how safe is it to put pipes under the gas tank? - TCCoA Forums
post #1 of 15 (permalink) Old 06-29-2004, 09:05 PM Thread Starter
Send a message via AIM to jjjustin17 Send a message via Yahoo to jjjustin17
i wanna have my exhaust come out the side before the tire but there is obvisley the tank there. how close can i get the pipes to it withought possing a issue if at all?
green 95 thunderbird lx 4.6
mods-- clear corners, k & n filter, lebra, 97 intake tube. flowmasters.
mods to install-- saleen wing, sc side skirts. hopefulls-- new heads, intake, sc rear bumper, cowl hood, cobra r's, lower the car,
jjjustin17 is offline
post #2 of 15 (permalink) Old 07-01-2004, 06:28 AM Thread Starter
please?
post #3 of 15 (permalink) Old 07-01-2004, 07:40 AM
Mark M. TCCoA VP's Avatar
There is like zero room under the gas tank for road clearance. You would need a good air gap and shield to protect the plastic gas tank from an exhaust pipe.
Mark
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #4 of 15 (permalink) Old 07-01-2004, 07:42 AM
Rolling-Thunder's Avatar
I thought the primary concern with trying to install side pipes, is the location of the fuel line along the passenger side.
With regard to your question, here is my opinion;
Take a look at how close the stock exhaust pipe is to the fuel tank, and don't get any closer to it than that.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #5 of 15 (permalink) Old 07-01-2004, 08:56 AM
Jedi Master
mn12xr7's Avatar
the gas tank can handle sum heat, 89-91 models actually have part of the exhaust going through the gas tank
-Orlando
mn12xr7 is offline
post #6 of 15 (permalink) Old 07-01-2004, 09:08 AM
I know on my 94, where the exhaust goes above the tank there is a metal heat shield and also thick reflective insulation that is taped to the gas tank. So a lot of engineering went into trying to protect the plastic tank from excessive heat right from the factory.
MHO is that between the lack of clearance, the plastic fuel lines on the passenger side, and the necessary clearance to the plastic fuel tank makes the side pipe configuration not realistically feasible.
IMHO.
69 F100 LWB w/460 Engine
post #7 of 15 (permalink) Old 07-01-2004, 04:01 PM Thread Starter
well my exhaust is kinda rigged up and i dont really wanna put a ton of money into it.. right now it has stock cats then it goes into 2 flowmasters like under the middle ive never rubbed nething its probly mabee 2 inches low. then i was thinking mabee just running some pipes 2 along the drivers side but not out of the pinch weld just so u cant see em but they will take the smoke and stuff out of the underside.
post #8 of 15 (permalink) Old 07-01-2004, 05:06 PM
The exhaust goes beneath the tank, the driveshaft is above the tank. But you're right, there is a protective sheild both above and below the tank.
-Rod
post #9 of 15 (permalink) Old 07-01-2004, 06:34 PM
4 Cam Bird's Avatar
Put a fuel cell in the trucnk and run the exhaust where ever you want
2011 CTS-V Wagon
4 Cam Bird is offline
post #10 of 15 (permalink) Old 07-01-2004, 07:37 PM
The Band, not the Disease!
AnthraxBird's Avatar
Re-Route the lines... simple as that!
AnthraxBird is offline
post #11 of 15 (permalink) Old 07-01-2004, 08:33 PM
-Rod
Yeah, that's what I said...
Sorry, my bad.
post #12 of 15 (permalink) Old 07-04-2004, 01:54 AM
4.6Rebuild's Avatar
i know that this is not the same subject but it has to do with exhaust. i was wondering if it would cause a problem to end the exhaust pipes right after the differential, would the exhaust come back into the car or heat the trunk up to much any input would be apreciated.
OK, maybe not soon to be, but i will have it all sooner or later: PI heads, kooks headers, comp cams, 24# injectors, U/D pullies, J-mod, Aluminum driveshaft, and mustang convertor all into a 94 thunderbird.
4.6Rebuild is offline
post #13 of 15 (permalink) Old 07-04-2004, 09:58 AM Thread Starter
mines like that now.. i havent had any problem yet but im gonna put turndowns on come winter.
post #14 of 15 (permalink) Old 07-05-2004, 04:07 AM
4.6Rebuild's Avatar
i got the idea from a pic i saw in the exhaust section in the tech articals, but i wasn't sure if they where going to finish running out the back. kinda like they had taken a pic part of the way through.
post #15 of 15 (permalink) Old 07-06-2004, 09:00 AM
Thumper91's Avatar
I ended mine at the diff for a few months.. and my back bumper deformed.. just warning you..
"I'm fat, you're ugly.. I can diet!"
"I may not be smart, but I can lift heavy objects"
"10 Million sperm, and look which one got through"
Thumper91 is offline
