First dyno numbers....Opinions wanted - TCCoA Forums
post #1 of 9 (permalink) Old 09-14-2004, 05:49 PM Thread Starter
loopyj22's Avatar
Send a message via AIM to loopyj22
First dyno numbers....Opinions wanted-----PLEASE analize
These numbers were done before the PI intake and cams install as well as PnP...The outside temp was 98.3 with 87% humidity. First run was NA and second was on the bottle.
Mods in sig
What do you all think....any suggestions
BTW: Whats up with that A/F you like? <---- SARCASM, anybody know what it could be from
97 4.6L SOHC
(old times before headswap,PI cams, and PI intake)
N2O - 12.83 1/[email protected] --------- NA - 14.2 1/[email protected] mph
PnP NPI heads, PI intake with adaptor plates, crossover cooling mod, PI cams, 4100 lbs GVW, 2.25" true dual exhaust, Flowmaster 40 series, deleted cats, K&N cold air intake, 120HP NOS shot, NOS Programmable modulator, 80 psi fuel pump with reg., 9MM FRPP plug wires, Reinhart chip, Jmod, Mark8 T/C, FRPP 3.73 Alum. Rear-end, Dynotech MMC D/S, MSD coil packs, Custom ram air
94 T Bird Project Car
Planned installs: Ford 460ci motor, Tubbed rear-end with Dana 40 Axle, NOS power adder, new paint job, complete roll cage
loopyj22 is offline
post #2 of 9 (permalink) Old 09-14-2004, 07:47 PM Thread Starter
loopyj22's Avatar
Also what is a recommended air fuel ratio
97 4.6L SOHC
loopyj22 is offline
post #3 of 9 (permalink) Old 09-14-2004, 08:32 PM
RIP Jake
Leland Jacobson's Avatar
Your AF ratio, seems a tad high....I get nervous at 12.0 : 1 plus a couple tenths. I have been told optimum wot for my blown motor is 11.5:1 plus or minus a couple tenths... i'm sure some one will correct me... 14:1 on closed loop or a bit higher is common, but not on wot dyno runs....with nitrous, I would be verry nervous if that was over 12 while spraying, but hey, some people will regard it as job security, if they are building custom engines
Leland Jacobson is offline
post #4 of 9 (permalink) Old 09-14-2004, 08:43 PM Thread Starter
loopyj22's Avatar
yeah thats what ive been told as well....im gonna ail for something around low 12's on AF.....i need to get it tuned and hopefully that will take care of it
97 4.6L SOHC
loopyj22 is offline
post #5 of 9 (permalink) Old 09-14-2004, 10:17 PM
Silver95Bird's Avatar
that second run the TC unlocked... get a real dyno tune with the TC locked and the tranny commanded to stay in 3rd gear. feathering in the throttle in 3rd gear wont get an accurate reading either.
Silver95Bird is offline
post #6 of 9 (permalink) Old 09-14-2004, 11:12 PM Thread Starter
loopyj22's Avatar
silver95bird
umm...not sure about the TC locking but that second run was on the bottle thats why theres a jump.....Im new to dyno analizing so could you explain to me why you think each of those points is true so i can learn how to read the chart Thanks
97 4.6L SOHC
loopyj22 is offline
post #7 of 9 (permalink) Old 09-15-2004, 06:17 AM
My bad, I saw the giant torque spike and thought something was wrong... however it's still important to amke sure the run was TC locked/3rd gear, because otherwise all the numbers will be all out in left field. Can you verify this was done?
post #8 of 9 (permalink) Old 09-15-2004, 01:21 PM Thread Starter
loopyj22's Avatar
no i cant....it was at the NMRA meet this year in bradneton so i was a mobile dyno from diablo sport....i doubt they did.
97 4.6L SOHC
loopyj22 is offline
post #9 of 9 (permalink) Old 09-15-2004, 01:22 PM Thread Starter
loopyj22's Avatar
ill be posting new numbers soon with the new mods and sct tune
97 4.6L SOHC
loopyj22 is offline
