Headers ? - TCCoA Forums
post #1 of 6 (permalink) Old 07-22-2002, 11:14 PM Thread Starter
scott's Avatar
Headers ?
Is JBA the only way to go or is there some thing else available?
97 LX sport 4.6
T-45 5 speed, 3.73 with track lock; PI heads, 02 MAF, #24 injectors,190 fuel pump,JBAs, 75mm TB. ect,ect.; Aluminium drive shaft. 13" PBR Brakes; Dennis chip, lowered with solid sway bar bushings and hiem joints; console mounted E brake WITH the cup holders; C&l Plenum, Steeda U/D; VERY big radiator; 2.5" duals, Magnaflows;B&M ripper shifter; bla..bla...bla...
Lincoln MKVIII 93.........sweet ride.
Bag-less, lowered.
scott is offline
post #2 of 6 (permalink) Old 07-23-2002, 01:26 AM
WaLieN's Avatar
Send a message via AIM to WaLieN
From what I've found, yes, JBA is the ONLY ones that'll fit in our birds. That's why they can charge so much, too.
☼1997 Ford Thunderbird LX - 4.6L -K&N Panel Filter-Steeda U|D Pulleys-Steeda 180* Thermostat-Removed Intake Silencer-Polyurethane IRS Bushings-Tranny Cooler-Urethane Tranny Mount
☼1993 Mazda RX-7 Touring [VR] - Rotary Power rebuilt turbos & motor w/ 3mm Apex Seals - PWR Radiator - PFS Cat-Back - RB Intake Duct w/ K&N Panel - Manual Boost Controller - KG Differential Brace - Gotham Engine Torque Brace - Aluminum 45mm Front STB - B&M Short Throw Shifter - PFS Column Mounted Boost Gauge - Falken Azenis ST115s [235/40ZR17] on Speedy Mashie Silvers
WaLieN is offline
post #3 of 6 (permalink) Old 07-23-2002, 07:24 AM
WhiteBird101's Avatar
theres always another option. Make your own longtubes!
Bird Page
'95 v8 T-bird, 126+K, Tune, "faux" jmod trans, 245 BFG's for grip, "ghetto" intake - Blown Head Gasket
e.t. = 15.3 @ 93 mph
Bird of a different feather - 1999 NBM Pontiac Trans Am, 5.7l LS1 V8 - SLP lid, Borlamouth exhaust. [email protected]
WhiteBird101 is offline
post #4 of 6 (permalink) Old 07-23-2002, 02:57 PM
The Hitman's Avatar
That would be the most awesome thing ever!
1995 Mustang GT
Bolt ons. Stock H/C/I for now.
13.2
2001 Sentra SE
Short Ram Intake only.
15.3
Kerry/Edwards '04
The Hitman is offline
post #5 of 6 (permalink) Old 07-23-2002, 03:31 PM
I'm actually doing just that. I bought a set of used MAC longtubes for a 99GT for $160 and as soon as the motor is ready to go in, we are going to start fabbing the headers as they need be. The only bastard is going to be the drivers side. I'm going to have to get a friend of mine (builds cages and fabs sheetmetals crap for race cars) to extend the first and second primary tube out and down to clear the steering crap that's in the way. I figure with that and then having the headers coated after we test fit them I'll have around $600 in them total. Worth it, hell ya.
95 T-Bird
2Vbird is offline
post #6 of 6 (permalink) Old 07-23-2002, 09:28 PM
4 Cam Bird's Avatar
I really want to fab a set of headers some day for the new motor, I was kind of planning on starting from scratch with some tube, a plate of steel, and I am pretty sure you can buy collectors, getting everything lightly tacked in place and taking them and haveing everything TIG welded and then maybe jet hot coated...I have a dream!
2011 CTS-V Wagon
4 Cam Bird is offline
