Weird thing happened today..... - TCCoA Forums
post #1 of 16 (permalink) Old 07-01-2004, 10:14 PM Thread Starter
CEO Red Sox Nation
DMcBrideBoston's Avatar
I was driving earlier today and began to pull into my friends parking lot and all of the sudden, I lost my power steering and my check battery light came on, BUT MY CAR WAS STILL RUNNING!
I had no idea what was goin on so I popped my hood, and saw that my belt had came off, I put it back on and everything is now fine.
Has anyone ever had this happen, I thought it was very strange. Maybe if the belt had broke I could have understood, but it didn't.
Insight?
Dave
2003 Infiniti G35 Sport Package with Navigation
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
DMcBrideBoston is offline
post #2 of 16 (permalink) Old 07-01-2004, 10:49 PM
Whining Intakes Rock
Al_Florida's Avatar
How old is the belt?
You can check the wear indicator on the belt tensioner to see if it is close to the stop. Also check to see if the tensioner, tensioner pulley and idler pulley aren't binding. My idler pulley is tight turning. I need to replace mine.
Edit: I wrote idler pulley but technically its the accessory drive belt routing pulley. The one above the tensioner (on the 4.6).
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 16 (permalink) Old 07-01-2004, 10:59 PM Thread Starter
CEO Red Sox Nation
Belt is about 2 months old, seems to be in perfect shape.
post #4 of 16 (permalink) Old 07-02-2004, 05:41 AM
Sweet T
SanDiegoLXBird's Avatar
Check your tensioner maybe? If the belt is good, the only way I can think of for it to pop off is if the tensioner is going, loose or otherwise not opperating at it's best.
SanDiegoLXBird is offline
post #5 of 16 (permalink) Old 07-02-2004, 05:43 AM Thread Starter
CEO Red Sox Nation
Everything is cool now, nice and tight. Maybe it's on it's way out??
I don't know!
Dave
post #6 of 16 (permalink) Old 07-02-2004, 06:42 AM
I'd bet that 2 months ago, when the belt was replaced, it was partially off a pulley. And it took this long for it to work its way completely off.
Just a guess though, if the tentioner is ok.
69 F100 LWB w/460 Engine
post #7 of 16 (permalink) Old 07-02-2004, 04:25 PM Thread Starter
CEO Red Sox Nation
Good thinking, that one never crossed my mind
How can you tell if the tensioner pulley is bad or going bad?
Dave
post #8 of 16 (permalink) Old 07-24-2004, 05:27 AM Thread Starter
CEO Red Sox Nation
Well.....It happened again this morning on my way to work......mind you in the POURING friggin rain! I asked in my last post how to tell if the tensioner is going bad, no one awnsered the question, now I need to find out. Cus this was one hell of a morning, trying to do this myself in the rain.
Thanks in Advance
Dave
post #9 of 16 (permalink) Old 07-24-2004, 05:39 AM
Sweet T
Well.. do you hear squealing at all when you start the car or during initial acceleration?
post #10 of 16 (permalink) Old 07-24-2004, 05:45 AM Thread Starter
CEO Red Sox Nation
Nope none.
Car sounds good, no odd noises.
Dave
post #11 of 16 (permalink) Old 07-24-2004, 05:55 AM
Sweet T
How easy is it to take tension off the belt? It should take a little muscle to get the tension off the belt. If it does it relatively easily, it's a pretty safe bet that the tensioner is going. That or you forgot the set the belt completely again.
post #12 of 16 (permalink) Old 07-24-2004, 05:58 AM Thread Starter
CEO Red Sox Nation
Well...The tensioner is hard to move, it does take muscle, boy was it fun to do alone
Maybe 1 time I could believe the belt wasn't on correctly but 2, that's kinda pushin it.
Also I didn't metion in the first post that it was also drizzling and the ground was quite wet.
Dave
post #13 of 16 (permalink) Old 07-24-2004, 06:01 AM
Sweet T
If the belt has good tension on it, moisture really isn't going to cause it to jump off the pulleys like that. tripple check the belt this time. 'cause if the tensioner feels okay.. and the belt is /all/ the way on the pulleys, I don't see why it should be falling off like that.
post #14 of 16 (permalink) Old 07-24-2004, 06:11 AM Thread Starter
CEO Red Sox Nation
Alright...Thanks
Dave
post #15 of 16 (permalink) Old 07-24-2004, 02:09 PM
ITT-BIRD's Avatar
Dont know anything about your mechanical abilities, but how long have the U/D been on? On correctly .... if so ... what kind of belt &double check part #s on belt. could just be a factory freak.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #16 of 16 (permalink) Old 07-24-2004, 02:27 PM
Lonnie's Avatar
I've seen that happen before on vehicles with a lot of miles. The power steering pump worn and doesn't put out enough pressure anymore. So when you turn the wheel to it's full travel or close to it the pump can't keep up and stalls. Then the belt jumps off the pulley since everything else is still turning.
If you can move the tensioner by hand then it needs replaced. Other wise it should take a ratchet or tension tool to move it.
www.blueovalchips.com
1992 5.0 Thunderbird Sport, 328 rwhp 347 rwtq
1995 Mark VIII, 287 rwhp 305 rwtq
I have seen the truth and it makes no sense
Lonnie is offline
