PI Intake on 96/97 question - TCCoA Forums
post #1 of 8 (permalink) Old 09-05-2004, 11:51 PM Thread Starter
JNT
JNT's Avatar
I've been reading the posts about adding the PI intake to a car with NPI heads.
A few questions.
In the group purchase thread about the Livernois kit it says that "Upwards of 35 hp and 40 lb's can be obtained - Doubles the output of just installing the PI intake alone"
http://forums.tccoa.com/showthread.p...threadid=41272
Can someone clarify what in the kit accounts for double the power of just using the PI intake itself.
Also will the Livernois adapter and the PI intake (not the kit) fit in my car. The Livernois site says that the regular intake will not fit but that is on a mustang what about a MN12?
http://www.livernoismotorsports.com/product.phtml?p=457
The HP claims I saw for this mod varied and some were for cars with PI Cams. Is 10-15 HP about right for a car with minor mods (mods in sig) installing a cat back and UD pullys this winter.
1997 Thunderbird 4.6L LX (out of commission for now)
SCT XCAL 2 From Lonnie, 02 Mustang MAF and air box, Dynomax Cat Back Exhaust, Steeda U/D Pulleys, 70MM FRPP TB, Dual Piston Calipers, KVR Rotors, Alpine CD, Polk Speakers
1996 Thunderbird 4.6L LX Stock
1994 Thunderbird SC (Needs Work, for sale)
1996 Bronco XL - 2003 Escort ZX2 wrecked - 1996 Bronco XLT Sport
Project Car: 69 Lincoln Continental
JNT is offline
post #2 of 8 (permalink) Old 09-05-2004, 11:57 PM
whitecoug's Avatar
Send a message via AIM to whitecoug
If memory serve me correctly (not looking at the link) the kit contains the PI intake, adapter plates, coolant tube, and gaskets. I think that if you were to put the PI intake and the PI cams in, you might get close to 30 hp. But to keep it simple, you can simply use the NPI gaskets and some RTV with the PI intake and be done with it. That should yield around 10 hp or so. And it is a lot cheaper than the kit.
1994 Mercury Cougar XR7 4.6L Special Edition
PnP'd NPIs, PI Cams, PI intake, 80mm GT MAF, 24# Injectors, Shorty Headers, SCT Tuned, Jmod, Trans Cooler, 3.73's, Underdrives, Zex Dry kit 75 shot, Dirtydog TC, Trans built by Darrin, 97 Cupholders
219 RWHP/256 RWTQ NA
280 RWHP/343 RWTQ Bottle Fed (75 shot)
[email protected] mph 5/20/06
I feel sorry for the people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day.
whitecoug is offline
post #3 of 8 (permalink) Old 09-06-2004, 12:28 AM Thread Starter
JNT
JNT's Avatar
Thanks Joe.
I'm not planning on PI cams, at least not right now. I read your write up on installing the PI intake without the adapter. I'll most likely go this route. I don't want to spend $600 on the kit. I considered the adapter by itself but $300 is still pretty steep. Does anyone make an alternative adapter? I know some guys looked into having them made but that seems to have fallen apart.
JNT is offline
post #4 of 8 (permalink) Old 09-06-2004, 12:36 AM
Refrigerator Raider Hater
GreenBird's Avatar
Double? no way. JL and KD did this swap and did portmatching, and only got afew more hp than people who didn't port match at all. Is it better to port match? yes. However it is WAY beyond the point of diminishing returns.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #5 of 8 (permalink) Old 09-06-2004, 12:55 AM Thread Starter
JNT
JNT's Avatar
Thanks Greenbird. I thought double the HP sounded pretty optimistic.
JNT is offline
post #6 of 8 (permalink) Old 09-06-2004, 12:06 PM
Silver95Bird's Avatar
Do the portmatching with epoxy, then you need no RTV and have a much better sealing surface. 10-15HP peak, and more than that as the RPMs increase. What theyre doing is quoting HP at like 6000 RPMs instead of peak (mid 4000s).
Silver95Bird is offline
post #7 of 8 (permalink) Old 09-07-2004, 08:10 AM
ThunderB's Avatar
check here for the progress of the adapters:
http://www.hiperformancesolutions.com/index2.html
They are also working on an aluminum upper and lower intake for our cars as well as some 5.4 adapters to adapt the PI intake. Pretty cool company. they specialize in making hard-to-find or one-off parts. They said their PI adapters should be very affordable.
B
97 T-Bird Sport: Dynomax catback, Removed silencer w/ K&N panel, DReinhart chip, Lightning AGSF12-FM1 plugs/180 stat, Tokico 1.25" dropped stance, bye bye fender gap
'79 F100 SB : 300 ci six, Hurst Mastershift 3spd floor shifter, Offenhauser intake, Holley 4 brrl, EFI manifolds, Chebbie Rockers, Summit Racing 3.50 gearset, DISO 2.5" diesel muffler and 2.5" exhaust, Its'a six?!
ThunderB is offline
post #8 of 8 (permalink) Old 09-07-2004, 09:18 AM Thread Starter
JNT
JNT's Avatar
Yeah I've looked at that site, interesting stuff. Does anyone know if the PI intake and one of their adapters will fit under the stock hood?
JNT is offline
