keeps overheating - TCCoA Forums
post #1 of 5 (permalink) Old 07-03-2004, 02:35 PM Thread Starter
Send a message via AIM to toymrj Send a message via Yahoo to toymrj
keeps overheating
ok i am so confused right now i dont know what to do. my car is still running hot and i have a 160degree thermostat, new temp sensor and just replaced my water pump and refilled system the way it suppose to be done. i dont know if it is trapped air or what? the only other thing is maybe it is my radiator is ****ting the bed or my fan is not cooling it enough cause a bought a 16 inch fan and hooked it up to a switch. does anyone know the cfm on the stock electric fan. mine says it does 2700cfm.
toymrj is offline
post #2 of 5 (permalink) Old 07-03-2004, 03:46 PM
CobraRThunder's Avatar
You better put your stock fan back on there Chief. Take my advice, and put your stocker back on there. Chris
4R70W From DirtyDog
CobraRThunder is offline
post #3 of 5 (permalink) Old 07-03-2004, 07:27 PM
AEDM8's Avatar
You didnt mix orange and green coolant did you?
AEDM8 is offline
post #4 of 5 (permalink) Old 07-03-2004, 10:34 PM
Moderator & Teksid Whore
guitar maestro's Avatar
might only other major aspect of your cooling system that you nelgected was to check your radiator if its clogged up
guitar maestro is offline
post #5 of 5 (permalink) Old 07-04-2004, 08:10 PM
FLABIRD's Avatar
If your radiator is original...replace it.
Wrecked...will be parting out soon 97 thunderbird 02GT 4.6 Bullitt Intake
Kook's true dual 02 4r70w trans completely rebuilt to jerrys specs
cstm D/S 373's 11/4 bars F&R 3800lbs
240rwhp/282tq ET:14.00
"Luck happens when opportunity meets preparation"
FLABIRD is offline
