Data Link - TCCoA Forums
post #1 of 5 (permalink) Old 07-24-2002, 04:34 AM Thread Starter
Question Data Link
My check engine light came on recently, so I went buy a code reader. I then found out my 95 lx needs the more expensive one, obviously. But both the OBD II and the Ford harnesses did not fit the port under my glove box. I know its probably something really obvious, but what type of code reader do I need and where might I get one? (Realitively cheap hopefully?) Am I just a retard or has somebody else had this problem?
95 T-Bird LX
flows catback
shift+
K&N FIPK
3" intake
MSD superwires
H&R springs
shortputt is offline
post #2 of 5 (permalink) Old 07-24-2002, 05:11 AM
WaLieN's Avatar
Send a message via AIM to WaLieN
What did you buy one for? AutoZone reads em for free.
☼1997 Ford Thunderbird LX - 4.6L -K&N Panel Filter-Steeda U|D Pulleys-Steeda 180* Thermostat-Removed Intake Silencer-Polyurethane IRS Bushings-Tranny Cooler-Urethane Tranny Mount
☼1993 Mazda RX-7 Touring [VR] - Rotary Power rebuilt turbos & motor w/ 3mm Apex Seals - PWR Radiator - PFS Cat-Back - RB Intake Duct w/ K&N Panel - Manual Boost Controller - KG Differential Brace - Gotham Engine Torque Brace - Aluminum 45mm Front STB - B&M Short Throw Shifter - PFS Column Mounted Boost Gauge - Falken Azenis ST115s [235/40ZR17] on Speedy Mashie Silvers
WaLieN is offline
post #3 of 5 (permalink) Old 07-24-2002, 11:28 AM Thread Starter
Just my luck, too. Theres no Autozone where I live.
post #4 of 5 (permalink) Old 07-24-2002, 11:35 AM
Automatic Weapon
Big-Al's Avatar
No Autozone?!?!?!
Time to pick up steaks and move camp!:p
<----not throwing rocks at girls anymore
Big-Al is offline
post #5 of 5 (permalink) Old 07-24-2002, 01:01 PM
bmac's Avatar
Send a message via AIM to bmac Send a message via Yahoo to bmac
If you have a laptop and some money I would go with this one...
OBD Automotive Diagnostic
I use it and its really easy the software is free and the hard ware only cost me $80.00 at the time.
But it can get really expensive if you don’t have a laptop.
Brian Macfadden
Look Good, Be Loud & Go Fast!
bmac is offline
