Design II to Design III Injector Swap = Chip? - TCCoA Forums
post #1 of 5 (permalink) Old 09-10-2004, 09:23 AM Thread Starter
Question Design II to Design III Injector Swap = Chip?
Hopefully a simple question:
If I swap my 24 lb., design II injectors (in my 97 LSC) to 24 lb., design III injectors, will I have to be chip's/tuned for it to run ok.
I know a chip or tune would be optimal, but is it necessary?
69 F100 LWB w/460 Engine
post #2 of 5 (permalink) Old 09-13-2004, 08:33 PM
J.Miller's Avatar
I am not sure what you mean but if you mean the fat FRPP vs the thin Ford then it is a direct swap with no changes. Do you have a link?
J.Miller
East Coast Rolling Thunder!!!!
Official Eastern and Central PA chapter of the SCCoA!
J.Miller is offline
post #3 of 5 (permalink) Old 09-13-2004, 08:45 PM Thread Starter
I've never heard of them as "fat" vs. "thin", but we're probably thinking the same thing. The "thin" (or plastic body) are the "Design III's" and the "fat" (or metal body) are the "Design II's".
To my knowledge, the Design III's are a much better injector for atomizing the fuel since they have 4 small holes vs. the one larger hole for the design II's.
http://www.fiveomotorsport.com/Injector_SetsFORD.asp
I have some brand new 24 lb. Design III's that I'd like to put in my LSC (that has Design II's and 120K miles on them.) But I don't want to do this if I'll need a tune.
I'm thinking at cruise the O2's will make any necessary adjustments, and at WOT... I really don't care right now as long as it isn't lean..
Which I don't think will be a problem because when I had it dyno'd it wasn't lean to say the least.... 10:1 mixture at WOT..
Way, way too rich!! (I suspect partially blocked IMRC's is making it really rich).
post #4 of 5 (permalink) Old 09-13-2004, 09:01 PM
I may be crazy, but my "pink top" 19lb "gen II's" (fat) have four holes in the nozzle... as did my original injectors and the yellow top 19# injectors...
Best times:
Cougar281 is offline
post #5 of 5 (permalink) Old 09-13-2004, 09:13 PM
Like Titles Matter
kdanner's Avatar
Yes these need a new calibration to be done right. Battery voltage compensation is totally different between the two of them.
kdanner is offline
post #6 of 5 (permalink) Old 09-14-2004, 06:40 AM Thread Starter
Thanks! Not what I really wanted to hear though.
Oh well, it was a good idea.
I'll just wait until the Cobra intake install to also install these injectors.
