Underdrive Pulleys?? - TCCoA Forums
post #1 of 15 (permalink) Old 07-23-2002, 10:24 PM Thread Starter
bmac's Avatar
Send a message via AIM to bmac Send a message via Yahoo to bmac
Question Underdrive Pulleys??
Underdrive Pulleys?? Which one should I get?
Brian Macfadden
Look Good, Be Loud & Go Fast!
1997 Ford Thunderbird LX
bmac is offline
post #2 of 15 (permalink) Old 07-23-2002, 11:00 PM
Boost Happy
Jurgen's Avatar
Send a message via AIM to Jurgen
i am about to get some U/D pulleys and most people told me if u have the money
go with the Stedda pulleys they r already balanced and they r better and the march perf
u have to reuse ur balancer or they have some on carpars.com i think they say r march perf
and they go for $58
Jurgen is offline
post #3 of 15 (permalink) Old 07-23-2002, 11:54 PM
Refrigerator Raider Hater
GreenBird's Avatar
Despite...
the ghetto english...he is right. the steeda pullies are the best. a secondary option is the ford FRPP set. you just get a set for a 96-98 GT. There are sets that are for 96-01 but you have to make sure that the water pump pulley is the same design, other wise your water pump pulley won't stick out far enough. If you do happen to ge the wrong set, you will be able to tell by comparing the water pump pullies...it is easy to see.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 15 (permalink) Old 07-24-2002, 05:13 AM
WaLieN's Avatar
Send a message via AIM to WaLieN
For the Steeda ones, get the ones that fit the "96-01" Mustang GT's. You can get a set off ebay for about $125 shipped.
☼1997 Ford Thunderbird LX - 4.6L -K&N Panel Filter-Steeda U|D Pulleys-Steeda 180* Thermostat-Removed Intake Silencer-Polyurethane IRS Bushings-Tranny Cooler-Urethane Tranny Mount
☼1993 Mazda RX-7 Touring [VR] - Rotary Power rebuilt turbos & motor w/ 3mm Apex Seals - PWR Radiator - PFS Cat-Back - RB Intake Duct w/ K&N Panel - Manual Boost Controller - KG Differential Brace - Gotham Engine Torque Brace - Aluminum 45mm Front STB - B&M Short Throw Shifter - PFS Column Mounted Boost Gauge - Falken Azenis ST115s [235/40ZR17] on Speedy Mashie Silvers
WaLieN is offline
post #5 of 15 (permalink) Old 07-24-2002, 12:50 PM Thread Starter
bmac's Avatar
Despite... the ghetto english
No kidding! Thanks for the info.
So just to be sure get the steeda U/P's for a 96-01 Mustang GT.
Brian Macfadden
bmac is offline
post #6 of 15 (permalink) Old 07-24-2002, 02:48 PM
GreenBird's Avatar
Double checked my info...the change is mid 2002, not mid 2001 like I thought.
Any 96-01 kit will work.
96 Alpine Green V8
post #7 of 15 (permalink) Old 07-24-2002, 06:47 PM
Send a message via AIM to UltraChicken
I've heard from people who have worked on other cars (hondas, Camero, ect.) that underdriving the alternator is a bad idea. Does anyone have any exeriance good/bad?
Josh
UltraChicken is offline
post #8 of 15 (permalink) Old 07-24-2002, 06:52 PM
WaLieN's Avatar
Why would it be bad at all? If anything, it would be good, because you're making it work much less that it should.
WaLieN is offline
post #9 of 15 (permalink) Old 07-24-2002, 08:28 PM
My assumption is that underdriving the alternator is bad because you are getting a lower charge from it. Am I right or is this idea just an old mechanics tale? And if so does anyone know of a low spin alternator?
Josh
post #10 of 15 (permalink) Old 07-24-2002, 08:59 PM
BR1
Send a message via AIM to BR1
mine works fine. 5K miles on them now, no charge issues whatsoever, and i have 2 batteries, 2000watts rms stereo. i can't understand that tale because the alternator is spinning fast when the car is at 5000 rpm, and when its at idle the alt is spinning slow. what is another 200 rpm drop causes by the pulleys??? nothing.
J-chipped
90mm Lmaf, GT tube
magnaflow exhaust
FRPP pulleys
17x9 Cobra R chrome
255/45/17, 245/45/17 potenzaRE-730
13" cobra brakes, KVR rotors
1.25" addco rear bar
mark VIII driveshaft
bilsteins & tokico springs
BR1 is offline
post #11 of 15 (permalink) Old 07-24-2002, 09:14 PM
GreenBird's Avatar
Josh
Most kits will have full charge rpm listed. Most are around 1000rpms. The only way to get in trouble would to sit and idle you car for a long period of time with a big stereo booming.
96 Alpine Green V8
post #12 of 15 (permalink) Old 07-24-2002, 09:17 PM
Robinson's Avatar
Send a message via AIM to Robinson
personally, ive yet to see an electrical system fail due to underdrive pullies. yes it will require a higher rpm to fully charge(small when you consider the operating range of the engine) but like everyone is saying, unless you just sit the car at idle, turn on all your accessories and have a power-hogging stereo, its not going to be a problem. a couple seconds back at the charge rpm and you are good to go anyway.
www.innerlusion.com
89 SC 5 speed
FCoNE President
Robinson is offline
post #13 of 15 (permalink) Old 07-24-2002, 09:31 PM
Boost Happy
Jurgen's Avatar
i havet got my pulleys yet but people say that theres not a big difference in size
so it shouldt be a big problem and i have seen em so i dont know y they sell the ALT
pulley
1994 Ford Thunderbird
2002 Corvette Z06
Yeah I got a few mods.And Some More
http://www.cardomain.com/ride/239875
Jurgen is offline
post #14 of 15 (permalink) Old 07-24-2002, 10:35 PM
Robinson's Avatar
pulley
its funny you mention that, because when i compared my March alternator pully to the stock one, there was NO difference. too tired to know for sure, but i think that if you spin the crank quicker, it will have to spin the alternator slower, hence the lower speed, but im not positive on that and i dont feel like checking
www.innerlusion.com
89 SC 5 speed
FCoNE President
Robinson is offline
post #15 of 15 (permalink) Old 07-24-2002, 10:46 PM
GreenBird's Avatar
a smaller crank pulley leads to slower belt speed, which will make everything spin slower. to keep something spinning the same speed per RPM as before you must replace it with an equal ratio pulley as the crank. So if the new crank pulley is 20% smaller, to keep the alt spped the same the new alt pulley needs to be 20% smaller.
96 Alpine Green V8
