Need HELP ASAP...please... - TCCoA Forums
post #1 of 3 (permalink) Old 09-04-2006, 02:23 AM Thread Starter
Send a message via AIM to Green Thunder Send a message via MSN to Green Thunder Send a message via Yahoo to Green Thunder
Hey guys/gals... I'm still new to the forum, so I appologize if this is in the wrong forum...but I need help bad!!
I gotta get this Bird running in 12 hours or I am screwed... its 1:30AM now...
Please help with any input.
Vehicle Info:
1994 Ford Thunderbird
4.6L V8
Problem:
The vehicle was running very well, then... there's fuel but no spark. When vehicle is turned on but not running. A box in the engine compartment, that is located exactly in front of the air box is making a humm and also changes pitch in the noise when it is disturbed/moved. (See pic for reference...)
What is this box?
Any ideas why it won't start now?
Does this box have anything to do with lack of spark?
Photobucket - Video and Image Hosting
Real desperate here, gotta get this bird running. Thank you all in advance.
Please reference this same topic with further discussion and troubleshooting. I am still new to the forum and thought I would try this section too, thanks!
http://forums.tccoa.com/showthread.php?t=89025
Andy
Green Thunder is offline
post #2 of 3 (permalink) Old 09-04-2006, 06:58 AM
Rolling-Thunder's Avatar
There is a duplicate post in the Club forum.
I agree with Sir William to check the crank position sensor.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #3 of 3 (permalink) Old 09-04-2006, 08:26 AM
svtbird88's Avatar
To answer your first question it is called IRCM/CCRM it is a relay control module inside is the eec, fuel pump, wot, and fan control relays. If it is humming then I would check all powers & grounds to it. My guess would be you have a bad ground and the noise is the relays cycling off and on. This could be the cause of your lack of spark.
svtbird88 is offline
