I'm wondering... - TCCoA Forums
post #1 of 7 (permalink) Old 07-22-2002, 08:55 PM Thread Starter
NickFL's Avatar
Send a message via AIM to NickFL Send a message via Yahoo to NickFL
I'm wondering...
...if I should cut out the first two cats. From what I have read, or what I understand, I will not experience any problems as long as I leave the sensors in place and get the MIL eliminators, or get that burned in my chip. Do the drawbacks outweigh the benefits? I am getting ready to order my chip from Dennis, and I just need to know what to tell him to burn.
Later, NickFL
2004 COBRA COUPE #3036 of 3768 OXFORD WHITE; 601.5 RWHP @ 6450 RPM; 595.2 lb/ft Torque @ 3750 RPM; 18* Timing | 18.5 PSI Boost | 11.94 AF
Whipple 2.3L | Steeda idler | Reichard idler pulleys | Metco 2# Lower | Reichard 3.0 Upper | Magnaflow Catted X-pipe | Magnaflow Catback | Focus Pumps | 8AN lines | CPR rails | SD 60lb injectors | TR6 Plugs | Revolution chip | MAFiA | BBK T-body | Steeda CAI | Custom heat exchanger | Royal Purple coolant additive | Kenny Brown super subs | Steeda lowering springs | IRS bushings | IRS weld in braces | FPDM rewire | MT ET Street Radials | Centerforce clutch | Steeda billet quad and cable | Lunar boost and fuel gauges | Autometer gauge panel
NickFL is offline
post #2 of 7 (permalink) Old 07-22-2002, 08:59 PM
Send a message via AIM to BlackBandit
Are you planing to run straight pipes? If not then I'd leave them in. Acid Rain will mess up.
-Thomas
95 Thunderbird LX
K&N Panel
Ram Air
180* T-stat
BlackBandit is offline
post #3 of 7 (permalink) Old 07-22-2002, 09:19 PM
Send a message via AIM to Evil Bird
if you want to...
take off the mufflers and run strait pipes from there, but you need the back pressure from those cats. i heard from some of the people on here that a stock bird with strait pipes loose power. if you want to, get high flow cats. i prefer MAC ones.
latre,
jordan
i used to have a: 96 Thunderbird Sport LX
115 shot of Nos; JBA headers; Mac Underdrive pullies; SVO 70mm Throttle Body; Accufab fuel regulator; Mac Intake; 1 step colder plugs and stuff
Evil Bird is offline
post #4 of 7 (permalink) Old 07-23-2002, 01:22 AM
MagerThom's Avatar
Talking Have Dennis shut off the O2 sensors on your
new chip. That way you can do whatever you want, whenever
you want to your exhaust...cats,.....no cats,....whatever.
There's always the ART system (drool) available to you a couple
hours away in Miami....cats,....no cats,....high flow cats,
once again whatever you want.
What are you doing as far as a MAF.....?
Mager Thom
1997 AED Thunderbird LX
287RWHP 345RWTQ
"It's ALL about air flow...eveything else...is tuning..."
MagerThom is offline
post #5 of 7 (permalink) Old 07-23-2002, 09:17 AM Thread Starter
NickFL's Avatar
Well...
I have the 80mm LMAF. I asked Dennis if I should go with the Mustang MAF instead of the LMAF, but he said to just stick with the LM. I will sell the LMAF if the Mustang MAF is better. I got a pretty good deal on it. What do you think? Also, what about filter setups with each MAF?
Later, NickFL
NickFL is offline
post #6 of 7 (permalink) Old 07-23-2002, 11:54 AM
MagerThom's Avatar
Talking I'd go with what Dennis told you...
the theory behind the GT Mustang MAF is that it's designed for
a lower volume of air (NA) and that by using a lager percentage
of the transfer functions (table) in the GT Mustang MAF your
metering is theoretically more accurate than using a smaller
percentage of the LMAF's (larger) transfer functions (table).
I suppose this is all true, but if Dennis didn't feel it was
necessary to make the switch, then I wouldn't worry about it.
I'm ASSUMING he's getting that info from "you know who" -
if that's the case, I'd feel very comfortable using the (L) MAF
you have.
As far as filter setups - THAT is a controversy that will never
go away. Simply put - I haven't found K&N filters to be a problem
with respect to MAF wire oiling (so far). They shouldn't be
cleaned very often, unless they practically have a solid coating
of mud on them - I posted a long writeup in the old Forums on
proper oiling techniques a few months ago. If you want to read it,
I'll find it for you.
Cone or panel filter? I've gone back to using a K&N panel filter,
from using an Autophysics cone, and my stock air box of course,
simply because it's simple and easy to maintain and I've got a
totally sealed system that keeps heated under hood air from
elevating my intake charge. No one, so far, has proven a cone of
the same surface area provides any additional power. I suppose they
do provide a certain level of satisfaction with respect to the
wood factor however and that's the main reason, I'm guessing , you
see so many of them being used. If you want to use the oem style
paper filter instead - go for it, just change 'em pretty often.
Good luck with the mods, I hope this helps,
Mager Thom
287RWHP 345RWTQ
post #7 of 7 (permalink) Old 07-23-2002, 12:14 PM
Refrigerator Raider Hater
GreenBird's Avatar
Re: I'd go with what Dennis told you...
Originally posted by MagerThom
I posted a long writeup in the old Forums on proper oiling techniques a few months ago.
If you want to read it, I'll find it for you.
I think you should find it and send a copy to both boards to be a tech article. You did an excellent job writing that up.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
