help!! thermostat leak?? - TCCoA Forums
post #1 of 5 (permalink) Old 09-21-2004, 12:35 PM Thread Starter
I have replaced the thermostat with new o ring and it still leaks.(it only leaks a little bit) My question is, when I first opened the housing up to change the thermostat, the o ring was on the bottom of the thermostat. Is it supposed to be on top of the thermostat or below it? I know that it is not cracked for sure , just need to know what goes where . thanks guys
JACOB is offline
post #2 of 5 (permalink) Old 09-21-2004, 12:51 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I'm pretty damn sure mine was on the housing side.
-Rob
-Rob
Rob is offline
post #3 of 5 (permalink) Old 09-21-2004, 12:59 PM Thread Starter
Housing side?? so on top of the thermostat right? Screw it , i'm gonna put one on bottom and one on top, i'm sick of this small leak that has been troubling me for quite some time.
JACOB is offline
post #4 of 5 (permalink) Old 09-21-2004, 02:54 PM
try using a touch of RTV.
post #5 of 5 (permalink) Old 09-21-2004, 08:18 PM
scott's Avatar
The O ring should be on top of the T-stat.
Some non Ford T-stats are too small in diameter so the O ring falls
into the space around the T-stat instead of sitting on top of it.
If that's the case there is no "crush" on the O ring and ..................leak.
97 LX sport 4.6
T-45 5 speed, 3.73 with track lock; PI heads, 02 MAF, #24 injectors,190 fuel pump,JBAs, 75mm TB. ect,ect.; Aluminium drive shaft. 13" PBR Brakes; Dennis chip, lowered with solid sway bar bushings and hiem joints; console mounted E brake WITH the cup holders; C&l Plenum, Steeda U/D; VERY big radiator; 2.5" duals, Magnaflows;B&M ripper shifter; bla..bla...bla...
Lincoln MKVIII 93.........sweet ride.
Bag-less, lowered.
scott is offline
