Oil Pressure - TCCoA Forums
post #1 of 4 (permalink) Old 07-20-2002, 04:21 PM Thread Starter
Send a message via Yahoo to wkenneth
Oil Pressure
Ever since my last oil change, my oil pressure has been waaaay up on the back end of the M on NORM (95 4.6 w/ 103k). Any ideas why that would happen? Oil pump going out or some other ghostly thing? I think it threw a code which isnt good because the check engine light is on.....Any ideas are appreciated
wkenneth is offline
post #2 of 4 (permalink) Old 07-20-2002, 04:23 PM
Mushroom Stamp Layer
seabass's Avatar
Well the stock oil pressure guage only tells you if you have less than 6psi or more than 6psi...where it is on the gauge means nothing. I wouldn't worry about it...or get a real gauge.
seabass is offline
post #3 of 4 (permalink) Old 07-20-2002, 04:25 PM Thread Starter
So as long as it works its fine?
And where can I get some real gauges at for a good price?
wkenneth is offline
post #4 of 4 (permalink) Old 07-20-2002, 09:24 PM
BR1
Send a message via AIM to BR1
buy some autometers. look on summits website. mine works i think, it varies between about 25 to 80 psi. it was pretty cheap too. i would suggest buying electrical gauges, not mechanical.
J-chipped
90mm Lmaf, GT tube
magnaflow exhaust
FRPP pulleys
17x9 Cobra R chrome
255/45/17, 245/45/17 potenzaRE-730
13" cobra brakes, KVR rotors
1.25" addco rear bar
mark VIII driveshaft
bilsteins & tokico springs
BR1 is offline
