Compression ratio with PI heads - TCCoA Forums
post #1 of 3 (permalink) Old 07-23-2002, 09:50 PM Thread Starter
scott's Avatar
I plan to do the PI head swap soon and was thinking 10.4-1 might be a bit to high and hard on the bottom end. I was thinking of haveing some material machined out of the bowls to lower the ratio or is the engine up to it. I plan on 24 lbs injectors bigger fuel pump headers MAF new intake manifold. So what MAF and should I go for the Bullit intake or the stock 99 GTone?
97 LX sport 4.6
T-45 5 speed, 3.73 with track lock; PI heads, 02 MAF, #24 injectors,190 fuel pump,JBAs, 75mm TB. ect,ect.; Aluminium drive shaft. 13" PBR Brakes; Dennis chip, lowered with solid sway bar bushings and hiem joints; console mounted E brake WITH the cup holders; C&l Plenum, Steeda U/D; VERY big radiator; 2.5" duals, Magnaflows;B&M ripper shifter; bla..bla...bla...
Lincoln MKVIII 93.........sweet ride.
Bag-less, lowered.
scott is offline
post #2 of 3 (permalink) Old 07-24-2002, 12:06 AM
Refrigerator Raider Hater
GreenBird's Avatar
Re: Compression ratio with PI heads
How many miles on the car? had a compression or leak down test done? If you engine is in good condition there shouldn't be any problems.
Get a chip re-burn from Dennis, Dom, or Pete. Inject Tech rules. I know Dennis carries MAFs...not sure on the other guys. I would suggest the 80mm "NA" MAF.
The bullitt is not worth the $$$ unless you are supercharged or are uncomfortable with a plastic intake.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 3 (permalink) Old 07-24-2002, 09:05 AM Thread Starter
scott's Avatar
Thanks Greenbird. I have 60,000 miles on the car but I haven't done a compression test yet.
97 LX sport 4.6
Bag-less, lowered.
scott is offline
