Temperature Sensor - TCCoA Forums
post #1 of 2 (permalink) Old 07-22-2002, 09:24 PM Thread Starter
Question Temperature Sensor
I AM INSTALING A WATER TEMP. GUAGE IN MY BIRD AND I NEED TO KNOW WHERE THE TEMPERATURE SENDER IS SO THAT I CAN HOOK IT UP, I HAVENT THE SLIGHTEST, PLEASE HELP
96V8 is offline
post #2 of 2 (permalink) Old 07-23-2002, 10:05 PM
BR1
Send a message via AIM to BR1
well, is it mechanical or electrical? i assume you have a 4.6, 1996? i drilled and tapped a hole in the water neck, thermostat outlet thing. use lots of teflon too. it doesn't leak one bit on mine. i don't think this is the best place to put it, but it works quite well for me, and it gives the temp of the water coming out of the engine, not the water going into the engine.
J-chipped
90mm Lmaf, GT tube
magnaflow exhaust
FRPP pulleys
17x9 Cobra R chrome
255/45/17, 245/45/17 potenzaRE-730
13" cobra brakes, KVR rotors
1.25" addco rear bar
mark VIII driveshaft
bilsteins & tokico springs
BR1 is offline
