Im Through Checking My Engine... - TCCoA Forums
post #1 of 7 (permalink) Old 06-15-2004, 12:28 PM Thread Starter
birdmandan's Avatar
Send a message via AIM to birdmandan Send a message via Yahoo to birdmandan
Angry Im Through Checking My Engine...
So my check engine light has been on for officially a year, i get the codes tested at auto zone and it was the EGR and my car passes emmision test like nobody's business, soooo, i was wondering if someone knows which wire i cut to turn the check engine light off, FOREVER! and im not gonna fix the EGR, if i do any thing, it will be removing the
EGR.
thats all, and thanks and what not
Modifications....
-air silencer removed
-3.25 pipe from filter to throttle body
-cone filter
-flowmaster muffler in for resonator
-3 inch exaust past muffler
birdmandan is offline
post #2 of 7 (permalink) Old 06-15-2004, 01:37 PM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
hahahaha sorry had to laugh at the topic.... I guess you could remove the bulb, but then if you really need that CE light, then you wouldn't know if there is a real problem. I would just fix the problem man... Which code is it exactly?
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #3 of 7 (permalink) Old 06-15-2004, 02:17 PM
Trumpeter Extraordinaire
IronChopz's Avatar
I agree...the problem may not be the EGR valve itself, but rather the pressure sensor or vacuum regulator...
To reiterate jordansypek's question: what code(s) is/are present?
IronChopz is offline
post #4 of 7 (permalink) Old 06-15-2004, 02:26 PM
jk69cat's Avatar
pull your upper intake off , check the passage underneth, i bet its plugged solid! if its not that , then its either a egr valve or a dpfe sensor still cheap fixes, id fix it if were you, its probally affecting gas milage.
mn12 less!
jk69cat is offline
post #5 of 7 (permalink) Old 06-15-2004, 04:47 PM
Refrigerator Raider Hater
GreenBird's Avatar
the EGR tube could even be physically damaged.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #6 of 7 (permalink) Old 06-15-2004, 05:04 PM
RyanG's Avatar
Send a message via AIM to RyanG
Is it a P0402? I get that every 2 weeks or so after hot stop and go traffic. When I did my PI intake swap, the pencil size egr port was completely blocked, so I cleaned it. Now I get this code off and on. Mileage is decent.
Also, I have a question regarding the EGR hoses that go up to the DPFE. I am pretty sure we installed them back properly, does anyone know which hose goes to which port? Like longer hose goes to the rear connector, short to front?
thanks
RyanG is offline
post #7 of 7 (permalink) Old 06-16-2004, 04:45 PM
3rd Gear Chirper
hotbird's Avatar
Cut wire= BAD.
Remove bulb=GOOD.
Just remove the gauge cluster and twist out the bulb holder, reassemble and you're done.
I removed mine due to the fact that the EEC saw one of my mods as a malfunction...and put the light on, therefore rendering it useless as far as telling me about actual faults. When I get money to buy a chip with programming to force the EEC to ignore the fault, I'll put it back in.
hotbird is offline
