Stock compression/torque? - TCCoA Forums
post #1 of 2 (permalink) Old 07-22-2002, 05:22 PM Thread Starter
WaLieN's Avatar
Send a message via AIM to WaLieN
From some sites, I'm hearing 10:1, some 9:1. Also, I hear 260lb-ft and 280lb-ft, which is it?
☼1997 Ford Thunderbird LX - 4.6L -K&N Panel Filter-Steeda U|D Pulleys-Steeda 180* Thermostat-Removed Intake Silencer-Polyurethane IRS Bushings-Tranny Cooler-Urethane Tranny Mount
☼1993 Mazda RX-7 Touring [VR] - Rotary Power rebuilt turbos & motor w/ 3mm Apex Seals - PWR Radiator - PFS Cat-Back - RB Intake Duct w/ K&N Panel - Manual Boost Controller - KG Differential Brace - Gotham Engine Torque Brace - Aluminum 45mm Front STB - B&M Short Throw Shifter - PFS Column Mounted Boost Gauge - Falken Azenis ST115s [235/40ZR17] on Speedy Mashie Silvers
WaLieN is offline
post #2 of 2 (permalink) Old 07-22-2002, 06:33 PM
Robinson's Avatar
Send a message via AIM to Robinson
tech articles are your friend
Compression ratio 9.0:1
'96-'97 HP & TQ SAE-net 205 hp @ 4,250 rpm
280 lbs.-ft. of torque @ 3,000 rpm
www.innerlusion.com
89 SC 5 speed
FCoNE President
Robinson is offline
