knocking at startup - TCCoA Forums
post #1 of 18 (permalink) Old 07-20-2002, 01:29 PM Thread Starter
95LX's Avatar
Question knocking at startup
I sometimes abuse my Bird by letting her sit for a week at a time. When I go to start her up, I hear knocking for a second or two. It sounds like the oil isn't present at some parts for the first few seconds after start up. It sounds just like it does when you just changed the oil and strated the car for the first time.
Should I be concerned about this, or is it normal? The engine does not smoke, nor does it eat enough oil to be added between oil changes with just about 113k on it. Thanks.
Jim
95LX is offline
post #2 of 18 (permalink) Old 07-20-2002, 01:30 PM
Mushroom Stamp Layer
seabass's Avatar
Do you run a Fram filter?
Seabass
seabass is offline
post #3 of 18 (permalink) Old 07-20-2002, 01:34 PM Thread Starter
95LX's Avatar
Unhappy uh oh...
It's not Fram, but it's a no name. Could it be the problem?
Jim
95LX is offline
post #4 of 18 (permalink) Old 07-20-2002, 01:51 PM
seabass's Avatar
Get a motorcraft filter or something named other than Fram. That knock sounds like a drystart...definatly not good. When the knock happens...look at your oil gauge...it probably doesn't move while it's knocking and then once it goes up you'll hear the knocking stop.
Seabass
seabass is offline
post #5 of 18 (permalink) Old 07-20-2002, 01:55 PM Thread Starter
95LX's Avatar
Thanks, will do.
Jim
95LX is offline
post #6 of 18 (permalink) Old 07-20-2002, 03:33 PM
JustinH's Avatar
Hmm.
Very intersting, about a year ago I was running fram filters and I was getting a similar knock for about two seconds only right after I changed the oil, and put in a fresh filter. Now, I run motorcraft filters, and the knock is no longer there. Why would this be?
JH
JustinH is offline
post #7 of 18 (permalink) Old 07-20-2002, 03:52 PM
There is talk of Drain back vakle issues with Fram
I use them with 10W40 Mobil and haven't heard "rattling or knocking" at cold start. Been using them for years just like Fords maybe it's loyality I don't know, maybe it's the fact that a Motocraft filter left me stranded in the middle of nowhere Arizona when the seam burst. Never had an issue with Frams will keep not having issues untill I do have one.
Blitzcat is offline
post #8 of 18 (permalink) Old 07-20-2002, 04:24 PM
seabass's Avatar
problem is that Fram doesn't have an anti-drainback valve so dry starts will happen...period.
seabass is offline
post #9 of 18 (permalink) Old 07-21-2002, 01:20 AM
All of them?
It depends on the type of Fram filter (which are made by Allied Signal), and while they do have an anti-drain valve on a lot, they are made rather cheaply and out of a nitrile rubber diaphragm which fails easily in cold weather. Infact you can simply look inside and tell if your filter has the valve. But as mentioned, even if it does, you aren't exactly safe.
I don't know how many different "levels" of filter they supply for the MN-12, but I've used Motorcraft and now Mobil One.
Fram has dropped off in terms of quality significantly. Avoid them.
Derek is offline
post #10 of 18 (permalink) Old 07-21-2002, 10:07 AM
Tbirdluvaffair's Avatar
I'm using a K&N and I have the same problem. After the car sits overnight, it knocks just a little when I start it. Guess I won't use their oil filters anymore.
Sarah
2001 Mustang
Staying Stock
Tbirdluvaffair is offline
post #11 of 18 (permalink) Old 07-21-2002, 10:49 AM
JustinH's Avatar
Thats interesting about the k&n filters. I would never buy those to start with because they are over ten dollars each, right? I hear they filter a very small particle, but the last thing you want is knocking at startup.
I'm starting to like the motorcraft filter more and more, especially because I think it is the same price as the cheap fram is at walmart.
Justin
JustinH is offline
post #12 of 18 (permalink) Old 07-21-2002, 03:48 PM
Hey, anything for my bird, lol! I was experimenting, but I don't think the filter is worth the $$. I did pay a little over $10 for it. I guess you live and learn.
Sarah
2001 Mustang
Staying Stock
post #13 of 18 (permalink) Old 07-21-2002, 08:34 PM
Refrigerator Raider Hater
GreenBird's Avatar
Every once in awhile.....
Ford does something right. LOL.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #14 of 18 (permalink) Old 07-21-2002, 10:48 PM
Slacks 12 months a year
LX-Tasy's Avatar
I use a puralator...
I dont know if i spelled that right but they have the anti drain back.I used that on my Mark and never had the knock on start up and the 32 valve is more known then the 16 valve for knock on start up.You can get them at Discount,AutoZone and I think Pep-Boys.Not sure though.
Chris
LX-Tasy is offline
post #15 of 18 (permalink) Old 07-22-2002, 01:51 AM
WaLieN's Avatar
Send a message via AIM to WaLieN
Are NAPA filters like this also?
☼1997 Ford Thunderbird LX - 4.6L -K&N Panel Filter-Steeda U|D Pulleys-Steeda 180* Thermostat-Removed Intake Silencer-Polyurethane IRS Bushings-Tranny Cooler-Urethane Tranny Mount
☼1993 Mazda RX-7 Touring [VR] - Rotary Power rebuilt turbos & motor w/ 3mm Apex Seals - PWR Radiator - PFS Cat-Back - RB Intake Duct w/ K&N Panel - Manual Boost Controller - KG Differential Brace - Gotham Engine Torque Brace - Aluminum 45mm Front STB - B&M Short Throw Shifter - PFS Column Mounted Boost Gauge - Falken Azenis ST115s [235/40ZR17] on Speedy Mashie Silvers
WaLieN is offline
post #16 of 18 (permalink) Old 07-24-2002, 06:54 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Talking
My car knocks/ rattles whatever when it sits for more than a couple hours....whether or not I have a motorcraft filter or Fram Extra guard....(both of these had anti-drainback valves) Any other ideas on what it could be?
-Rob
Rob is offline
post #17 of 18 (permalink) Old 07-25-2002, 02:33 AM
Earl's Avatar
knock at startup
My 96 t-bird did that when I first got it...I couldnt ever figure out what it was caused by, and it would only do it after the car sat all night...I changed the battery a couple months after I got it, and not only did the car fire right up a lot quicker then before, but the startup knock was gone, and never re-appeared for the rest of the time I owned the car. Could it have been the starter due to the engine not turning over very quickly due to a almost dead battery? Possibly, but I'm not sure...Try a fresh battery, worked for me.
Hope this helps
Earl
Earl is offline
post #18 of 18 (permalink) Old 07-26-2002, 09:50 PM
has any one considered a cloged pick up or bad oil pump?
Rino is offline
