Major Mods on a budget - TCCoA Forums
post #1 of 5 (permalink) Old 09-15-2004, 10:57 AM Thread Starter
281_TBird's Avatar
Hey guys, Im still in the saving process right now, but I wanted your input on the thing I'm gonna do to my T-Bird.
PnP'd NPI or PI Heads.
PI Cams, or 268 Comp Cams
PI Intake or Bullitt Intake.
Accufab Plenum and TB.
3.73's or 4.10's
Mach 1 Converter or aftermarket one ?
MMX D/S
What do you guy suggest I'm on a budget so the comp cams and bullitt intake will probably not happen. But If I can get them fro a good price I'd use them. I just want to know what you guys think is a good perfromace/cost ratio. Thanks.
1997 Ford Thunderbird, Built NA 2V/ T-45
1997 Ford Explorer AWD 5.0L
2003 Lincoln LS V8 Bolt Ons
2009 Yamaha VMax
2011 F-150 Lariat Limited 6.2L 4WD
2015 Ford Mustang GT Premium, Performance Pack, Recaros
281_TBird is offline
post #2 of 5 (permalink) Old 09-15-2004, 11:34 AM
Boom.
Palmguy's Avatar
In the cases of the heads, cams, intake manifold and torque converter; you're going to spend approximately 5-10 times more on the aftermarket stuff than on Ford OEM stuff. You'll have to decide if it's worth that much more to you. There are good gains to be had with, for example, PI heads, PI cams, PI intake, and Marauder converter. There are even better gains to be had with, again for example, professionally worked NPI heads, Comp or VT cams, SVO intake, and a PI conveter. You'll pay a lot more though.
As far as the gears/DS, that's a good combo as well, you're really going to want a tune after all that so you have to take that into account as well.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #3 of 5 (permalink) Old 09-15-2004, 11:42 AM Thread Starter
281_TBird's Avatar
Thanks for the help. Would it be cheaper to just get PI heads or to get my NPI's PnP'd? I have heard that the pnp'd NPI's actually flow better than PI's. What is cheaper though? You would think maybe the PI's would be better becuase of teh bump in compression, and I don't plan on running a s/c.
2009 Yamaha VMax
post #4 of 5 (permalink) Old 09-15-2004, 01:06 PM
Rich95XR7's Avatar
Send a message via Yahoo to Rich95XR7
You can cut some money out on the driveshaft. The MMX is nice, but most people here don't need that much shaft. Call Denny's, they can get you one for over $100 cheaper, and with the same guarantee.
Rich95XR7 is offline
post #5 of 5 (permalink) Old 09-15-2004, 02:40 PM Thread Starter
281_TBird's Avatar
Cool. I'll check it out.
2009 Yamaha VMax
