How can I run underdrive pulleys with a big stereo? - TCCoA Forums
post #1 of 10 (permalink) Old 07-22-2002, 04:15 PM Thread Starter
bmac's Avatar
Send a message via AIM to bmac Send a message via Yahoo to bmac
Question How can I run underdrive pulleys with a big stereo?
Is there a way to run them with out going through batteries / alternators?
Brian Macfadden
Look Good, Be Loud & Go Fast!
1997 Ford Thunderbird LX
bmac is offline
post #2 of 10 (permalink) Old 07-22-2002, 04:29 PM
NickFL's Avatar
Send a message via AIM to NickFL Send a message via Yahoo to NickFL
I am running...
...ASP underdrive pullies right now. How big are you going to go? I do not have any problems with charging. I do get the needle twitch on my volt gauge, but other than that, I have not experienced any problems.
I have two amps...
JBL 1200.1 and JBL 80.4
I have two Bostwick 12's
Again, I dont know how big you want to go, but I am not experiencing any problems ::knocking on wood::!!!
Later, NickFL
2004 COBRA COUPE #3036 of 3768 OXFORD WHITE; 601.5 RWHP @ 6450 RPM; 595.2 lb/ft Torque @ 3750 RPM; 18* Timing | 18.5 PSI Boost | 11.94 AF
Whipple 2.3L | Steeda idler | Reichard idler pulleys | Metco 2# Lower | Reichard 3.0 Upper | Magnaflow Catted X-pipe | Magnaflow Catback | Focus Pumps | 8AN lines | CPR rails | SD 60lb injectors | TR6 Plugs | Revolution chip | MAFiA | BBK T-body | Steeda CAI | Custom heat exchanger | Royal Purple coolant additive | Kenny Brown super subs | Steeda lowering springs | IRS bushings | IRS weld in braces | FPDM rewire | MT ET Street Radials | Centerforce clutch | Steeda billet quad and cable | Lunar boost and fuel gauges | Autometer gauge panel
NickFL is offline
post #3 of 10 (permalink) Old 07-22-2002, 04:40 PM Thread Starter
bmac's Avatar
when I am rolling with my stereo going (hard) and A/C I'm right at 14 amps but at night when you add the head lights it goes down to 12.5.
Are you running your amps at 2 Ohms or 4 Ohms?
Brian Macfadden
bmac is offline
post #4 of 10 (permalink) Old 07-22-2002, 04:45 PM
NickFL's Avatar
Well...
...I am not a stereo guru. The amp that drives the subs is a JBL 1200.1 (1 channel x 1200w), and the amp that drives the front speakers is the JBL 80.4 (4 channel x 80w). Your setup looks sweet! Yours looks much cleaner than mine! Nice job.
Later, NickFL
NickFL is offline
post #5 of 10 (permalink) Old 07-22-2002, 04:54 PM Thread Starter
bmac's Avatar
Well if the amps are at 4 Ohms they are 600.1 and 40.4 but if they’re at 2 Ohms than they are 1200.1 and 80.4. 1200 watts sounds like a lot for the 2 subs you have so I’m guessing your running them at 4 Ohms.
As far for my install THANKS but all I did was give my installer a lot of my paychecks
From JBL's Web Site
Specifications
Output 4 Ohms: 600W x 1
Output 2 Ohms: 1200W x 1
Signal-to-Noise (dBA): >100
Frequency Response (±3dB): 20Hz - 500Hz
Total Harmonic Distortion: 0.1%
Input Sensitivity: 250mV - 4V
Brian Macfadden
bmac is offline
post #6 of 10 (permalink) Old 07-22-2002, 05:30 PM
WaLieN's Avatar
Send a message via AIM to WaLieN
That's good to know. My system isn't going to be even half as nutty as that... hehe.
☼1997 Ford Thunderbird LX - 4.6L -K&N Panel Filter-Steeda U|D Pulleys-Steeda 180* Thermostat-Removed Intake Silencer-Polyurethane IRS Bushings-Tranny Cooler-Urethane Tranny Mount
☼1993 Mazda RX-7 Touring [VR] - Rotary Power rebuilt turbos & motor w/ 3mm Apex Seals - PWR Radiator - PFS Cat-Back - RB Intake Duct w/ K&N Panel - Manual Boost Controller - KG Differential Brace - Gotham Engine Torque Brace - Aluminum 45mm Front STB - B&M Short Throw Shifter - PFS Column Mounted Boost Gauge - Falken Azenis ST115s [235/40ZR17] on Speedy Mashie Silvers
WaLieN is offline
post #7 of 10 (permalink) Old 07-22-2002, 11:23 PM
Not Blinking Anymore
KewlBird's Avatar
Send a message via AIM to KewlBird
Well I had March Underdrive pulleys, Anytime I turned ac on or lights the voltage would drop down to 12's, I installed a sub and realized that I won't have enough juice to run ac and the sub at the same time. So pulled them off, after a few weeks I took the sub out. Now I'm planning on putting them back in (there is noticable power at highway speed, when you punch it the car increases speed faster).
1996 Ford Thunderbird LX 4.6L -
1994 Ford Thunderbird LX 3.8L
2002 Chevrolet Blazer 4D 4WD
2002 Chevrolet Impala
http://members.tccoa.com/kewlbird/
KewlBird is offline
post #8 of 10 (permalink) Old 07-23-2002, 02:54 PM
The Hitman's Avatar
I had ASP's on my Thunderbird and they did really well. I didn't have a system in the car but I didn't experience any charging problems. ASP's are supposedly one of the better brands to buy if you have a system because they alternator pulley isn't as large as some brands. The pulleys on my Mustang are a different story. HAHAHA This thing dims like a mother at idle.
1995 Mustang GT
Bolt ons. Stock H/C/I for now.
13.2
2001 Sentra SE
Short Ram Intake only.
15.3
Kerry/Edwards '04
The Hitman is offline
post #9 of 10 (permalink) Old 07-23-2002, 10:03 PM
BR1
Send a message via AIM to BR1
i have a RF power 1500.1 that is sheeted at 1698 watts, and i have a RF power 360.2 that is sheeted at 482 watts. those are RMS numbers. i have FRPP underdrives, a stinger deep cycle in the trunk, and stock alternator at 130 amps. i have no problems at all. when i'm at idle, and pounding it, i do see the autometer gauge i have installed bounce from >14 to around 12 volts. but its an instantaneous thing. even at night with the lights on, its aroudn 13 volts or so. the underdrive pulley is not that much larger than the stock pulley, they make most of it up on the crank and water pump. there should be no worries with them.
J-chipped
90mm Lmaf, GT tube
magnaflow exhaust
FRPP pulleys
17x9 Cobra R chrome
255/45/17, 245/45/17 potenzaRE-730
13" cobra brakes, KVR rotors
1.25" addco rear bar
mark VIII driveshaft
bilsteins & tokico springs
BR1 is offline
post #10 of 10 (permalink) Old 07-23-2002, 10:23 PM Thread Starter
bmac's Avatar
COOL thanks guys
Now the new question
Brian Macfadden
bmac is offline
