Missing - foot on brake in drive - TCCoA Forums
post #1 of 11 (permalink) Old 09-03-2006, 11:13 PM Thread Starter
I just changed my spark plugs 22C's to 12C's (have chip - had slight ping at 40mph).
After I changed the plugs the problem started.... Idles fine, it does have slight slight slight miss.
But when I put it in Drive and hold the brake (like at a red light) it will miss very noticably every 6-8secs.
Thing is I thought that maybe the plugs where damaged??? So I swapped the 22C's back in and it does it with them in it now too.
krazy3o4 is offline
post #2 of 11 (permalink) Old 09-04-2006, 12:14 AM
Baby Huey
warmaster259's Avatar
Sounds like a vacuum issue.
Jim
warmaster259 is offline
post #3 of 11 (permalink) Old 09-04-2006, 06:54 AM
Vacuum leak in the brake booster?
Bob
thunderferret is offline
post #4 of 11 (permalink) Old 09-05-2006, 01:13 AM Thread Starter
Well I think I found my problem. I did replace a few pieces of vacuum line, but I don't really think thats what the problem was.
Was working on it tonight, and had someone else throw it in drive while I watched; at least 4 of the plug boots where arcing!!! It wouldn't do it at idle, but as soon as it was in drive or reverse, BAM I could see the arcing plain as day.
I think I'm going to try some of the MSD wires. I'll let you know for sure tomarrow if that was the ONLY problem.
krazy3o4 is offline
post #5 of 11 (permalink) Old 09-05-2006, 02:04 AM
Moderator & Teksid Whore
guitar maestro's Avatar
makes sense....a denser aircharge, like when in gear, will increase the resistance within the plug gap, so the spark looks for the path of least resistance to ground....but the plugs would have to be severly over-gapped for this.....are the plugs gapped correctly?....... if so, then sounds like the plug wires are to blame
guitar maestro is offline
post #6 of 11 (permalink) Old 09-05-2006, 08:16 AM Thread Starter
They're gapped at 0.056
krazy3o4 is offline
post #7 of 11 (permalink) Old 09-05-2006, 06:35 PM
Send a message via AIM to AtroXR7 Send a message via Yahoo to AtroXR7
sure you got your boots snapped back on tight? I use MSD wires... good stuff, good click in from the boots.
AtroXR7 is offline
post #8 of 11 (permalink) Old 09-05-2006, 07:44 PM Thread Starter
Well the miss was from the wire's. Went and bought some MSD wires today, hooked them up & Wah-lah! miss is gone and POWER is back.
krazy3o4 is offline
post #9 of 11 (permalink) Old 10-31-2006, 01:50 PM
Where do you get the wire holders above the alternator? Mine are routed below the alternator. A PITA to route that way. Probably a lot hotter, too. Could be clue to early wire failure.
Leroy
'95 TBird 4.6L LX
'69 Galaxie 500 2dr
'16 Fusion
lgharis is offline
post #10 of 11 (permalink) Old 10-31-2006, 02:19 PM
Faster than Porkchop
cjchevez's Avatar
That s a updated intake with the alum crossover.
The bracket should come with the intake .
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #11 of 11 (permalink) Old 10-31-2006, 02:33 PM Thread Starter
Yeah the bracket works on all the updated aluminum x-over intakes and the PI intakes as well!
krazy3o4 is offline
