Engine bay wiring harness - TCCoA Forums
post #1 of 7 (permalink) Old 09-05-2006, 12:59 AM Thread Starter
Peter M's Avatar
So, I just got a Meziere electric water pump, and was looking for a place to get a switched feed that only was on with the engine in 'run', not 'acc'. The instructions said to use Pin 9 on the harness coming from the firewall on the passenger side.
Well, it works... but what exactly did I tie in to? I can't find a reliable wiring diagram anywhere.
Peter M
SOLD 1996 4.6l Thunderbird-(fast) PI intake, custom exhaust, Bullet-Resistant Tranny™, blah, blah, blah
2007 VW GTI-(faster) United Grey, 18" wheels, APR stage 1 chip, and... uh... that's it for now.
________________________
..this space for rent..
Peter M is offline
post #2 of 7 (permalink) Old 09-05-2006, 02:09 AM
Moderator & Teksid Whore
guitar maestro's Avatar
you can open up the wire loom for the wires going to the coil packs......red with green stripe is the color that is ignition-switched on....so you could use this to turn on a relay....the actual positive voltage to drive the pump would then have to come from either the battery or some wire after the fuse box in the engine bay, if you havent already done so
guitar maestro is offline
post #3 of 7 (permalink) Old 09-05-2006, 07:48 AM
Whining Intakes Rock
Al_Florida's Avatar
^ yes, please use a relay (if you aren't already) and grab the power for the pump off the battery. That pump probably will draw too much power for most of the wires in the loom.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #4 of 7 (permalink) Old 09-05-2006, 08:54 AM
Pin 9 in the wiring diagram is shown as the power supply for most of the engine's electronic controls. At quick glance I can see it powers the fuel injectors, oxygen sensors, EVAP components, IAC, and EVR. I agree with the others to use a relay. You could really distrupt some things by drawing that much amperage from the wiring harness.
post #5 of 7 (permalink) Old 09-05-2006, 10:17 AM Thread Starter
Peter M's Avatar
Thanks 486, thats what I was looking for.
Just to put everyone's mind at ease, YES I did use a relay.
I just wanted to know what I had that only was hot in run.
Peter M is offline
post #6 of 7 (permalink) Old 09-05-2006, 03:39 PM
Al_Florida's Avatar
Get a voltmeter
# 0 rows returned
post #7 of 7 (permalink) Old 09-05-2006, 04:01 PM Thread Starter
Peter M's Avatar
Already got one. Too lazy to probe every wire.
I had the high current feed taken care of. I have a multitap terminal on the battery post. Toss on an inline fuse, relay... all set. Finding a feed on in run AND acc was easy. Finding the run only.... priceless.
Peter M
Peter M is offline
