car starts, immediately dies - TCCoA Forums
post #1 of 30 (permalink) Old 08-17-2004, 04:49 PM Thread Starter
ZackG's Avatar
alright, it will turn over great, rev then immediately die. if i give it gas it will stay running, but the second i stop giving it gas, it stalls. My neg. battery cable is in corroded all the way through, could this cause it? i was thinkin fuel or pump, but why woudl it run if i give it gas?
edit: the other day the car wouldnt start after driving it 3 mins to the post office, i wiggled the neg battery cable and it started up
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #2 of 30 (permalink) Old 08-17-2004, 06:47 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
I kind of had a problem like that but my car wouldnt die the power would kill before it would turn over. This morning it did it and i figured out it was the negative wire that hooked on the frame so i'm going out in a bit to clean that up to get a nice contact
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #3 of 30 (permalink) Old 08-17-2004, 08:37 PM
RIP Jake
Leland Jacobson's Avatar
If the electrical isnt the answer, check the IAC next, you can allways clean that up even tho ford sez replace them...
Leland Jacobson is offline
post #4 of 30 (permalink) Old 08-17-2004, 08:38 PM Thread Starter
ZackG's Avatar
i was thinkin the IAC or TPS also
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #5 of 30 (permalink) Old 08-17-2004, 08:47 PM
Kentwood's Avatar
Send a message via AIM to Kentwood
Yeah fix that battery cable ASAP
IAC
If it's bad - chances are cleaning it won't help
Kentwood is offline
post #6 of 30 (permalink) Old 08-17-2004, 09:50 PM
JoeyICU's Avatar
can a bad IAC cuase a very rough idle?, zach try doing the iac thats my bet, replace the negative battery cable also, thats just crazy to leave the way it is being new cables arent to expensive at all
edit: i guess a new battery cable is in order?
JoeyICU is offline
post #7 of 30 (permalink) Old 08-18-2004, 12:10 AM
Send a message via AIM to M_S_P_O_T
i had the same problem like a year ago and it turned out it was the TPS
M_S_P_O_T is offline
post #8 of 30 (permalink) Old 08-18-2004, 03:59 AM
Full Metal
RedThunder94's Avatar
don't forget, a vacuum leak could cause it as well if it was large enough.
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #9 of 30 (permalink) Old 08-18-2004, 04:30 AM Thread Starter
ZackG's Avatar
yeah i plan on changing the neg battery cable, but i hear it attaches to the passenger side motor mount and i looked for it and i couldnt really find it too easily! im goin to buy an iac and tps and see which one it "should" be
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #10 of 30 (permalink) Old 08-18-2004, 10:29 AM
Kentwood's Avatar
One of the motor mount bolts is a stud instead - and the cable goes on it then a bolt goes on top.
It's right above the oil filter.
If you drop the power steering pump and the oil filter it's right there
Kentwood is offline
post #11 of 30 (permalink) Old 08-18-2004, 10:29 AM
Kentwood's Avatar
Originally posted by Kentwood
One of the motor mount bolts is a stud instead - and the cable goes on it then a nut goes on top.
Kentwood is offline
post #12 of 30 (permalink) Old 08-18-2004, 10:34 AM Thread Starter
ZackG's Avatar
ok WTF. i started the car, gave it gas, and it IDLED. rough, but it idled. unplugged the IAC, it would die. plugged it back in, and it would start and idle rough w/o me giving it gas. sounds like the IAC. Good thing i ordered it.
Kentwood: and removing the power steering pump is an easy thing to do? Are you sure it goes there, b/c i swear i traced the ground more to the passenger side of the engine...
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #13 of 30 (permalink) Old 08-18-2004, 10:45 AM
Overkill Fetish Freak
You can see the stud installed in the upper LT motor mount hole. You do not have to remove the PS pump but it might be a good time to change the oil filter since that will give you some more room to work with.
-Scott
Dr. FrankenCougie is offline
post #14 of 30 (permalink) Old 08-18-2004, 10:47 AM Thread Starter
ZackG's Avatar
frankencougie, thanks for the pic, it clears up where it is so much. It still looks like a pita
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #15 of 30 (permalink) Old 08-18-2004, 10:49 AM
JoeyICU's Avatar
sounds liek it may be your iac, did you have any other problems with the car, b/c my guess it could possibly more then one thing cuasing to the idle issues
JoeyICU is offline
post #16 of 30 (permalink) Old 08-18-2004, 10:50 AM Thread Starter
ZackG's Avatar
it always idled totally fine. No other issues were known
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #17 of 30 (permalink) Old 08-18-2004, 12:40 PM
BGsTBird's Avatar
Send a message via Yahoo to BGsTBird
Don't even worry about the engine ground strap, make yourself a new one. Then attach it to the engine and body ground somewhere accesible.
I did this for a big stereo and it works great.
Don't make the task of replacing it harder than it really is.
Brian
'02 Supercharged Harley Davidson F-150 w/small system pic1 pic2 pic3 pic4
'96 TBird Sold - Another coming soon
'03 40th Ann. Busa Sold - '04 Red SE coming soon
BGsTBird is offline
post #18 of 30 (permalink) Old 08-18-2004, 08:28 PM
"Don't make the task of replacing it harder than it really is."
I need to work on that part...
post #19 of 30 (permalink) Old 08-18-2004, 09:43 PM
Still needs a clue
so Scott, how do you change that oil filter without dripping oil all over that purdy car?
mylittleblackbird is offline
post #20 of 30 (permalink) Old 08-18-2004, 11:10 PM
The pictures were taken after the first oil change so I think I'm ok on the spillage tip. Never be scared of bathing in the black lava flow of the blockenheds & red blood of the slushbox. It's good for the soul. Do be weary of the pumkin jizz as it does not go well as a Kuh-Log-Knee.
post #21 of 30 (permalink) Old 08-18-2004, 11:29 PM
RIP Jake
Just one other thought..... Is your MAF plugged in?...
post #22 of 30 (permalink) Old 08-18-2004, 11:31 PM Thread Starter
ZackG's Avatar
yes its plugged in, i tried unplugging it and i got the same results. I'm pretty sure its the IAC since i can get the car to idle now, but rough. But if i unplug the IAC it doesnt idle at all.
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #23 of 30 (permalink) Old 08-20-2004, 05:52 PM
JoeyICU's Avatar
the car would run with the maf unpluged tho, just like crap
JoeyICU is offline
post #24 of 30 (permalink) Old 08-20-2004, 06:50 PM
Kentwood's Avatar
Just put aluminum foil over the k member and form it into a spout.
Catches all the oil and makes it all end up in my catch pan.
Then you pull it off and your k member has no oil on it.
Kentwood is offline
post #25 of 30 (permalink) Old 08-20-2004, 09:27 PM
Place a plastic bag on your hand when you go to grab the filter and spin it right on in brother.
"This Bird shall fly"
post #26 of 30 (permalink) Old 09-29-2004, 03:24 AM
Send a message via AIM to powerhouze
aluminum foil. Genious. absolutly genious. It's a PITA trying to use cardboard. thanks for that tip.
99 trans w/2800 stall (thanks to Darrin and Dirtydog) Mac Underdrive, CAI, SSAutoChrome headers sitting in my closet (For Sale), ford factory 4.10 ring/pinion in the closet also(for sale) 2 mtx 6x9s in the back .
powerhouze is offline
post #27 of 30 (permalink) Old 09-29-2004, 11:37 PM
JoeyICU's Avatar
so, does the car run? wasup, did you check most of the sensors?
JoeyICU is offline
post #28 of 30 (permalink) Old 09-30-2004, 11:06 AM Thread Starter
ZackG's Avatar
i just cleaned the IAC and it idles totally fine now.. i dont get it
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #29 of 30 (permalink) Old 09-30-2004, 01:54 PM
RIP Jake
Well, the IAC was stuck closed , and you had enough bleed air to start, but not enough to run, so it died every time...
post #30 of 30 (permalink) Old 10-02-2004, 09:39 AM
cougar_ricer's Avatar
When my neg batt cable got corroded it wouldnt even turn over... the lights and stuff would be on... but as soon as i tried to start it... the lights and everything shut off. After i cleaned the terminal it fired right up.
Sold my Cougar . But I am in the market for another MN12 project!
cougar_ricer is offline
