4.6 Build up..Engine experts tell me what you think - TCCoA Forums
post #1 of 4 (permalink) Old 07-25-2002, 06:05 PM Thread Starter
Slacks 12 months a year
LX-Tasy's Avatar
Here are my new plans.I have a 94 Mark VIII short block,and I want to use 94-98 2 cam heads to keep the compression lower,99 GT cams and the 99 GT intake.I plan on using a Vortech later so that is why I want to keep the compression lower then I would get with the 99 and up PI heads.Of course I am going to have an 88 MAF and chip along with the DIS 4.A 5-seed along with 4:10 gears and true dual exhaust.
How do you think this would run?Let me know and if you have any suggestions.
Thank You,
Chris
LX-Tasy is offline
post #2 of 4 (permalink) Old 07-29-2002, 05:01 AM
Noe S.'s Avatar
Why not go with the 32v heads?
You do know that 96-98 heads have different ports than 99and up heads. Thus the 96-98 heads wouldn't match the 99 intake.
Noe S. is offline
post #3 of 4 (permalink) Old 07-29-2002, 08:09 AM Thread Starter
LX-Tasy's Avatar
You are right....
Thanks for the correction.I knew that the 99 intake is different and I still ask,duh.I also have the 32 valve heads but I just wanted to keep it sorta simple I guess.I guess I will be looking for 99 heads now to.I guess I could run a thicker head gasket to keep the compression ratio down so I can put a little bit more boost on it or I could just run the Mark block,old heads and intake with 99 cams,huh?Just a thought I have been kicking around.My goal is either a Vortech or Kenne Bell now,not sure yet.
Chris
LX-Tasy is offline
post #4 of 4 (permalink) Old 07-29-2002, 09:13 AM
Robinson's Avatar
Send a message via AIM to Robinson
http://www.mtcforum.com
www.innerlusion.com
89 SC 5 speed
FCoNE President
Robinson is offline
