Question about bad engine behavior - TCCoA Forums
post #1 of 13 (permalink) Old 07-23-2002, 10:04 AM Thread Starter
Send a message via Yahoo to wkenneth
Well...yesterday my car started running like crap. It stutters all the way from 1000 to 4500....its very very noticeable when driving up hills and such....any ideas what might cause this?
Got a K&N Cone, Custom exhaust, and thats it so far, but I've had those for a while as in the months, and nothing happened yet.
Thanks guys
wkenneth is offline
post #2 of 13 (permalink) Old 07-23-2002, 10:28 AM
Rolling-Thunder's Avatar
Standard answer for this one is to first clean the MAF
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #3 of 13 (permalink) Old 07-23-2002, 11:08 AM Thread Starter
Yeah, maf is cleaned. Still runs like poo. Any other suggestions?
wkenneth is offline
post #4 of 13 (permalink) Old 07-23-2002, 11:39 AM
Refrigerator Raider Hater
GreenBird's Avatar
plugs and wires...
CHECK your plugs and wires.
you can check your wires by opening the hood at night in a dark place. with the engine running, you will see blue flashes of light from the plug wires if they are bad. plugs should be red-gray with slight wear.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #5 of 13 (permalink) Old 07-23-2002, 11:40 AM Thread Starter
So I should check for arcing, or just bad wires and plus?
wkenneth is offline
post #6 of 13 (permalink) Old 07-23-2002, 11:41 AM
I guess the next thing I would check is plugs and wires, maybe fuel filter, too.
Have you tried actually disconnecting the maf and taking the car on a test drive?
I am still leaning towards the MAF sensor..........
How many miles, and what year T-Bird ?
post #7 of 13 (permalink) Old 07-23-2002, 11:43 AM Thread Starter
I'll check plugs and wires, its a 95 bird w/ 103k
No I havent tried driving w/o the MAF, but I can do that this afternoon....
thanks
wkenneth is offline
post #8 of 13 (permalink) Old 07-23-2002, 11:47 AM
If your wires have 103K on them, then you should replace them anyway.
With that many miles, it could be that your MAF has just had enough.
Keep us posted.
Note:
In case you don't know, the MAF being disconnect may cause your check engine light
to come on. If it does, just re-set the computer by doing the fuse #15 trick.
post #9 of 13 (permalink) Old 07-23-2002, 11:48 AM
GreenBird's Avatar
checking for arcing IS check the wires.
96 Alpine Green V8
post #10 of 13 (permalink) Old 07-23-2002, 11:49 AM Thread Starter
I've been looking into the wires thing already, and the maf is a ReMan that was on the car when I bought it. I'll disconnect it and see what happens....
wkenneth is offline
post #11 of 13 (permalink) Old 07-23-2002, 02:08 PM Thread Starter
Well guys, the culprit has been found.
My alternator was putting out exactly ZERO amps. Which is not good when its sposed to be pushing 130. So my car is dead in my friends neighborhood. woohoo
Anyway, called autozone $167.99 w/ a $35 core charge. Owie. Well...gotta do what I gotta do. Thanks for all your suggestions guys. Much appreciated...I probably wouldnt have cleaned my MAF yet, but its done now. Now I'm waiting for my girlfriend to call me back (since she works at a body shop and gets parts at cost *cough*) Anywho...
wkenneth is offline
post #12 of 13 (permalink) Old 07-23-2002, 02:17 PM
You should be able to get a better deal than that on a 'new' alternator.
There also should be 'electrical rebuild' shops near you that could even
fix yours for less than that.
Good luck, and let us know how you make out !
post #13 of 13 (permalink) Old 07-23-2002, 07:01 PM Thread Starter
Well, got the alternator replaced...bought new plugs since it is running lean, I think they're cooked....so I'll put those in later...as for the engine.....very very nice. Runs better off an alternator than it does a battery :P
Thanks for all your help guys...
wkenneth is offline
