Yamaha VMax
