I've got a question... - TCCoA Forums
post #1 of 25 (permalink) Old 09-22-2004, 06:53 PM Thread Starter
On the engine issue... I know it's not completely related, but wouldn't an NPI engine re-fitted with PI heads make more power than a PI engine? Because of the higher compression and all. I've asked this question before and I didn't get a straight answer, so I reworded it and asked again. Also, searching is useless since all I get are flame wars about NPI vs. PI. I'm thinking I'm gonna get an NPI motor and put PI heads on it instead of buying a PI motor, especially if they actually do make more power.
1997 Lincoln Mark VIII
1998 Contour SVT (for sale)
SloMo228 is offline
post #2 of 25 (permalink) Old 09-22-2004, 07:10 PM
CEO Red Sox Nation
DMcBrideBoston's Avatar
I can't see how they'd make MORE power, I'd say less or equal but not more.....so I'd like to know also.
Dave
2003 Infiniti G35 Sport Package with Navigation
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
DMcBrideBoston is offline
post #3 of 25 (permalink) Old 09-22-2004, 07:20 PM
Still needs a clue
I thought(and this could be misinformation) that I read somewhere that the PI engines have deeper dished pistons. Mind you I don't know for a fact, that is just something that jumped to my mind. I could have it completely wrong.
mylittleblackbird is offline
post #4 of 25 (permalink) Old 09-22-2004, 08:15 PM Thread Starter
Yeah, engines that came with PI heads (PI engines) had dished pistons, the CR on a PI engine is the same as that on a NPI-headed NPI engine. At least, that's how I understand it. So, a PI-headed NPI engine should have a higher CR. If what I've heard is true, anyway... But I suppose it's a moot point, since I'm looking at forged internals and I can just get whatever dish I need. I'm still curious, though.
SloMo228 is offline
post #5 of 25 (permalink) Old 09-22-2004, 08:41 PM
MaleWhore
smokymance's Avatar
PnP NPIs and the will make some hella power...even better than PIs
smokymance is offline
post #6 of 25 (permalink) Old 09-22-2004, 09:02 PM
JR Tigerstar's Avatar
My '96 NPI short block with PI heads, stock exhaust manifolds, high flow cats & a 2 in/1 out mid-mounted MagnaFlow muffler dynoed at 229 rwhp & 272 rwtq.
Hopefully, one of the Explorer swap fellas will chime in with dyno numbers.
Please let us not start another NPI vs. PI debate. Please.
JR Tigerstar is offline
post #7 of 25 (permalink) Old 09-22-2004, 09:05 PM
MaleWhore
smokymance's Avatar
oh i know...i now just realized that stating anything on what makes more power just gives me less power ....
post #8 of 25 (permalink) Old 09-22-2004, 09:07 PM
96bird's Avatar
Yes PI heads on a non-PI block should make more power with equal mods. The extra point or so in compression will yield 5% or so more power across the board.
96bird is offline
post #9 of 25 (permalink) Old 09-22-2004, 09:41 PM Thread Starter
Cool. That's what I suspected, it's good to hear a concurrent opinion.
SloMo228 is offline
post #10 of 25 (permalink) Old 09-22-2004, 09:54 PM
Still needs a clue
so that means... I was right?!? WOW!
post #11 of 25 (permalink) Old 09-22-2004, 10:02 PM
If the 5% is true, that is a plus over the Explorer engine.
The aluminum Explorer engine weighs, what, 75-100 lbs. less than the iron block.
5% more power or 75-100 lbs reduction.
Which is better?
post #12 of 25 (permalink) Old 09-22-2004, 10:11 PM
Still needs a clue
Just take the exploder block and put NPI pistons in it with PI heads, there you go. Hell, shave the heads while your at it!
post #13 of 25 (permalink) Old 09-22-2004, 11:15 PM
96bird's Avatar
Shaving your heads isn't a good idea (timing chains come to mind)...you should be able to search around for the answer to that one. Personally I would grab the exploder engine and lose the weight. If you are going to stay NA and want aftermarket cams...I would get the Flat top pistons (not stock NPI though..forged instead) to put in the explorer engine though.
Russell
96bird is offline
post #14 of 25 (permalink) Old 09-23-2004, 11:10 AM Thread Starter
That's what my long-term goals are. Aluminum block, fully worked heads and some nice lopey cams, flat top pistons with forged rods and crank, and a wee little shot of nitrous, like a 75 or 100.
SloMo228 is offline
post #15 of 25 (permalink) Old 09-23-2004, 11:31 AM
NPI heads will outflow PI heads any day. Now, our stock NPI heads will not out flow PI heads, but 98 mustang NPI heads will. Of course you will have to do a lot of porting work on these heads, and so will you on the PI heads.
The reason the 98 heads are better is because in our heads, in the intake side, there is a water passage in there, you cannot grind away as much metal in the heads as you can on 98 heads(NPI of course). The reason I say 98 because they have a casting number, (don't remember what it is right now), on them that identifies what they are. I think there was some in 97 that had the same casting numbers.
Take it for what its worth.
If the PI heads where better, don't you think JL would be running them, and other guys for that matter.
I think a lot of people got in there heads that the PI heads outperform the NPI heads, in which they do not.
Hope this makes any sense.
Nick
post #16 of 25 (permalink) Old 09-23-2004, 11:45 AM
... but wouldn't an NPI engine re-fitted with PI heads make more power than a PI engine? Because of the higher compression and all. I've asked this question before and I didn't get a straight answer, so I reworded it and asked again. Also, searching is useless since all I get are flame wars about NPI vs. PI.
Originally posted by badbird95
NPI heads will outflow PI heads any day. Now, our stock NPI heads will not out flow PI heads, but 98 mustang NPI heads will. I think a lot of people got in there heads that the PI heads outperform the NPI heads, in which they do not.
Nick
post #17 of 25 (permalink) Old 09-23-2004, 12:25 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
Nick
i thought 96-98 non pi heads were all the same? they're all F5 casting. the F4 casting was used from 91-95.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #18 of 25 (permalink) Old 09-23-2004, 12:51 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Frank
I agree!
-Rob
Rob is offline
post #19 of 25 (permalink) Old 09-23-2004, 02:01 PM
Yes you are correct on the F5, F4 part.
But the number you are looking for(finally found it), is at the end of the casting number.
Also, I was wrong on the 98 part, it was 96-98 with the casting number.
The numbers are:
B22A
B24A
These heads will out - flow PI's any day, properly ported mind you.
Of course, you have to have the heads off to check the #'s.
I have a set at the house that I'm currently working on for my brothers Stang.
Nick
post #20 of 25 (permalink) Old 09-23-2004, 03:00 PM
Silver95Bird's Avatar
I have yet to see how any F5AE casting is any different from any other F5AE casting.
Silver95Bird is offline
post #21 of 25 (permalink) Old 09-23-2004, 07:46 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
2007 Dodge Ram 1500
Previous Rides:
post #22 of 25 (permalink) Old 09-25-2004, 07:20 PM
ITT-BIRD's Avatar
OK this is what ive picked up over the yrs.
NEVER want to try to use 91-95 heads w/o at least doing springs but are still pretty worthless to PNP. All referals below NPI heads are from 96-98.
Stock NPI heads will not flow better than Stock PI heads.
PNP NPI heads will flow better than Stock PI heads.
PNP NPI head will still outflow PNP PI heads but not by too much.
Stock NPI 4.6 has a CR of 9.1:1 as the Stock PI 4.6 has CR of 9.3:1.
Stock NPI 4.6 bottom end with PI heads will raise CR to 10.1 or so:1. Thus producing near the same power as Stock PI.
Stock NPI 4.6 bottom end with PI heads, PI intake, PI cams will have raised CR and have more power over Stock PI 4.6.
Stock NPI 4.6 bottom end with PNP NPI head, PI intake, PI cams will both have raised CR but have better flow than Stock NPI 4.6 bottom end with Stock PI heads, PI intake, PI cams. Not sure of PNP PI heads would do.
Then you can also do the combo of Stock NPI 4.6 w/ Stock heads (96-98), PI cams, PI intake will still have 9.1 CR but may produce the same or more power than Stock PI 4.6.
Ok i think that about wraps it up... if anything is wrong or have added info please feel free to educate me. I like to learn more everyday so i may post correct info often.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #23 of 25 (permalink) Old 09-25-2004, 08:50 PM Thread Starter
I think I'll go with the Bullitt intake, ported NPIs, VT Stage IIs, and high-compression forged internals. Heck, why not throw a stroker kit and an overbore on there while we're at it?
SloMo228 is offline
post #24 of 25 (permalink) Old 09-27-2004, 02:55 PM
infectrus's Avatar
Send a message via AIM to infectrus
a pi engine comes with better pistons, and i think that the compression ratio is higher (if im wrong, slap me) but my guess is that there pretty close
1990 Nissan 300ZX N/A 5-Speed
222hp, 190tq
0-100km/h: 6.6sec (lotsa wheel hop)
Top speed: Hit Fule cut off at 146mph..(not bad for stock)
Future mods:
Greddy body kit; Nissan 350z "Lemans sunset" paint; TT swap with lotsa upgrades and greddy e-man.
Stock for now
infectrus is offline
post #25 of 25 (permalink) Old 09-27-2004, 03:06 PM
02 Explorer Pioneer
timb's Avatar
Pi engines do not have better pistons they are made of the same material but they do have a dish in them so no they also do not have higher compression. You would have higher compression if you compined NPI pistons with PI heads
Birdless
timb is offline
