where do I get a new Harmonic balancer bolt ...read - TCCoA Forums
post #1 of 4 (permalink) Old 07-26-2002, 07:40 PM Thread Starter
for a set of underdrive pullies that I got from a guy. He had to keep the bolt to re-install the old pulley. where do I get one to work with the new pullies. I believe they are ASP. I guess I should ask ASP huh ...but I haven't got the pullies yet. just asking to get an idea.
Mike
MZ-Bird is offline
post #2 of 4 (permalink) Old 07-27-2002, 07:03 AM Thread Starter
I was told I would need a longer bolt than stock. that was why I asked.
do I need a longer bolt or not?
I will check with Auto SPecialties
Mike
MZ-Bird is offline
post #3 of 4 (permalink) Old 07-27-2002, 11:13 AM
AED Specialist
A-Train's Avatar
Post Bad info...
This is what I'm talking about. First the crankshaft bolt is a torque-to-yield type, meaning it stretches when installed and torqued. That means you SHOULDN'T re-use it. I would also get a new washer was well, but it's not my car.
Second this bolt is less than $5.00 from your Ford dealer (p.n. F1AZ-6A340-A). Third to install ASP underdrives, you need a longer bolt to START the pulley onto the shaft. Then you remove that bolt and install a NEW stock bolt and torque it to the recommendation by ASP. It's 115-120 lb.-ft. in the Ford service manual. Don't forget the dab of high temp RTV to the keyway of the pulley before you install it or it will leak oil.
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
post #4 of 4 (permalink) Old 07-27-2002, 05:47 PM Thread Starter
A_TRAIN!!!!!!!
I haven't seen you in a long time. Of course I don't have time to scan boards daily.
Yes, after reading this stuff for 5 years I still don't have many mods and still need help from time to time.
About that washer.....what type of washer or part number is it?
I ordered the MARCH set from CarParts.com this morning after thinking about the bolt situation.....
So, I may not need the new bolt after all right?
I am going to sell the set without the bolt to someone else and keep the March Set.
thanks for the help everyone!
Mike
MZ-Bird is offline
