will this work air tube - TCCoA Forums
post #1 of 7 (permalink) Old 09-05-2006, 10:07 AM Thread Starter
baylensman's Avatar
Send a message via AIM to baylensman
http://cgi.ebay.com/ebaymotors/HIGH-...QQcmdZViewItem
is this the honda tube that every one talks about will it work on the 97 4.6??
price looked good
i'd rather go slow than not go at all
1996 MKVIII air ride delete
2007 Royal star venture (loaded)
2007 Ford free style 3.0 v-6
baylensman is offline
post #2 of 7 (permalink) Old 09-05-2006, 10:10 AM
Back in Black
ShadowDragon's Avatar
That's for 94-95's, 96-97 have a totally different intake path.
ShadowDragon is offline
post #3 of 7 (permalink) Old 09-06-2006, 10:13 AM
Send a message via AIM to AtroXR7 Send a message via Yahoo to AtroXR7
autozon and pepboys now have these modular style intakes so you can build your own intake. They're multi plated plastic so they're very resistant to the elements, but look a lill janky to me. If you want looks... Id modify a mustang tube. If you want performance, look elsewhere, cause intake side mods have proven to not be worth the money unless you're stroked.
AtroXR7 is offline
post #4 of 7 (permalink) Old 09-06-2006, 10:17 AM
Back in Black
a 96-97 doesn't need to modify a mustang tube...
post #5 of 7 (permalink) Old 09-06-2006, 09:02 PM
well the MAF to TB connection should be identicle, but some tubes need modified to turn down rather than to the side to get into a fender. I wouldnt consider altering the intake unless the filter was away from the hot air from the radiator fan. Even with a "cold air" setup I've seen 60 deg. intake temps in the middle of winter.
AtroXR7 is offline
post #6 of 7 (permalink) Old 09-06-2006, 10:20 PM
Merlon's Avatar
right now im using that one
but after the maf to a k&n filter in the fender.
ill take some pics, but for what they charged at auto zone ($39) id go elsewhere now.
get a pice of mendrel bent exaust tubing, paint it, couplers, and id be happy.
some use plastic parts found at ace, or homedepot in the plumming section. a saw and a few couplers later and youve got an intake.
00 GT transmission,Jmod,30,000 gvw transmission cooler
Air silencer removed(cone filter added w/ heatshield)
shaved emblems, doors, trunk, and antenna
Clear corners
chrome 95sc rims
20% tint all the way around,
6gallon air tank capacity, Viair 400c commpressor
175psi pressure switch
custom guages by Scott H.
http://www.cardomain.com/ride/2733945
Merlon is offline
post #7 of 7 (permalink) Old 09-07-2006, 04:15 PM
i just run a 3" 60deg. "street" PVC elbow and sized the pod to fit around the larger part of the elbow and a 3" rubber coupler to the maf, used it for years and works great.
AtroXR7 is offline
