4.6 Cobra Top end deal?? - TCCoA Forums
post #1 of 4 (permalink) Old 08-31-2004, 01:27 PM Thread Starter
Thumbs up 4.6 Cobra Top end deal??
Guys,
If I want to do a top end Cobra 32V conversion, what do I have to do to a Lincoln block to make this work? 1998 top end with only 6K miles!
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2488026010
Seems like the price is way too cheap to not buy! Aren't heads about $1k apiece?
Thanks guys....
Steve
fastmerc is offline
post #2 of 4 (permalink) Old 08-31-2004, 04:36 PM
mechman1984's Avatar
Hello
Nothing need to be done to the block at all cobra heads are the same thing as mark heads except with different cams. The intake will bolt right up but the sensors are probably different I don't know so they would probably need a rewire. I know on a 95 mark and a 95 tbird you only need to lengthen one sensor. The problem you will have is in 96 everything went to OBD-II so it gets a little more complicated in terms of wiring. HOpe that helps.
Will
Will
08 Ford Ranger
95 Thunderbird V8-Sold!
mechman1984 is offline
post #3 of 4 (permalink) Old 08-31-2004, 05:24 PM
Sweet T
SanDiegoLXBird's Avatar
Originally posted by fastmerc
Guys,
Thanks guys....
Steve
I have one piece of advise.
Talk to Lonnie Doll. His name on the boards is Lonnie. If there's anybody that knows that swap (and the BS associated with it in California) it's him.
SanDiegoLXBird is offline
post #4 of 4 (permalink) Old 08-31-2004, 06:01 PM
5.0 Chero's Avatar
thats seems real cheep on the price.. some body needs to jump on this
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
