Anyone here use Comp Cams? - TCCoA Forums
post #1 of 35 (permalink) Old 09-14-2004, 09:14 PM Thread Starter
Send a message via AIM to 1997T-Bird Send a message via Yahoo to 1997T-Bird
I have read in article in MM&FF and was wondering about the gains on T-Birds with Comp Cams instead of the usual PI cams. Also, was tone A LOT more different than PI cams?
Just curious!
John
Currently: 2004 Honda Civic Ex 5 Speed
17X7 BSA Wheels - 215/45/17 Falkens; Complete JL System; Magnaflow Catback; Lowered 1.4"
Last Car:
Custom Magnaflow Dual Exhaust; 2003 Cobra Rims with Kelley 255/45/17s;Steeda U/Ds; B&M Transmissoin Cooler; Dirtyd0g's custom 2800 Stall Torque Converter; J-Mod Kit installed by Dirtyd0g; SCT Tuned by Darrin; Lowered with Spring Tech Springs
Want great work done on your tranny? Have dirtyd0g do it! He made a believer out of me!
1997T-Bird is offline
post #2 of 35 (permalink) Old 09-14-2004, 09:19 PM
Boom.
Palmguy's Avatar
There are good gains to be had with aftermarket cams. Personally I'm wary of Comp Cams after all the stories I've read about incorrect base circles and improper advance...but many people have good luck with them. You need to follow proper procedure when installing them to avoid problems.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #3 of 35 (permalink) Old 09-14-2004, 09:31 PM
RIP Jake
Leland Jacobson's Avatar
I have had really good results... well over 25 hp and better curves, but my original cams were experimental, and not worth do-do... the only rub was that one journal was tight and hadda be wiped (honed )to free up rotation, and yes, we put all the caps on the right journals the right way, so it was the cam, but a little correction and all's well....
Leland Jacobson is offline
post #4 of 35 (permalink) Old 09-14-2004, 09:34 PM Thread Starter
25 RWHP I am assuming of course.
Any tone differences from PI? I know PI gives us the Mustang blub blub blub, so what does Comp Cams give?
Last Car:
post #5 of 35 (permalink) Old 09-14-2004, 09:42 PM
RIP Jake
There is noticable idle in the form of a lope thats not unplesant, and tells anyone around my car that there aint stock cams in there...., and yes RWHP....
post #6 of 35 (permalink) Old 09-14-2004, 10:02 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
I use them.
JL
Fuelly
Johnny Langton is offline
post #7 of 35 (permalink) Old 09-15-2004, 12:11 AM
CEO Red Sox Nation
DMcBrideBoston's Avatar
Originally posted by Johnny Langton
I use them.
JL
So that's what makes ya so fast
GEtting mine next month
2003 Infiniti G35 Sport Package with Navigation
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
DMcBrideBoston is offline
post #8 of 35 (permalink) Old 09-15-2004, 12:26 AM
Still needs a clue
In all honesty, I think the times JL has produced with the numbers his engine puts out are very impressive. Skill of the driver and all. But I've been known to be wrong quite often...
mylittleblackbird is offline
post #9 of 35 (permalink) Old 09-15-2004, 06:04 AM
The car went 12's with stock cams ....
It should be a bit quicker with these.
JL
Fuelly
post #10 of 35 (permalink) Old 09-15-2004, 08:03 AM Thread Starter
JL
Damn... 12s on a 96/98 GT engine.. What would the Mach 1 guys say eh? Probably a lot of this ---->
Thanks for the input!
Last Car:
post #11 of 35 (permalink) Old 09-16-2004, 09:39 AM
I used them too.
Notice the past tense... I passed them on to someone who is putting them to good use now.
I will first address the QC "issues." Compcams had quite a few cam circle and journal issues last summer. They addressed those issues and for the most part are resolved. I bought mine last summer in the height of the controversy and spoke at length with Compcams about it and they explained what the problems were and what steps they took. I was satisfied. I had mine custom ground, so they did not come off-the-shelf. Mine were delayed two days because when they QC'd them, one was out of spec and they had to grind a new one. What I did was mic the base circles and journals and compare them to the PI cams I took out, and they were all right on, or within .003. I'm not sure when Leland purchased his, before or after Compcams addressed the promblem, but I think it was after, so it's still a good idea to check them before installation.
As far as "improper advance," the 270's (.55 lift for PI application only) are ground with a 5 degree advance. If they are bolted in without being properly degreed to accomodate the advance there can be VTP clearance issues. The solution is to properly install them, or have them ground without the 5 degree advance, if you choose to use the 270 grind cams.
For NPI application, you will want the 268 grinds anyway and there are no advance or PTV issues with those grinds. That's what I had, what JL has, what Hans Solo has, and probably what Leland has, but I don't know for sure.
OK.. about performance. Jerry tuned me to 223rwhp with the PI cams in August. In November he tuned me to 245rwhp. The only difference was the Compcams swapped in place of the PI's. The November tune was kept very conservative because of concerns about my 130K+mi bottom end. I would say that in a PNP NPI application the 268 grinds are probably worth at least 25-30 or so rwhp. Possibly a bit less in stock heads, but certainly worth the money...
Ask anyone that was at SSHS 3 what my car sounded like. Let's just say that heads turned and the words "got cams?" were heard often. The engine loped at idle and sang in the mid - high rpms.
-mike
96 GoldBird
N/A:
96 GoldBird is offline
post #12 of 35 (permalink) Old 09-16-2004, 09:40 AM
JL
If weather permits, we should know shortly... good luck, by the way...
-mike
96 GoldBird
N/A:
post #13 of 35 (permalink) Old 09-16-2004, 11:47 AM
Boom.
Palmguy's Avatar
Originally posted by 96 GoldBird
Yeah...I should have elaborated a bit more in my earlier post in this thread. There have been stellar numbers and performances from Comp Cams, and I really wasn't trying to scare anyone away from them due to past issues, just thought I'd mention that. What I didn't mention is that Comp has, from everything that I've seen, been outstanding as far as correcting it's problems.
TCCoA Gun Club
Palmguy is offline
post #14 of 35 (permalink) Old 09-16-2004, 02:35 PM
RIP Jake
Just remember to get the beehive valve springs that go with them and youll feel a lot better about hi RPMs, and yes I've got the 268 grinds.....
jake
post #15 of 35 (permalink) Old 09-16-2004, 02:46 PM Thread Starter
jake
Are the springs that much of an improvement over stock? I read the ad on them about superclean technology or something of the sort, not to mention lighterweight. That much of a difference?
Last Car:
post #16 of 35 (permalink) Old 09-16-2004, 02:47 PM
Boom.
Palmguy's Avatar
As Leland alluded to it is a "safety" issue for higher RPMs.
TCCoA Gun Club
Palmguy is offline
post #17 of 35 (permalink) Old 09-16-2004, 02:54 PM
You do NOT want to break a valve spring:
-mike
96 GoldBird
N/A:
post #18 of 35 (permalink) Old 09-16-2004, 05:54 PM
RIP Jake
Wink
They said most of the spiel....., also tho', the design is such that they prevent high RPM "bounce" on the seats, and will take you to higher rpms without the float that you get with stock springs...This means more power at higher rpms.
post #19 of 35 (permalink) Old 09-16-2004, 07:14 PM Thread Starter
Awesome! Well if I ever decided to mod the car that far, I will get Comp Cams/springs, because I don't want PIs I think.
Last Car:
post #20 of 35 (permalink) Old 09-16-2004, 07:19 PM
Any particular reason not to get PI's?
JL
Fuelly
post #21 of 35 (permalink) Old 09-16-2004, 07:34 PM Thread Starter
JL
Bigger gains from Comp Cams, and a more unique tone.
Last Car:
post #22 of 35 (permalink) Old 09-16-2004, 07:47 PM
Well,be warned-until you get it tuned.....it's gonna be a driveability nightmare.
Won't idle for ****,die all the time,etc,etc,etc..
It'll be perfect after a tune,but til then-it'll be a *****.
JL
Fuelly
post #23 of 35 (permalink) Old 09-16-2004, 07:50 PM Thread Starter
JL
Um... well what do you do when the tuning joint is 40 miles away??? (Will an auto shop tune it?) I thought the Apten Chip would do it.
Last Car:
post #24 of 35 (permalink) Old 09-16-2004, 07:50 PM
JL
Sounds familiar... I wonder why?...
Don't sugar-coat Johnny, tell it like it really is...
-mike
96 GoldBird
N/A:
post #25 of 35 (permalink) Old 09-16-2004, 08:03 PM
Oh, you'll probably be able to drive the car 40 miles, but an auto shop can't help you, unless they have SCT software and a ton of experience.
A chip can do it, but I'm not sure if Ken at MD (Apten) can get it right the first time. He can access my old tune, but I had more than just the cams, so it'lll take some adjustments...
Lonnie could probably get it right, but the best way is for the tuner to be able to drive the car.
Jerry and the other SCT guys drove my car around Atlanta on and off for two days tweaking it until they got it right... and those are the Guys That Know.
The off-the-shelf LSA version will be a bit more tame than mine were, but it'll still take some tuning by someone that knows what they are doing...
I know their site says the 268 will run on the stock EEC, but remember, these are competition cams, designed for competition cars and guys that will do what they gotta do to get the car to run...
-mike
96 GoldBird
N/A:
post #26 of 35 (permalink) Old 09-16-2004, 10:13 PM Thread Starter
Thanks for your input Goldbird, I am not sure if I will even go as far enough to get the new Cams. I was just curious if anyone in TCCoA had them on and their results w/ the cams.
Thanks again for everyone's input!
John
Last Car:
post #27 of 35 (permalink) Old 09-16-2004, 10:19 PM
Now I'm curious...are the Comp Cams better than the VT stage II's?
1997 Lincoln Mark VIII
1998 Contour SVT (for sale)
SloMo228 is offline
post #28 of 35 (permalink) Old 09-16-2004, 10:52 PM
John
Another thing to consider is that the Compcams are 3 times the cost of PI's. A pair of PI's run about $200.. Comps are close to $600..
-mike
96 GoldBird
N/A:
post #29 of 35 (permalink) Old 09-17-2004, 07:54 AM Thread Starter
-mike
Yeah I know, I looked at prices and what not, but then I saw that vid of JLs car....
Like I said, I doubt if I will ever get that far on the Bird, but if I do, those will be my #1 choice!
Thanks man,
John
Last Car:
post #30 of 35 (permalink) Old 09-17-2004, 08:37 AM
The cams JL runs are similar to the ones I ran, hell he told me exactly what I should buy.. My car sounded exactly the same.
When I close my eyes, I hear GB.. and it brings back very pleasant memories...
-mike
96 GoldBird
N/A:
