Got a code p0430 while going to autozone today... - TCCoA Forums
post #1 of 30 (permalink) Old 09-21-2004, 04:12 PM Thread Starter
wilson502's Avatar
I went to autozone and scan the codes on my car and i got a p0430 which is catalyic efficeny below threshold bank 2. Now, my car runs fine, theres no smells whatsoever to speak of, no smoke out of the tail pipe. Its not using unusual amounts of oil, however my fuel efficiency has gone down, which leads me to the o2s. Any input on this, yes ive searched.
2007 White Ford Focus SE ZX3 Hatchback (The new driver)
1997 Alpine Green 4.6L Bird (SOLD!)
Mods:
Removed Air silencer, Clear Corners, Silverstar headlights and corner lights, Moroso Bluemax Spiral Core wires, Custom 3" Magnaflow exhaust with 2.5" Y-Pipe, 300-450 HP J-mod Kit by dirtyd0g , Hayden 30k GVWR Trans Cooler, Sport Front Suspension, 03-04 Cobra Rear Shocks, PBR Front Brake Swap, Xcal 2 by Lonnie @ Blueovalchips.com, 22C plugs, 180F T-stat, 02GT MAF/Airbox with K&N Drop in, Griffin Radiator, Cobra Water Pump
wilson502 is offline
post #2 of 30 (permalink) Old 09-21-2004, 04:15 PM
96dirtybird's Avatar
no input, more of a question........i live not too far from you, but does the local autozone check codes? my cel has been on for a few days, and my autozone is like 3 min from my house........just curious..........thanks
96dirtybird is offline
post #3 of 30 (permalink) Old 09-21-2004, 04:23 PM Thread Starter
wilson502's Avatar
yes, you can do it for free, what they do is, you give them ur ID, and you take the scanner out to the parking lot. Read the codes, write them down if u need to, then give it back.
Mods:
post #4 of 30 (permalink) Old 09-21-2004, 04:28 PM
ok, really stupid moronic question again, i'm still wet behind the ears on this stuff, i'l learning from u guys, but where does the scanner exactly plug into? where is the port?
post #5 of 30 (permalink) Old 09-21-2004, 05:19 PM
Rolling-Thunder's Avatar
Passenger side footwell, upper left
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #6 of 30 (permalink) Old 09-21-2004, 05:52 PM Thread Starter
wilson502's Avatar
so does that sound like a o2 sensor from what i described? Bank 2 is passenger side right?
Mods:
post #7 of 30 (permalink) Old 09-21-2004, 06:22 PM
Silver95Bird's Avatar
Bank 1 should be the side with the #1 cylinder (passenger side), therefore bank 2 holds cylinders 5-8 on the drivers side.
Silver95Bird is offline
post #8 of 30 (permalink) Old 09-21-2004, 06:32 PM
hey rollin-thun...............was that my answer, seems like it was. i know where it's at now. gracias!
post #9 of 30 (permalink) Old 09-22-2004, 02:06 PM Thread Starter
wilson502's Avatar
i erased the code, ill see if it comes back or not.
Mods:
post #10 of 30 (permalink) Old 09-22-2004, 04:33 PM Thread Starter
wilson502's Avatar
well the light stayed off for about 35-40 miles, and came right back on when i was driving home, i dunno whether its the cat, or the driver side o2s. Theres no smell. smoke, more the usual oil consumption. Car runs strong as always. Dont know what the deal is.
Mods:
post #11 of 30 (permalink) Old 09-22-2004, 04:37 PM
do you think you might need new o2's in there? I had to chg all 4 on mine not too long ago.
post #12 of 30 (permalink) Old 09-22-2004, 04:38 PM Thread Starter
wilson502's Avatar
im not sure, thats why im posting this.
Mods:
post #13 of 30 (permalink) Old 09-22-2004, 04:59 PM
motor city poster
Red96Bird's Avatar
i changed both of the rear o2's and reset the computer about a month ago and hasnt come back on since
Red96Bird is offline
post #14 of 30 (permalink) Old 09-22-2004, 05:33 PM Thread Starter
wilson502's Avatar
Did you get the same code i did? I hope its the o2s, but if the cats, ill get some magnaflow ones, they have ones that r 50 state legal. Are those hi-flow cats as well?
Mods:
post #15 of 30 (permalink) Old 09-22-2004, 08:58 PM
motor city poster
Red96Bird's Avatar
yea mine was also p0430...
i have no idea about the cats though
post #16 of 30 (permalink) Old 09-22-2004, 09:01 PM Thread Starter
wilson502's Avatar
So it would be the o2 sensor behind the driver side cat then? Also, whos the company that makes oem o2 sensors (Not Ford)? What sucks about california, i cant replace all the cats, only the driver side one (if its bad), kinda retarded to have a nice high flow driver side cat, and the stock OEM cats for the other 2. Theres no smell of rotten eggs after i shut the car off, no black smoke, even if i rev the engine. Runs like it alwas does.
Mods:
post #17 of 30 (permalink) Old 09-23-2004, 12:30 AM Thread Starter
wilson502's Avatar
Ill talk to my uncle tomorrow (master mechanic) and see what he has to say about my situation, if the cats were bad wouldnt i smell the rotten egg smell? Im thinkin its the rear o2 sensor, which i hope, cause a new cat will be more expensive than a new rear o2 sensor.
Mods:
post #18 of 30 (permalink) Old 09-23-2004, 01:00 AM
Sweet T
SanDiegoLXBird's Avatar
Awesome.. P0430.. My favorite code. If it's not accompanied by any other codes (those relating to bank 2 being rich, etc) I'd spend the 50 or 60 bucks and get a new rear 02 sensor for Dan once he's set up again. It's sure cheaper than 3-400 for a new cat. /If/ you can find somebody to do the work. Most places want you to replace the whole Y-pipe.
Also.. have you noticed your floors getting hot?
SanDiegoLXBird is offline
post #19 of 30 (permalink) Old 09-23-2004, 08:08 AM Thread Starter
wilson502's Avatar
negative, car feels the same as it always does, theres no smell from the car, i drive with the vent in the morning, i dont smell anything unusual. Floors arent hot, theres no smoke coming from the tail pipes (black,blue or white), even if i gun it/rev the engine.
Mods:
post #20 of 30 (permalink) Old 09-23-2004, 08:12 AM Thread Starter
wilson502's Avatar
If Dan isnt going get setup soon, i can buy it through my uncle who works at a lincoln mercury dealership and can get it to me at cost + 10% off. So im paying 90% cost.
Mods:
post #21 of 30 (permalink) Old 09-23-2004, 10:12 AM
Sweet T
Cool. If the floors aren't hot, I'd wager that its just the O2
post #22 of 30 (permalink) Old 09-23-2004, 02:56 PM Thread Starter
wilson502's Avatar
i was thinkin that to, the rear driver side o2 sensor. I also looked underneath the car after i drove it and looked at the cats, they looked normal meaning they werent red hot or anything. And the tail pipes didnt stink either.
Mods:
post #23 of 30 (permalink) Old 09-23-2004, 10:11 PM Thread Starter
wilson502's Avatar
i can get a after cat bosch oem o2 sensor for about $60, is that what i need?
Mods:
post #24 of 30 (permalink) Old 09-23-2004, 10:13 PM
Sweet T
If it can wait, just sit on it until Dan gets set up.. Or you can try calling Max at that one place he works (Five Star Ford ) and see if he's still doing club discounts. BUY FORD! Heh. I wouldn't trust bosch to put air in my tires. IIRC it's about the same price.
post #25 of 30 (permalink) Old 09-23-2004, 10:43 PM
Then you better swap out your O2's, IIRC Bosch makes them for Ford.
http://forums.tccoa.com/showthread.p...light=bosch+O2
post #26 of 30 (permalink) Old 09-23-2004, 10:53 PM Thread Starter
wilson502's Avatar
i was just gonna say that SanDiego Bird that Bosch makes o2 sensors for ford, i heard NTK does to. What about denso?
Mods:
post #27 of 30 (permalink) Old 09-23-2004, 10:55 PM
Sweet T
Now that you mention it... but even though they make them for ford aren't there two different connections? I could swear I read something along those lines not too long ago..
post #28 of 30 (permalink) Old 09-24-2004, 12:03 AM Thread Starter
wilson502's Avatar
maybe for their universal units, not their OEM units.
Mods:
post #29 of 30 (permalink) Old 09-24-2004, 07:43 PM
Moderator & Teksid Whore
guitar maestro's Avatar
Bosch O2s work just fine in my car.....The Man didnt have any problem tuning the car with them when it was bone-stock..........i would have bought them from Dan, but this was before i knew about TCCoA and bought them at Autozone instead
guitar maestro is offline
post #30 of 30 (permalink) Old 09-25-2004, 12:52 AM Thread Starter
wilson502's Avatar
my uncle will get me some o2 sensors when he goes back to work, he just had surgery, so i have to wait about 2 weeks or so.
Mods:
