mods not making me faster help - TCCoA Forums
post #1 of 4 (permalink) Old 07-22-2002, 12:44 PM Thread Starter
hey i have a 94 4.6 lx. since i got the car i have been modding it . i got ud pullys then kn panel filter filter then the j mod +l maf and i got the car it was great. now i just got a crome intake tube fom a diffrent car but it fits good and a cone kn filter. then i got the 2 cats cut off and had a custom true dual 2 chamber flos put on and my car isnt any faster then when i got the comp done. do u think i need my comp reprogrammed again? any help or any more mods that i can do would be appreciated.
Rino is offline
post #2 of 4 (permalink) Old 07-22-2002, 01:14 PM
Robinson's Avatar
Send a message via AIM to Robinson
you might have killed some low end torque with the true dual setup. these bolt ons arent going to do much to wake up the car. im sure it is a little faster than it was before, but im not suprised that you havent noticed a huge difference.
IMHO, do exhaust on a stock car for the sound, not the performance.
the intake tube might have free'd up some horsepower, but will mostly improve your throttle responce.
www.innerlusion.com
89 SC 5 speed
FCoNE President
Robinson is offline
post #3 of 4 (permalink) Old 07-22-2002, 01:22 PM
MagerThom's Avatar
Unhappy Are you SURE you're....
no faster? Have you quarter miled or dyno'd your 'Bird since
you did all those mods? Whose chip are you using?
Remember one thing though, assuming you're running stock heads -
you're a victim of a pretty restrictive design (at least stock)
and my best GUESS is the MAX you might expect from what you've
done is maybe a 15-20rwhp increase which is not going to make
a BIG difference in performance on our heavy cars....other
opinions?
Mager Thom
1997 AED Thunderbird LX
287RWHP 345RWTQ
"It's ALL about air flow...eveything else...is tuning..."
MagerThom is offline
post #4 of 4 (permalink) Old 07-22-2002, 05:43 PM
WaLieN's Avatar
Send a message via AIM to WaLieN
If you want a noticeable improvement, then get some 3.73 gears, and get your chip reburned. It's cheap, and you'll notice improvements on your 1/4 times.
☼1997 Ford Thunderbird LX - 4.6L -K&N Panel Filter-Steeda U|D Pulleys-Steeda 180* Thermostat-Removed Intake Silencer-Polyurethane IRS Bushings-Tranny Cooler-Urethane Tranny Mount
☼1993 Mazda RX-7 Touring [VR] - Rotary Power rebuilt turbos & motor w/ 3mm Apex Seals - PWR Radiator - PFS Cat-Back - RB Intake Duct w/ K&N Panel - Manual Boost Controller - KG Differential Brace - Gotham Engine Torque Brace - Aluminum 45mm Front STB - B&M Short Throw Shifter - PFS Column Mounted Boost Gauge - Falken Azenis ST115s [235/40ZR17] on Speedy Mashie Silvers
WaLieN is offline
