Opinions on a damaged block? - TCCoA Forums
post #1 of 8 (permalink) Old 09-05-2006, 02:06 PM Thread Starter
Silenced's Avatar
I found a 96 cobra block with 17k miles on it, but it was involved in an accident.
"Apparently", the motor mount was jammed up into the skirt of the block, making a crack in it. Since it is a teksid aluminum block, it should be able to be welded back up... but also since it is an aluminum block, couldn't the force of that impact have damaged everything inside??
Silenced is offline
post #2 of 8 (permalink) Old 09-05-2006, 02:11 PM
nickmckinney's Avatar
Does the crank turn smoothly in the block?
nickmckinney is offline
post #3 of 8 (permalink) Old 09-05-2006, 02:24 PM Thread Starter
Silenced's Avatar
I haven't looked at it yet. I'll be buisy with work until probably Friday.
Assuming someone doesn't stop me by yelling "BAD IDEA", I'll go check it out. I have never tried to turn a block before without heads on it... How hard should it be to turn?
Silenced is offline
post #4 of 8 (permalink) Old 09-05-2006, 02:28 PM
Should be pretty smooth, even with all the pistons and rings still there.
post #5 of 8 (permalink) Old 09-05-2006, 02:41 PM
02 Explorer Pioneer
timb's Avatar
Blocks aren't that hard to come by if that one is cracked just look for another
Birdless
timb is offline
post #6 of 8 (permalink) Old 09-05-2006, 06:22 PM
Send a message via AIM to AtroXR7 Send a message via Yahoo to AtroXR7
I'd shy away from a cracked alum block. Yes it can be welded... im not sure which aluminum a teksid is actually made of but the actual crack is probably a simple repair. The issue is that aluminum blocks have very tight tolerances compared to iron. its possible that some of the geometry was offered. If you're considering this for a full rebuild where you can blueprint it and check the deck, Id say go for it as long as you check the crank rotation and everything feels smooth. Check with and without plugs for compression and ease of motion. I wouldnt look at it if you just wanna weld the crack and try to run it. unless its just a stupid good deal.
AtroXR7 is offline
post #7 of 8 (permalink) Old 09-05-2006, 08:02 PM
Refrigerator Raider Hater
GreenBird's Avatar
I wouldn't touch it, just find a good block.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #8 of 8 (permalink) Old 09-05-2006, 08:14 PM Thread Starter
Silenced's Avatar
Ok, I'll stay away then
Mods, feel free to delete this thread if you want, it has served its purpose.
Silenced is offline
