Which motor? - TCCoA Forums
post #1 of 8 (permalink) Old 09-02-2004, 12:41 AM Thread Starter
Which motor?
What vehicle has a 4.6 PI that would be a good start for a supercharged engine. I want to rebuild it to take the rigors of supercharging. Anyone with knowledge on this swap would be appreciated. Thanks Tim Moore (newbie to LX)
97 Kenny Brown Supercharged 4.6
95 SC 5 Speed (wife stole it)
95 SC Auto
Whats a behind a me is not a my concern
Moorio is offline
post #2 of 8 (permalink) Old 09-02-2004, 01:17 AM
Rich95XR7's Avatar
Send a message via Yahoo to Rich95XR7
If you are going to rebuild the engine anyways, you could buy anything with a 4.6, and just put PI heads on it, adjusting the compression ratio with the new forged pistons you'll have to buy.
I thought Kenny Brown made suspension components, not superchargers.
Rich95XR7 is offline
post #3 of 8 (permalink) Old 09-02-2004, 09:01 AM Thread Starter
One of the 4.6s is an aluminum block. Would that still be good for a supercharged application? If so which vehicle did that motor come in? Thanks
95 SC Auto
Moorio is offline
post #4 of 8 (permalink) Old 09-02-2004, 11:58 AM
Still needs a clue
the Ford Exploder has a 4.6L Alluminum block methinks. As for supercharging, I don't know. I believe that all depends on how much PSI your going to be pushing.
mylittleblackbird is offline
post #5 of 8 (permalink) Old 09-02-2004, 01:45 PM
I beleive it was 01-or-02 when the Explorer changed the bodystyle, thats when they put aluminum 4.6 blocks in them.
post #6 of 8 (permalink) Old 09-02-2004, 01:52 PM
girdnerg's Avatar
02+ explorer, mountaineer have the AL block. Don't know about others.
timb is/was running a blower on his, and I'm pretty sure he said he had 15k+ miles on it so far. He is a great guy that helped me with my PI swap. I'd PM him and ask about the specifics of PSI and setup.
Rob
girdnerg is offline
post #7 of 8 (permalink) Old 09-02-2004, 02:21 PM
Smokin' Bird's Avatar
Send a message via Yahoo to Smokin' Bird
Probably means Kenny Bell?
Smokin' Bird is offline
post #8 of 8 (permalink) Old 09-02-2004, 02:27 PM
Cougar Pilot
BlackCat94's Avatar
Kenny Brown used to offer an S/C kit for the MN-12's. Still might. It's a Vortech based kit.
BlackCat94 is offline
