'98 Cobra IMRCs - TCCoA Forums
post #1 of 11 (permalink) Old 09-02-2006, 11:39 AM Thread Starter
driller's Avatar
'98 Cobra IMRCs
Will the '98 Cobra IMRCs fit on the '93 Mark VIII with a stock(NOT Cobra) intake?
RH Plate: F8ZZ-9U531-AA
LH Plate: F8ZZ-9U531-BA
Do they help?
driller is offline
post #2 of 11 (permalink) Old 09-02-2006, 09:37 PM
ThunderBeast86's Avatar
Send a message via AIM to ThunderBeast86
Well, they do help.
In our large cars, the extra hp/torque down low helps our fat ladies move off the line.
As for working....they SHOULD, both are B heads............ someone else will have to chime in.
2.25" True Dual Catless DI/DO Magnaflow Exhaust, Eibach Springs, Addco 1 3/8", J-mod, Viper 791 Alarm, Clarion 855 full color touch-screen, Directed 2400 amp , 2 12" CV Strokers with a custom ported box, K&N air filter, 180* T-Stat, Xcal2 SCT TUNED BY LONNIE 17 x 7.5 (245/45/17) Chrome Cobra R's, 17x9 in back(275/40/17)
DOHC sitting in the garage
Teksid 2v plans?!?!
Tranny Cooler, Dual Remote Oil Filter waiting for install
ThunderBeast86 is offline
post #3 of 11 (permalink) Old 09-03-2006, 01:15 AM
CLowe1243's Avatar
Send a message via AIM to CLowe1243
It's a pretty simple swap...only issue i am concerned about will be the controllers. But I'm pretty sure it is the same as the Mk8's stock ones. Why would you want to swap IMRC's anyway? Keep in mind you can't fix a bottleneck from the bottom up.
CLowe1243 is offline
post #4 of 11 (permalink) Old 09-03-2006, 11:30 AM Thread Starter
driller's Avatar
Yes, they are both 'B' heads. I was told the '98 Cobra IMRC housings are plastic? Much like the plastic SOHC intakes, they should help resist heat soak. The '93 Mark VIII intake and IMRCs being aluminum get hot easily.
My thinking is the plastic IMRC housings would help, much like a composite spacer. I have a ported/polished/coated Gen1 intake I plan to swap in and was hoping the actual ports were the same to match the IMRCs.
As far as the controllers, I've known others who went with the Cobra intake on a Gen1 and used the electric controllers. It requires using the IMRC vacuum solenoid and a relay to acuate the electric Cobra IMRC controllers. A MSD window switch could also be used. So, barring any physical constraints, one should be able to make it work?
Or I can just clean up the IMRCs I have, gasket match them and go with what I have.
As far as the bottleneck, I hope to later get ported/polished heads with a new valvetrain and cams.
driller is offline
post #5 of 11 (permalink) Old 09-03-2006, 12:38 PM
Thomas A's Avatar
GenII Mark VIII IRMC's are also plastic. Physically, they will mount up just the same, and as you mentioned, you just have to rework the controllers a bit as they are a different setup.
Thomas
1989 Cougar XR7 - 13.21 @ 102.29 -SOLD-
1993 Thunderbird SC -Awaiting Suspension-
1994 Mark VIII - 14.85 @ 93.95 -SOLD-
1996 Thunderbird Sport 15.57 @ 89.42 -Retired @ 258k-
1997 Thunderbird LX AED -SOLD-
1997 Thunderbird Sport 15.71 @ 86.89 -SOLD-
1997 Mark VIII LSC 12.97 @ 112.15 -SOLD-
Thomas A is offline
post #6 of 11 (permalink) Old 09-03-2006, 01:14 PM
Lonnie's Avatar
Yes they will work John but you will like you said have to use their controler or grind off the linkage of both and then install the Mark's linkage. They not only help with the heat soak but they are slightly larger.
www.blueovalchips.com
1992 5.0 Thunderbird Sport, 328 rwhp 347 rwtq
1995 Mark VIII, 287 rwhp 305 rwtq
I have seen the truth and it makes no sense
Lonnie is offline
post #7 of 11 (permalink) Old 09-03-2006, 02:13 PM Thread Starter
driller's Avatar
Thanks for the response guys!
Let the hunt begin!
driller is offline
post #8 of 11 (permalink) Old 09-04-2006, 02:42 PM
If you can fit cobra/gen2 plates with stock 1st gen intake, you're a GOD and I bow in front on you ! LOL
IMPOSSIBLE !!! without reworking the primaries of the intake, or IMRC ports. They will bolt up but the plates won't line up with intake ports.
Mad1stGen is offline
post #9 of 11 (permalink) Old 09-04-2006, 03:07 PM Thread Starter
driller's Avatar
So the Gen2/Cobra IMRC ports are the same as the head but not the same as the Gen1 intake?
Weird.
driller is offline
post #10 of 11 (permalink) Old 09-04-2006, 03:09 PM
yup, that's why when swapping to the cobra intake on a 1st gen car, you have to use the cobra/gen 2 plates with either electric actuators or swap over the rods and vac actuators from mark 8 to cobra plates. Either way you have to use the cobra plates. Sorry ...
post #11 of 11 (permalink) Old 09-04-2006, 04:38 PM Thread Starter
driller's Avatar
That's fine, I'll just clean up the IMRCs I have to go with the intake swap. If/when I go to a Cobra intake, I'll go with the Cobra IMRCs.
driller is offline
