kook's headers - TCCoA Forums
post #1 of 5 (permalink) Old 08-27-2004, 02:08 AM Thread Starter
Raptor03's Avatar
Question kook's headers
Will the Kook's headers for a 4.6 bird work on a 5.4? I'm contemplating an engine swap and I don't want to use stock exhaust manifolds.
Raptor03 is offline
post #2 of 5 (permalink) Old 08-30-2004, 02:25 PM
Recidivistic Procrastinator
Yes, they will bolt up. There is no difference between 4.6 2V heads and 5.4 2V heads. They will probably not fit due to the extra width of the 5.4 engine. Having just yesterday installed a 4.6 with the Kooks headers, I can tell you that it just fits with no room to spare. You practically need a "shoe horn" to get it in!
See this thread!
http://forums.tccoa.com/showthread.p...threadid=47599
94 LX 4.6
Hibernating...
Engine built by Jim O'[email protected] Racing
I live with "fear" everyday, sometimes she lets me race...
Cam94 is offline
post #3 of 5 (permalink) Old 08-30-2004, 05:37 PM
On Probation
blown96bird's Avatar
they will not fit because of the width of the 5.4 It is a extreemly tight fit even with the 4.6.
blown96bird is offline
post #4 of 5 (permalink) Old 08-30-2004, 05:50 PM
Still needs a clue
I have a friend that does machining for college, If he knew how far they were allowed to go out, I'm sure all he'd need would be a gasket for the bolt pattern and the tubes to bend it to shape. Reasonable idea?
mylittleblackbird is offline
post #5 of 5 (permalink) Old 08-30-2004, 08:54 PM
RIP Jake
Leland Jacobson's Avatar
thats not the prob.... the frame would need to be cut, and then rewlded to accomodate the things, and that wouldnt be a good thing in my opinion.... the stock headers (cast Iron) are a b1tch ta fit, require extensive grinding, and you still gotta dimple the frame with a 6lb maul to get a 1/16" clearance, go figure....
Leland Jacobson is offline
post #6 of 5 (permalink) Old 08-31-2004, 06:37 PM
J.Miller's Avatar
A few whacks on the frame with a big mallet and some light die grinder duty was all I needed to make the stockers fit.
Anyhow, it is a fact that the Kooks headers were designed to fit a stock 4.6L and will not fit a 5.4L without mods. You will be better off welding up your own set of headers to insure a fit….
J.Miller
East Coast Rolling Thunder!!!!
Official Eastern and Central PA chapter of the SCCoA!
J.Miller is offline
